Sonic Escape | 02/08/2023 18:38:32 |
![]() 194 forum posts 5 photos | Today for the first time made something useful on the lathe. A friend needed 4 stainless steel spacers for a packing machine that he is fixing. It took me almost 3 hours. I think I would starve to death if I'll have to make a living from my lathe skills. I bought a 6.5mm DeWalt Extreme Cobalt drill for the holes. This drill is worth the money. After drilling ~170mm of stainless steel in total the cutting edge is still very sharp! It has also a triangular section on the tail so it doesn't slip in the chuck. I don't know why they don't make all drilling bits in this way. This was a good time to use also my latest finding on the Sunday flea market, a huge Jacobs chuck. This relict has stamped on it Carpati (Carpathian). So it is an old Romanian model. I suppose this is the largest chuck made for MT3. It looks like it was used a lot but it opens/close smooth and the jaws are in very good condition. It is heavy and I like it a lot. After every few mm I removed the drilling bit and add more paste and remove the swarf. There was a lot of swarf compressed inside. I don't know if it is ok to make such a deep the hole in one single drill.
In exchange I got an 8mm H7 reamer. It doesn't have a square tail but it still useful.
Andrew Johnston | 02/08/2023 18:51:23 |
![]() 7061 forum posts 719 photos | Posted by Sonic Escape on 02/08/2023 18:38:32:is heavy and I like it a lot.
In exchange I got an 8mm H7 reamer. It doesn't have a square tail.... It's a machine reamer not a hand reamer. Unlike a hand reamer it has a 45 degree angle on the front and those are the cutting edges. The start of the flutes are not tapered like a hand reamer. It doesn't have a square on the shank because it doesn't need one. it will be held in a chuck on a machine tool. Andrew |
Ady1 | 02/08/2023 22:02:26 |
![]() 6137 forum posts 893 photos | Well done you, plus you've learnt the advantage of decent drills about 10 years faster than me. |
Chris Pearson 1 | 02/08/2023 22:37:32 |
189 forum posts 3 photos | That was quick! |
Ady1 | 03/08/2023 03:09:57 |
![]() 6137 forum posts 893 photos | Saw your video Your indexed tool looks like its too far away from the job, always cut with the toolpost as close as possible to minimise tool flex When drilling deep I use an old toothbrush dipped in oil to clean the drill flutes and lubricate them between each pass Edited By Ady1 on 03/08/2023 03:11:28 |
Gaz | 04/08/2023 23:03:16 |
![]() 18 forum posts 16 photos | Satisfying isn't it, well done! |
samuel heywood | 05/08/2023 20:48:19 |
125 forum posts 14 photos | Pretty good for your First job i'd say! Was many moons before i got beyond turning Ali & brass. My first atempt at turning (mild) steel at 1st glance bore more than passing resemblence to a screw thread, rather than a smooth surface i was aiming for.
