Can I fix or will Mr Schlesinger stop me?
Iain Downs | 10/06/2023 18:56:25 |
976 forum posts 805 photos | I recently turned a 50mm long 'pipe' in steel with an external diameter of 20mm and internal bore of 16mm. Both inside and outside were around 0.02mm or so narrower at the chuck end. I particularly wanted this to be highly accurate, particularly the inside as I wanted to press bearings in. I managed to get some approximation of what I wanted with the aid of some wet and dry, but this wasn't really ideal. I had to wait for a new test bar as my existing MT3 test bar had rusted rather nastily. What I found was that the test bar did in fact lean away from the cross slide by around this factor. This seemed independent of the rotation of the test bar. When I bought the lathe (a 7x14 Real Bull CJ18A from now defunct SPGtools), it was suggested that I could align the spindle by 'nipping up' the bolts which hold the headstock on. I've done this previously when relacing the spindle and this does seem to have some effect. My questions are:- Should I be able to get better alignment with my mini lathe (Mr Schlesinger and so on) Is nipping up / freeing the headstock botts the best way to do this? I ask these questions as I'm not particularly keen on stripping down the lathe if I'm not going to be able to fix this. I look forward to your help!
Iain |
Clive Brown 1 | 10/06/2023 20:14:25 |
1050 forum posts 56 photos | I do not have experience of this particular machine, bur adjustment of the headstock bolts is unlikely to improve the alignment IMO. The more usual method of improving the alignment of a small lathe is to shim or otherwise adjust the bolts holding the lathe down to its stand. This is often misleadingly called "levelling". The idea is to remove twist from the bed. Search this forum, there have been a number of threads describing the method. |
Iain Downs | 10/06/2023 21:06:22 |
976 forum posts 805 photos | HI, Clive. The lathe is rather small and is not secured to the bench. There's no particular way of doing that - not straightforwardly anyway. I can try applying some shims or such and see if it makes any difference. Thanks
Iain |
old mart | 10/06/2023 21:25:59 |
4655 forum posts 304 photos | 0.02mm in 50mm is not much. When you put a testbar in the chuck, even a rusty one, does it run true over at least 75mm, measured with an indicator on the cross slide? The spindle would have to be rotated by hand during the test. If that is not going to work, then an actual cut with a decent size bar, say 25mm steel or aluminium with about 80mm sticking out of the chuck. Both ends should be the same if the spindle is in line with the bed. Leaving the turned bar in the chuck, the headstock bolts can be slackened off and with the indicator, half the error taken out before retightening the bolts. This is trial and error, another skim should prove the results. The only headstock that I have taken off was not adjustable at all. I took the headstock off the museum's Smart & Brown model A when wanting to remove the spindle and found it was fitted to the prismatic bedways and line bored to the bed during manufacture. It only needed cleaning and bolting up to be perfectly aligned. Now I know how, I can remove the spindle in 15 minutes without touching anything else. |
Huub | 10/06/2023 23:20:56 |
220 forum posts 20 photos | I also can't bolt my mini lathe (HBM DC300) down to the table so I can't align the head stock by shimming. I have taken the head stock of the bed and scraped/sanded the seating of the head stock so that it aligns OK (0.015 mm/100 mm). It took me a day to do it. That is however not easy to do because to remove the head stock, the electronics, gears and motor have to be removed first.
Andy_G | 10/06/2023 23:59:37 |
![]() 260 forum posts | Posted by Iain Downs on 10/06/2023 21:06:22:
The lathe is rather small and is not secured to the bench. There's no particular way of doing that - not straightforwardly anyway. I also have a CJ18A 7X14 lathe (from Amadeal). Tweaking the headstock bolts shouldn't do anything if it is properly bolted down. You can easily correct that level of error by shimming the mounting 'feet'. (You can easily induce a much greater error, too!) The lathe can be secured from below, using the tapped mounting holes for the rubber feet. I used a length of rectangular hollow steel and filed / sanded it until it contacted all 4 feet. A piece of 0.0015" shim under one foot was needed to true it up. If you are interested, I described the process (and its effect) here: (The parting off at the end was very tentative because of previous problems that I'd had - I would go a lot quicker now!) Edited By Andy_G on 11/06/2023 00:09:49 |
Chris Mate | 11/06/2023 09:01:13 |
325 forum posts 52 photos | Lathe:The 360 degrees thing: Your cutter positioned but not turning, the work turns. |
Iain Downs | 11/06/2023 10:43:32 |
976 forum posts 805 photos | Thanks for the responses, guys. Old Mart I *think* that this is what I was hoping would work, but as Huub says, it's a bit of a pain to do. I will give that a go, though. Andy - that was very interesting. Did you check the trueness of the lathe after the work? I see that you'd checked that it was the same after bolting as before, but that assumes that the bed was in true to start with. That's something I will have to consider, probably later as I don't have the stock for that and my welding skills are ... dubious! In passing, my parting off has been much better since I changed the guides for the cross-slide under the bed. Teh replacements are brass and somewhat heavier than the original bars. I found this on a you-tube video, but can't recall which one other than that the author had a distinctive nasal voice. 20mm mild steel seems quite reliable these days even at higher speeds. Having said that sometimes it doesn't work for no apparent reason! Chris, If I've understood your question correctly, the diagram below might help.. The angled rectangle is the bar in a chuck which leans away from the operator. Left hand side is the chuck end. Note that the chuck is in line with the spindle and the bar rotates around its axis. the bottom horizontal lines represent the travel of the cutter. the lower one is the outside, then inner the bore. The dotted lines are what the travel would be on the other side of the bar..It's a bit hard to see, but if you tilt your head so that the bar is horizontal you will see what I mean. Thus the part near the chuck is narrower (inside and out) than the end. Hope that makes sense!
