Harry Wilkes | 17/08/2023 16:21:04 |
![]() 1613 forum posts 72 photos | Purchased some 0.125" bright mild steel round I find it to be 0.117" I understand that I may have been supplied 3mm, but lets say it is imperial what sort of tolerance should I expect ? H |
Bizibilder | 17/08/2023 16:26:26 |
![]() 173 forum posts 8 photos | It is 3mm. I'm not certain but I believe 1/8" has been unavailable for many years. |
JasonB | 17/08/2023 16:29:57 |
![]() 25215 forum posts 3105 photos 1 articles | Couple of thou at the most. I can still by 1/8" but get through more 3mm these days. |
Roger Best | 17/08/2023 16:44:01 |
![]() 406 forum posts 56 photos | You've bin dun, the whole point of "bright" is that it is close to size otherwise you would be happy with black bar. Ask if they have any 3.2mm. |
SillyOldDuffer | 17/08/2023 18:09:26 |
10668 forum posts 2415 photos | Posted by Harry Wilkes on 17/08/2023 16:21:04:
Purchased some 0.125" bright mild steel round I find it to be 0.117" I understand that I may have been supplied 3mm, but lets say it is imperial what sort of tolerance should I expect ? H I can't find any tolerances for Bright Imperial Round Drawn under 1/2" diameter, which is -3 thou to 0.0 Bright Metric Round Drawn under 6mm diameter should be -0.07mm to 0.0 What you have is certainly in spec for metric 3mm, and given Imperial doesn't seem to specify tolerances below 1/2", it could be street 1/8" too! Bet its 3mm though. Dave Dave |
Harry Wilkes | 17/08/2023 18:33:33 |
![]() 1613 forum posts 72 photos | Thanks Guy's for replies Jason confirmed my thinking a couple of thou H |
Mick B1 | 17/08/2023 19:27:50 |
2444 forum posts 139 photos | Posted by Harry Wilkes on 17/08/2023 18:33:33:
Thanks Guy's for replies Jason confirmed my thinking a couple of thou H That's always been my rule-of-thumb, more-or-less irrespective of nominal size up to maybe an inch or so. Don't have much experience of larger. |
