Niels Abildgaard | 29/06/2023 19:15:52 |
470 forum posts 177 photos | Some austrians try to take over the market for catalyzed IC driven generators for hybrid cars. It is a two-cylinder two -stroke but not like the famous Trabant where crankcases blew the cylinders with fresh charge. It is claimed that exhaust can only be catalyzed ,if fresh charge come from blowers separated from crankcase. Crankcases are full of oil and slidebearings like fourstrokes . Why? |
DiogenesII | 29/06/2023 19:42:22 |
859 forum posts 268 photos | ..because unburnt fuel / oil in catalyst can cause damage from exothermic reaction, maybe? Total scavenge is necessary? |
mgnbuk | 29/06/2023 20:09:54 |
1394 forum posts 103 photos | Post reunification, aftermarket catalyic converters were made for Trabants. IIRC they had a working life of around 50,000 Km |
Niels Abildgaard | 29/06/2023 20:32:06 |
470 forum posts 177 photos | Hello Diogeness and MZ-adorer mgnbuk. I forgot to mention that it is a three-way catalyst with a Lambda senor. The philosophy is they run the thing with a pme of only 6 bar or ca half theoretical full charge. With longitudinal scavenge no unused oxygen escapes during scavenging and cannot disturb lambda measurement. Unburnt fuel is low on both scavenge schemes and with no fuel in crankcase the oil content in exhaust is not vastly different I think? |
duncan webster | 30/06/2023 00:44:27 |
5307 forum posts 83 photos | As far as I can tell, it has some kind of blower instead of crankcase induction, and exhaust poppet valves instead of ports in the wall so you get better scavenging. It should work, but whether it's better than a 4 stroke is beyond my pay grade. It has swapped 2 inlet valves for a blower, so is it that much simpler? |
DiogenesII | 30/06/2023 06:35:52 |
859 forum posts 268 photos | Maybe the blower /catalyst statement is just marketing speak, if you are going to make a 'green' engine you cannot oil it by total-loss, it has to re-circulated, and if if it has to be compact and look 'clean' under a modern bonnet you will want to wet-sump it - and if you cannot squeeze the charge under the pistons you need a blower - maybe they just think this is too long-winded and prosaic to explain to customers.. ..'though all this will have occurred to you already maybe, Niels..? Edited By DiogenesII on 30/06/2023 06:36:33 |
Niels Abildgaard | 30/06/2023 07:57:54 |
470 forum posts 177 photos | Posted by duncan webster on 30/06/2023 00:44:27:
As far as I can tell, it has some kind of blower instead of crankcase induction, and exhaust poppet valves instead of ports in the wall so you get better scavenging. It should work, but whether it's better than a 4 stroke is beyond my pay grade. It has swapped 2 inlet valves for a blower, so is it that much simpler? Somewhere it is written that they intend the twin 2-stroke to run at a mep (mean effective pressure) of 6 bar and have a maximum pressure of 45 bar. A fourstroke with well engineered inlet tract can run 12 bar mep and ca 75 bar maximum. Same power from same cylinder volume.Which is lowest mass? |
Niels Abildgaard | 30/06/2023 08:22:25 |
470 forum posts 177 photos | Posted by DiogenesII on 30/06/2023 06:35:52:
You have some points. It is also complicated by being two-cylindered with a lot of gearwheels ,whirling counterweigths,camshaft etc. I have tried to compare size for a valveles VeloSolex with a coresponding sidevalved version and both crankcase scavenged. One sealing ring will do The Austrian need many more to seal two separate crankcase pumps from oil for gear and cams and bearing. Edited By Niels Abildgaard on 30/06/2023 08:25:11 |
Niels Abildgaard | 30/06/2023 08:26:50 |
470 forum posts 177 photos | The crankcase scavenged has a volume/packaging advantage
Edited By Niels Abildgaard on 30/06/2023 08:38:31 |
mgnbuk | 30/06/2023 14:43:27 |
1394 forum posts 103 photos | MZ-adorer mgnbuk Guilty as charged, Niels ! Though I did actually sell one last year (an ES150/1 ) that I finally admitted to myself would never get rebuilt by me. That means that I only have 5 at the moment - and a couple of those may be getting moved along to someone more likely to put them back on the road than I am. I did have a Trabant at one point & got it running without too much difficulty after it had been stood outside for many years, but at the time didn't have the time sort it's many structural body issues - the non-corroding Duroplast panels were only the outer cosmetic panels - so that found a new home as well. The return of "modified" 2T engines has been mooted before & seemed to hold great promise at the time - remember the Orbital engine ? Two stroke motorcycles are actually still available today - see KTM motocrossers And until fairly recently Aprilia (Piaggio Group now ) were working on a direct injected small two stroke for scooters, but that seems to have gone quiet. Nigel B Edited By mgnbuk on 30/06/2023 14:43:47 |
duncan webster | 30/06/2023 22:23:01 |
5307 forum posts 83 photos | 2 strokes with improved scavenging and external blowers are not new, see split single, and of course the wonderful Deltic engine, not forgetting the TS3 |
Niels Abildgaard | 01/07/2023 05:44:54 |
470 forum posts 177 photos | Posted by duncan webster on 30/06/2023 22:23:01:
