Formula for packing
Alan White 1 | 06/11/2009 18:56:53 |
2 forum posts | Can anyone supply me with the formula for calculating the packing to place on one jaw of a three jaw chuck in order to drill an off centre holein an eccentric?
Thanks
Alan |
mgj | 06/11/2009 19:13:01 |
1017 forum posts 14 photos | Yes, and its a nightmare to write up on a computer. page 13.12 of the Model Engineers Handbook - 3rd edition. Or use a 4 jaw. |
JasonB | 06/11/2009 20:03:04 |
![]() 25215 forum posts 3105 photos 1 articles | You may also find it by looking back at a few recent back issues on line, it was covered not that long ago in "Post Bag"
Jason |
Michael Webb 1 | 06/11/2009 20:40:12 |
2 forum posts | One of the ways I have succesfully turned, or drilled an eccentric dia./hole is to turn a shouldered blank out of a piece of scrap material,of which can safely accomodate the eccentric offset (half the value of the actual eccentric) . Then mount it in a milling machine for boring or drilling half that value of the required eccentric.When transferred back to the 3 jaw chuck,a prefect eccentric.Simples.This is providing you have a milling machine with a DRO to accurately position the offset.
Edited By Michael Webb 1 on 06/11/2009 20:44:14 Edited By Michael Webb 1 on 06/11/2009 20:46:28 |
Martin W | 09/11/2009 18:28:33 |
940 forum posts 30 photos | Is there any value in using a face plate. Fix a sacrificial plate to the surface and turn this surface until true then fix your eccentric to the plate lining up the hole centre using a wobbler then drill/turn to required dimension.
I think I have seen this in articles but as a relative novice I am open to correction as my recall may not be too brilliant
![]() Cheers
Martin |
mgj | 09/11/2009 19:38:48 |
1017 forum posts 14 photos | Getting a bit complicated? Put it in a 4 jaw, machine (what will be) the eccentric OD, plus any grooves etc. Put a DTI against one edge, and move it across the required throw. Drill and bore - you now have the axle/crank bore. Part off. Stick it on a mandrel, and turn any bosses needed. Turn round and do the final face. Done. |
Mark Dickinson | 09/11/2009 20:32:22 |
48 forum posts 4 photos | Alan is this what you were looking for ? |
Alan White 1 | 16/11/2009 10:55:49 |
2 forum posts | Thank you gentlemen I have now put it on my computer for quick calculation
Alan |
Malcolm BEAK | 16/11/2009 23:16:05 |
3 forum posts | Alan
I'm probably a bit late with this
The equation given in Model Engineers Handbook is: T = 1.5E[1-E/2D - 3/8(E/D)3] E = the desired eccentricity D = the OD of the material being gripped in the chuck T = the thickness of the packing The portion of the equation in red is very small and can safely be ignored Rather than work it out each time, it’s easiest to make up a spread sheet. Malcolm |
