peak4 | 18/07/2023 20:33:06 |
![]() 2207 forum posts 210 photos | Our friendly courier dropped me a parcel off this morning. Everything appears to work as it should, though a clean and polish will be in order soon, but I have a query regarding focussing, as I'm no expert on microscope/telescope optics. Any thoughts about an easy solution please?
Edited By peak4 on 18/07/2023 21:02:49 |
SillyOldDuffer | 18/07/2023 21:15:21 |
10668 forum posts 2415 photos | My guess is it's meant to focus on a somewhat distant object, not close-up like a microscope. Possibly it's not meant to look down unless there's a hole on the table and the item is on the floor: normally the scope looks sideways; does it swivel through 90°? On end, with the instrument measuring height, the item could be a foot or more away. Bit like a vernier height gauge, except cross-hairs instead of a physical pointer. If it's for somewhat distant objects, 13"+ across a table, then it's probably working correctly. Dave
Michael Gilligan | 18/07/2023 21:54:24 |
![]() 23121 forum posts 1360 photos | Sorry, Bill... I can’t do it just now, but if you search the old forum threads you will find a discussion about mine. MichaelG. |
peak4 | 24/07/2023 20:45:12 |
![]() 2207 forum posts 210 photos | The postman came earlier with a second hand Union 5x objective, so now I don't have to place objects on the garden fence to view them. |
Michael Gilligan | 25/07/2023 05:10:35 |
![]() 23121 forum posts 1360 photos | Posted by peak4 on 24/07/2023 20:45:12:
[…] . Please see the penultimate post on this page, Bill: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=89940&p=2
You, of course, have the great luxury of a nice big micrometer head. MichaelG. . Edit: __ direct link to the Album: https://www.model-engineer.co.uk/albums/member_album.asp?a=29450 Edited By Michael Gilligan on 25/07/2023 05:18:16 |
Michael Gilligan | 25/07/2023 07:33:30 |
![]() 23121 forum posts 1360 photos | In case any readers not-acquainted with these instruments have missed it … Their big advantage is that [subject to the optical resolution of the lenses] they can take very small measurements at long distances. Hence the inclusion of the ‘telescope’ objective. What other arrangement would allow you to so accurately measure the size of a bolt-head from across the room ? MichaelG. |
peak4 | 25/07/2023 12:17:09 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 25/07/2023 07:33:30:
In case any readers not-acquainted with these instruments have missed it … Their big advantage is that [subject to the optical resolution of the lenses] they can take very small measurements at long distances. Hence the inclusion of the ‘telescope’ objective. What other arrangement would allow you to so accurately measure the size of a bolt-head from across the room ? MichaelG. Cheers, I had read that post; as you have spotted, mine only came with the telescope objective, and my workshop is of limited size. |
Michael Gilligan | 25/07/2023 15:26:08 |
![]() 23121 forum posts 1360 photos | Just curious … Does your 7.5x eyepiece have cross-hairs, Bill ? MichaelG. |
Ian P | 25/07/2023 16:26:36 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 25/07/2023 07:33:30:
so accurately measure the size of a bolt-head from across the room Same problem here as you highlighted in the Platinum wire thread! Ian P |
Howard Lewis | 25/07/2023 17:24:18 |
7227 forum posts 21 photos | The advantage of optics is that light beams don't sag as much as physical ones! Hence the use of lasers Howard |
Michael Gilligan | 25/07/2023 18:51:14 |
![]() 23121 forum posts 1360 photos | Posted by Ian P on 25/07/2023 16:26:36:
[…] What other arrangement would allow you to so accurately measure the size of a bolt-head from across the room ? MichaelG.
so accurately measure the size of a bolt-head from across the room Same problem here as you highlighted in the Platinum wire thread! Ian P . That’s why they were made so heavily and finely … the one shown in my Album would make a very good lathe-bed. MichaelG. |
old mart | 25/07/2023 19:11:38 |
4655 forum posts 304 photos | Another lens fitted on top of the objective would shorten the focussing distance, but what strength would have to be found by trial and error. I saw that on ebay and was tempted myself just out of curiosity, but overspent on other things and just managed to resist it. Edited By old mart on 25/07/2023 19:13:58 |
peak4 | 25/07/2023 19:23:49 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 25/07/2023 15:26:08:
Just curious … Does your 7.5x eyepiece have cross-hairs, Bill ? MichaelG. Yes, on a separate graticle retained with a threaded collar. |
Swarf, Mostly! | 25/07/2023 19:31:45 |
753 forum posts 80 photos | Is one name for this device "cathetometer" ? Best regards, Swarf, Mostly! |
Michael Gilligan | 25/07/2023 20:12:03 |
![]() 23121 forum posts 1360 photos | RMS standard eyepieces are 23.2mm ‘insertion’ diameter, or thereabouts … but of course the reticle diameter varies between types. MichaelG. |
Michael Gilligan | 25/07/2023 20:13:53 |
![]() 23121 forum posts 1360 photos | Posted by Swarf, Mostly! on 25/07/2023 19:31:45:
Is one name for this device "cathetometer" ? . A close relative, I would say. MichaelG. |
Michael Gilligan | 26/07/2023 06:55:54 |
. I thought it interesting, Ian, that you chose to not quote the question that I asked of the world in general … instead, you highlighted the potential shortcomings of this method. Fair enough … but the question remains.
MichaelG. |
Ian P | 26/07/2023 11:39:38 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 26/07/2023 06:55:54:
MichaelG. Well, I'm not good at answering questions aimed at the world in general. My point was related to you saying that the travelling microscope could 'accurately' (your words) measure a bolt head across the room. I just thought there were many factors that came between theory and practice, especially in the home workshop Ian P
Michael Gilligan | 26/07/2023 11:45:09 |
![]() 23121 forum posts 1360 photos | My words were in fact “so accurately” … which is not an absolute but a relative expression. If, just for example, it’s accuracy was +/- 5% then I was asking what else could do so well Equally if it’s demonstrable accuracy turned out to be a different percentage; the same question applies. MichaelG. Edited By Michael Gilligan on 26/07/2023 11:56:15 |
Robin | 26/07/2023 12:00:20 |
![]() 678 forum posts | I wonder if it was to align the head on an RF30?
