Can anyone suggest what sort of motor this is?
Ian Parkin28/07/2023 11:31:37
1174 forum posts
303 photos
I have a need for a motor like this one
its dc 50v
it needs to fit in a smallish space hence its build (like a pancake)
Ady128/07/2023 11:34:56
6137 forum posts
893 photos
Fan motor?
Apparently small computer fans are brushless for reliability
Ian Parkin28/07/2023 12:00:09
1174 forum posts
303 photos
Sorry for got to say its about 7 inches diameter and the alloy bit is about 3.5 inches long
its a fairly powerful motor but i have no specs at all
its fused by a 15 amp so I’m guessing it draws about 8-10 in use so 500 watts or so
Bazyle28/07/2023 12:44:55
6956 forum posts
229 photos
3 phase so probably designed for soft start. Variable speed fan application perhaps.
Ian P28/07/2023 12:48:05
2747 forum posts
123 photos
Posted by Bazyle on 28/07/2023 12:44:55:
3 Phase, where did that come from?
Looks like a high torque DC motor, possibly a stacked printed armature as it has face commutator?
Ian P
Ian Parkin28/07/2023 12:55:15
1174 forum posts
303 photos
Ian p
have you seen one of these before? What would it be called?
Ian p
Ian P28/07/2023 13:08:48
2747 forum posts
123 photos
Ian
Put 'pancake motor' into Google images and see if you can identify yours
Ian P
Hairy Pete28/07/2023 13:20:34
17 forum posts
I would call it a pancake motor. Like this:
https://www.printedmotorworks.com/brushed-pancake-motors/
Or closer still, like this:
https://www.electronic-circuits-diagrams.com/store/LONGFORD-KOLLMORGEN-12CD-003-PANCAKE-DISC-SERVO-MOTOR-NNB-_155234707000.html
"12CD-003" seems to be thee part number.
peak428/07/2023 13:24:45
2207 forum posts
210 photos
I've had a brief look, but can't find anything immediately similar.
4 pole DC high torque is a starting point, but I guess you need to look at the speed as well, unless you can tell from the driving circuitry whether it's a normal 4 pole, or some sort of a servo/stepper motor..
There might be similar stuff, but not the same, on AliExpress, though the CE marking and RoHs do look in the correct format for EU rather than China Export.
What's it from and what's the problem with it?
Maybe fully re-assemble it, take a few photos and try HERE, which will search Google, Bing & Yandex
https://smallseotools.com/reverse-image-search/
You might not find one the same, but if it puts you on the right page............
edit, looks like Pete and I were typing at the same time; shame about the price though.
Bill
Edited By peak4 on 28/07/2023 13:28:15
Bazyle28/07/2023 13:36:37
6956 forum posts
229 photos
3-phase. My mistake. I saw 3 brushes but now I look again there are 4.
Ian Parkin28/07/2023 13:44:01
1174 forum posts
303 photos
Hairy pete
it is off a longford
Ian Parkin28/07/2023 13:47:42
1174 forum posts
303 photos
That’s the type but surely there must be a cheaper replacement
Ian Parkin28/07/2023 13:52:45
1174 forum posts
303 photos
From the site hairy Pete linked to this is what i need
Unique Features of Brushed Pancake Motors
Brushed pancake motors, or printed motors and Scheibenläufermotoren as they are known in Germany, have a number of unique features that make them stand out from other electric motors:
Size
The motor is much smaller and thinner than normal iron-core motors
Rapid acceleration and deceleration
The armature is very thin giving low-inertia and exceptional torque ratios. The result is extreme acceleration with a typical pancake motor able to accelerate from 0 to 3000 rpm in only 60 degrees of rotation. To achieve rapid acceleration and deceleration printed motors can handle a peak current of up to 10 times the continuous rating which would be impossible for iron-core motors without demagnetising
Zero-cogging
Printed armature motors are the only electric motor variant in the world with no torque ripple. A conventional motor has a tendency to prefer certain positions where the magnetic alignment is best. This is called cogging and creates torque disturbances. The flat armature motor is ironless and is thus intrinsically non-cogging. This gives perfectly smooth rotation at any speed with no ripple effect. Click here for a graph that explains this
Long brush life
Because brushed pancake motors have no iron core there is minimal inductance. The result is no arcing, because there is no stored energy in the armature to be dissipated during commutation. In an iron-core motor a lot of energy is stored in the magnetic field of each coil. When this field collapses, the energy tends to be discharged by arcing to the brushes and this wears them out. Depending on the application, the brushes in our printed motors tend to last as long as the bearings.
Reliable at high speed
Brushed pancake Motors do not suffer from arcing as thus can perform reliably at very high speeds
Instant torque delivery
Another benefit of minimal inductance is that the current flows into the armature extremely quickly (in less than one millisecond). This delivers instant torque
Flat torque curve
The ironless disc motor has a perfectly flat torque curve up to very high speeds whereas iron-core motors tend to fade at high speeds. Thus a small pancake motor may be sufficient where you would have to select a much larger iron-core motor to achieve the same torque at high speed
Easy to cool
Ian Parkin28/07/2023 16:04:21
1174 forum posts
303 photos
from the machine maker its £2500
Robert Atkinson 228/07/2023 18:17:56
1891 forum posts
37 photos
What's wrong with it?
Ian Parkin28/07/2023 18:40:10
1174 forum posts
303 photos
Well it was blowing the fuse (15 amp) resistance between the leads was only 1 ohm on removing the brushes a strong smell of burnt windings..
i may strip it down next week just for a look but I don’t think these types can be rewound/repaired economically
in this machine it has to start for a preset time (sheets delivered) usually about 1 second then stop for perhaps 2 seconds then restart and do that for 12 hours a day…perhaps a better way would have been a induction motor running continuously via a clutch and brake
Edited By Ian Parkin on 28/07/2023 18:44:39
peak428/07/2023 19:08:17
2207 forum posts
210 photos
I'm sure you've looked on the web, but did you spot these folk
https://www.pmwdynamics.com/pancake-servo-motor-repair/
Good Luck
bill
Ian Parkin28/07/2023 19:18:01
1174 forum posts
303 photos
Bill
the customer needs it running asap so its up to them
they have 12 of these motors so it may be well to see how much a rebuild is
ian
