david simmo | 19/05/2009 16:26:50 |
33 forum posts | hi me again is citric acid ok for pickling copper boilers becouse it safer to use
but soak for longer and anyboby know where I con get a container whith lid I have spent a hour or to on the computer buy Iam abit old fashion just learing!!
thanksdave ps where spell chech on site??
Richmond | 19/05/2009 17:38:29 |
![]() 73 forum posts 632 photos 64 articles | Hi David, and welcome to the site
![]() Citric acid is fine for pickling boilers.
As to containers you should be able to get that kind of stuff from a brewers merchants.
Spell checking is something that will be looked at in the future.
Rgds
Richmond
Ian Lee | 19/05/2009 21:57:45 |
53 forum posts | I used a couple of 25 litre plastic brewing buckets on for the citric solution the other for water to clean it off after pickling, I've seen these buckets in some garden centres also try a couple of plastic dustbins with the lids having a hold down clip on them, a lot of horse tack shops sell these as they use them for feed bins and they are not that expensive![]() Edited By Ian Lee on 19/05/2009 21:58:58 |
david simmo | 20/05/2009 15:30:21 |
33 forum posts | thanks richmond,ian sounds good to me thanks again dave
Circlip | 20/05/2009 15:33:20 |
1723 forum posts | Never heard of "Tupperware" David??? But if you nick one from SWTSMBO, be prepared to Ruuuuuuuuuuuun. 'Salso a good idea to CLEARLY mark the container with a Skull and Crossbones (Well, you don't want your boiler covered in Icing Sugar do you???) The Citric ain't poisonous but the dissolved Copper in it gives it a "Distinct" taste.
Regards Ian
PS, practice spullin
Chris | 26/07/2009 10:33:38 |
87 forum posts 13 photos | If you live in a rural area you may have noticed rectangular plastic buckets in fields. They are mineral suppliment blocks for livestock. Very strong plastic, snap on lid and being about 16 inches long by nine wide and nine deep are a good shape for our purpose. farmers usually have sheds ful of empty ones.
Chris. |
Redpiperbob | 02/08/2009 10:12:26 |
![]() 92 forum posts 41 photos | Hi dave
Just came across this thread
I use the following programme for my spell checking
just download and install it.
Then Right click anywhere on your post and click check spelling.
Before you use it for the first time make sure to click on iespell options then language and dictionaries and choose (English UK)
good luck
Bob |