2 strokes with improved scavenging and external blowers are not new, see split single, and of course the wonderful Deltic engine, not forgetting the TS3 Three dead ends Edited By Niels Abildgaard on 01/07/2023 05:45:28 |
Michael Horner | 01/07/2023 07:35:31 |
229 forum posts 63 photos | I guess this make 4 dead ends as well?Lotus omnivore efficient two-stroke engine | Motoring ...Dec 11, 2009 · Lotus omnivore efficient two-stroke engine - DP Ford were working with a company called Orbital in the early 90's on a 1.2 litre two stroke, three cylinder engine for the Fiesta and... Cheers Michael |
duncan webster | 01/07/2023 14:03:14 |
5307 forum posts 83 photos | Posted by Niels Abildgaard on 01/07/2023 05:44:54:
2 strokes with improved scavenging and external blowers are not new, see split single, and of course the wonderful Deltic engine, not forgetting the TS3 Three dead ends Edited By Niels Abildgaard on 01/07/2023 05:45:28 I didn't say they were a lost opportunity, just that the Austrian proposal that started this thread off is nothing new. The EMD diesels beloved of USA railroads were blower charged 2 strokes, but they had exhaust valves in the cylinder head. I think even they have moved to 4 strokes |
Niels Abildgaard | 01/07/2023 18:18:43 |
470 forum posts 177 photos | Posted by duncan webster on 01/07/2023 14:03:14:
2 strokes with improved scavenging and external blowers are not new, see split single, and of course the wonderful Deltic engine, not forgetting the TS3 Three dead ends Edited By Niels Abildgaard on 01/07/2023 05:45:28 I didn't say they were a lost opportunity, just that the Austrian proposal that started this thread off is nothing new. The EMD diesels beloved of USA railroads were blower charged 2 strokes, but they had exhaust valves in the cylinder head. I think even they have moved to 4 strokes The Austrians claim that they can make a two stroke spark ignited than can use a three way catalyst. This is done by longitudinal scavenge and around half the possible charge. Doing this using valves in head has been tried by most. car makers but not with sidevalves that make a very compact layout possible. I try to find prior writing than my describtion in dec 2014 HMEM to convince my daugthers in law that they have not married completely useless no brainers. There are other possible explanations when grandchildren underperform.
Edited By Niels Abildgaard on 01/07/2023 18:20:28 |
Mark Rand | 01/07/2023 21:33:56 |
1505 forum posts 56 photos | Blown two stroke engines could be a very good idea in modern vehicles. With current technology they could be turbocharged, with an AC motor driving the blower at low loads and extracting surplus power from the turbine at higher loads. |
Brian G | 01/07/2023 22:11:16 |
912 forum posts 40 photos | Stepped piston two strokes also offered a conventional bottom end whilst avoiding the complication of a separate charge compressor. Bernard Hooper Engineering Brian G |
Jon Lawes | 02/07/2023 09:19:54 |
![]() 1078 forum posts | The ford Ka was intended originally to have a very innovative two stroke engine, but legislation insisted that they put a catalyser on it. They couldn't get it to work effectively and blew their budget and time constraints, so the antique kent engine went into it instead. Apparently an overhead valve engine wouldn't fit under the tightly sloping bonnet. Source; ex-ford designer at a Haynes Museum display. |
Niels Abildgaard | 02/07/2023 09:32:36 |
470 forum posts 177 photos | Comparasion of packaging
Left One way oil crankcase scavenging
Rigth Wet sump lots of oil Upper Austrian with electric blower Edited By Niels Abildgaard on 02/07/2023 09:33:35 Edited By Niels Abildgaard on 02/07/2023 09:35:27 |
paul Longley 1 | 02/07/2023 16:32:59 |
10 forum posts | The Kadenacy patent engines come to mind whenever two strokes without crankcase scavenging are mentioned. Petter reputedly came across the concept whilst testing the diesel version of their established two strokes with crankcase scavenging, the diesel was test running but with lower power output than previously when it was realised the crankcase inspection door was not fitted. This gave rise to their Harmonic engine range of two stroke diesel naturally aspirated engines. However General Motors threatened legal action as they already held patents for that system, so a settlement was reached where Petter took a license for supercharged two stroke ( linear) inlet in cylinder lower end and exhaust valves in head, as GMC Detroit Diesels were. All this was pre war. Wet case non scavenging two strokes are very long established. The surprise is being a side valve, compromising the combustion chamber shape normally reduces thermal efficiency, but perhaps an affordable penalty for the sake of installation. Certainly, using valves allows a degree of internal exhaust gas retention helping emissions. Perhaps the loss of controlled inlet valves ( allowing variable induction stroke or compression pressure) is made up for by combinations of hybrid transmission allowing the engine to operate at constant load, and the exhaust valves retaining measured quantities of exhaust gas to maintain compression rates with lower induction capacity when required. Certainly an interesting engine.
