Dell | 11/07/2023 16:39:43 |
![]() 230 forum posts 44 photos | I have a problem that I’m hoping someone has an answer or suggestion, on my Myford 10 while using the Rocketronics els when my tool bit gets to a shoulder it jams, EG for example say I have a length of 25mm mild bright steel that I want to turn down to 10mm say over a length of 40mm, in the control I I input-40mm for Z and - 7.5mm for X , using a eccentric engineering tool the first few cuts are fine although I can hear the extra cutting up against the shoulder and with each cut the extra cut seems to get louder and the last 1mm or so before the shoulder is very rough and a Matt finish but it’s when the part is getting towards the 10mm it jams , I have checked to make sure the tool is square to headstock . |
Dell | 11/07/2023 16:41:34 |
![]() 230 forum posts 44 photos | This is what I was making. |
Ady1 | 11/07/2023 17:01:40 |
![]() 6137 forum posts 893 photos | It sounds like it's shoving itself into the corner and the flanks need more relieving Whats the angle your using? When I did the same sort of work I needed a very pointy tool, for some reason a common sense 10-15 degrees just didn't do it Edited By Ady1 on 11/07/2023 17:05:44 |
Dell | 11/07/2023 17:26:55 |
![]() 230 forum posts 44 photos | This is the tool setup. |
Tony Pratt 1 | 11/07/2023 17:36:19 |
2319 forum posts 13 photos | I presume you have a digital readout on the lathe or control, watch to see what position it is going to at each cut, that will give you a good idea what is going on, also speak to Rocketronics? You tool also needs sharpening Tony |
Dell | 11/07/2023 17:44:36 |
![]() 230 forum posts 44 photos | Posted by Tony Pratt 1 on 11/07/2023 17:36:19:
I presume you have a digital readout on the lathe or control, watch to see what position it is going to at each cut, that will give you a good idea what is going on, also speak to Rocketronics? You tool also needs sharpening Tony The readout goes to 40mm every time that tool bit has a radius corner so should I use a sharp corner ? |
bernard towers | 11/07/2023 17:51:46 |
1221 forum posts 161 photos | you are putting a high load on the length of the left hand edge of the tool if it is at 90deg to the lathe bed, you could try 89deg then when last long cut is taken, take a cut at the 40 mm dim from the outside edge to the diameter turned. |
Harry Wilkes | 11/07/2023 18:47:17 |
![]() 1613 forum posts 72 photos | Posted by Dell on 11/07/2023 17:44:36:
I presume you have a digital readout on the lathe or control, watch to see what position it is going to at each cut, that will give you a good idea what is going on, also speak to Rocketronics? You tool also needs sharpening Tony The readout goes to 40mm every time that tool bit has a radius corner so should I use a sharp corner ? Not sharp small radius is fine for that tool H
Howard Lewis | 11/07/2023 21:08:13 |
7227 forum posts 21 photos | Maybe the technique is to set the X to 39.5 mm, and as a finishing cut, to face the shoulder to length, so that the tool is moving at 90 degrees to the lathe axis, but only removing a small quantity of material down to the required diameter. Howard |
duncan webster | 11/07/2023 21:53:11 |
5307 forum posts 83 photos | What happens if you feed by hand. I'd have the angle twixt cutting face and material slightly more than 90 so that it doesn't try to cut full depth right at the left hand end |
Grindstone Cowboy | 11/07/2023 22:28:24 |
1160 forum posts 73 photos | I find having the shank of the Diamond tool set exactly perpendicular to the lathe axis gives the correct clearances for both longitudinal and facing cuts. And it does look like you need to sharpen it. Rob |
duncan webster | 11/07/2023 23:22:35 |
5307 forum posts 83 photos | Depends how old the diamond holder is, mine is fairly old and has to be set quite a way off. This was some compromise to do with screw cutting. It's also a d*mned nuisance |
Dell | 12/07/2023 10:55:50 |
![]() 230 forum posts 44 photos | Thanks for all the replies and suggestions,The tool holder is less than 6 months old and I put the finished part in to chuck so I could take a picture of it with tool up against the shoulder and I can see I have more clearance one side and not much near the shoulder. Dell |
Tony Pratt 1 | 12/07/2023 14:08:12 |
2319 forum posts 13 photos | Dell, looks to me like there is enough clearance on the shoulder side. Tony |
