Torx screws
Source sought
charadam04/12/2009 12:09:56
185 forum posts
6 photos
I keep losing the tiny Torx screws from my insert tools.
Does anyone have a source for bulk spares?
Thanks,
Charles
David Clark 104/12/2009 12:33:07
3357 forum posts
112 photos
10 articles
Hi there
I
think each maker supplies slightly different screws with their tools.
I suggest you buy the correct screw for the job.
Not
cheap but usually good quality.
regards David
KWIL04/12/2009 14:21:47
3681 forum posts
70 photos
Put candle wax on the end of the torx screwdriver and do not change over a swarf filled tray!!
David Clark 104/12/2009 14:45:39
3357 forum posts
112 photos
10 articles
Hi There
Use a can of WD40 to blow the swarf out of the screw.
Magnetise the Torx driver if possible.
Keep a couple of spares in stock.
regards David
Clive Farrar24/01/2010 17:37:40
125 forum posts
41 photos
Charadam, you are a jinx    I read your post last night and thought why does he need them I,ve never lost one.
Then I went out to the workshop to look at making a tool holder for some ccmt 11 tips I got by mistake. I found a spare M 2,5 torx X from an SCLR boring bar that I wrecked and set to on the job.  10 minutes later, ping off it went.  An extensive search with a cloth wrapped round a strong magnet failed to find it.
So now I have the same problem as you. Not easy to find a supplier is it.
Chronos do them at 85 p each !    so I tried dear old flea bay and at the third search attempt using " ccmt inserts" I came across a guy    tony4cats selling 10 of the above for £4.75 inc postage.
So mine are on the way on Monday I hope that is of use to you.
Make sure you get the right ones as the smaller ccmt tips can use M2 torx.
Regards Clive
Edited By Clive Farrar on 24/01/2010 17:38:08
mgj24/01/2010 18:29:48
1017 forum posts
14 photos
A decent fasteners supplier will sell them. Or any engineers supplies  selling tips.  They are not expensive, and I hate to say it, not difficult to come by.
Circlip24/01/2010 18:43:11
1723 forum posts
If they have a C/S head, beware as it won't be a standard C/S. You may have to machine it.
  Regards   Ian
mgj24/01/2010 19:37:17
1017 forum posts
14 photos
Are you sure Ian. The ones I have bought have been bog standard CS Torx, and they fit fine well. They are just a standard Torx screw.
They certainly fit the CCMT tips supplied by Chronos, and the Sandvik range, as well as the W six sided negative rake series.  They would because those are all standard ISO sizes, so once you get a fit in one tip, you get a fit in all. Mind you they also fit Stellram tips and those tips are not an ISO tip.