Iain |
Andy_G | 11/06/2023 11:30:59 |
![]() 260 forum posts | Posted by Iain Downs on 11/06/2023 10:43:32:
. Did you check the trueness of the lathe after the work? I see that you'd checked that it was the same after bolting as before, but that assumes that the bed was in true to start with. That's something I will have to consider, probably later as I don't have the stock for that and my welding skills are ... dubious! Yes - I knew it was turning parallel before I started, so didn’t want to alter anything too much. It’s within about 0.01 mm over 100mm so I’m not inclined to mess with it. I wouldn’t bother with welding - just get hold of a length of rectangular hollow section steel - I only resorted to welding to use what I had around. |
Iain Downs | 11/06/2023 12:43:53 |
976 forum posts 805 photos | Thanks, Andy. A trip to the scrapyard may follow! At the moment, I have the lathe in bits with the headstock off. Nipping the bolts had no positive effect, though I could make things worse by loosening some bolts - particularly the front right one. My first attempt is to make sure that the surfaces are all clean and deburred. I thought I did this before, but who knows? As the deviation is about 0.03 over 50mm and the headstock is 100mm long, I should need a .06mm shim (in total - two 0.03 might be better). If the deburring fails I will try that before trying to get clever with filing and sanding.
Iain |
Hopper | 11/06/2023 15:42:28 |
![]() 7881 forum posts 397 photos | If you are going to bolt it down to a solid steel base as per the video, you might be best off to set it to turn parallel as he did by shimming the tailstock feet to get it to turn parallel. Standard procedure on many lathes, including Myfords. See Myford manual pages below. See the bottom of the first page. Saves risking doing irreparable harm to the headstock mounting.
Iain Downs | 11/06/2023 16:22:50 |
976 forum posts 805 photos | Hi, Hopper. I tried lifting the corners of the splash tray on which the lathe is bolted, which should have had the effect of twisting the bed - at least a little. In fact this had little effect on the alignment. Since then I've removed the headstock and applied some shims (aluminium foil turns out to be 0.01mm in width) which has considerably improved the alignment. It would seem that the alignment bar isn't quite as perfect as the advertisement indicated, so I'm not quite sure how good yet, but probably between 5 and 10 microns over 50mm. I'm sitting here wondering if an extra shim might bring it even better or to leave well enough alone... Next step (tomorrow) is to put it back together and take a test cut. I will report.
Iain
Hopper | 11/06/2023 17:06:04 |
![]() 7881 forum posts 397 photos | Posted by Iain Downs on 11/06/2023 16:22:50:
Hi, Hopper. I tried lifting the corners of the splash tray on which the lathe is bolted, which should have had the effect of twisting the bed - at least a little. In fact this had little effect on the alignment. As flexible as the bed appears to be in the video above, I would expect a splash tray would flex before the bed would. |
SillyOldDuffer | 11/06/2023 18:22:58 |
10668 forum posts 2415 photos | Posted by Iain Downs on 11/06/2023 12:43:53: ... As the deviation is about 0.03 over 50mm ... Just a thought, but have you confirmed the pipe isn't bending under cutting pressure? Long jobs bend most when cutting furthest from the chuck where the cutter tends to remove less metal than the lathe dial suggests. The dial is more likely to be right close to the chuck where the job is well-supported. In this demo, I bent a 150 long length of ⌀20mm solid aluminium rod 0.08mm off-axis just by pushing it hard with my finger: A cutter driven in by the cross-side screw is much more forceful. I managed to bend the rod nearly 3mm off-axis before getting scared I might damage the nut: Not a good picture next - I couldn't hold the rule and camera accurately enough to highlight the whole curve. But laying a rule along the rod with a light underneath shows the rod is bent: I notice work starts to bend when turning anything more than about 3x diameter long beyond the jaws, worse when taking heavy cuts with carbide. Anything over 6x diameter in length is likely to bend under its own weight and has to be supported - tailstock, steady or lump of wood. Dave
Edited By SillyOldDuffer on 11/06/2023 18:25:31 |
Iain Downs | 11/06/2023 18:35:54 |
976 forum posts 805 photos | Hi, Dave. I'm pretty sure that it's not the pipe bending. Mainly because the MT3 test bar shows a deflection pretty close to what I measured with the 'tube'. The tube started off as 27mm mild steel (EN1A possibly Pb) with a stick out of about 60mm. The inside was bored to 16mm and then the outside cut down to 20mm. During the outside turning, I checked diameter with a micrometer at several places and fairly often and it was consistently showing smaller at the chuck end. So I'm fairly sure it's the alignment. After I've turned a new tube tomorrow, I can let you know the good news or admit I'm an idiot and the problem is elsewhere!
Iain |
Niels Abildgaard | 11/06/2023 19:15:07 |
470 forum posts 177 photos | All my lathes have been put solidly (bolted to) a solid foundation before I started to worry about accuracy |
Chris Mate | 11/06/2023 19:43:36 |
325 forum posts 52 photos | When I got my 330 Lathe new, it came with a metal stand not Cast Iron, and was given advice to lift it like 200mm. Edited By Chris Mate on 11/06/2023 19:44:41 |
Michael Gilligan | 11/06/2023 20:14:29 |
![]() 23121 forum posts 1360 photos | Posted by Iain Downs on 11/06/2023 18:35:54:
Hi, Dave. I'm pretty sure that it's not the pipe bending. Mainly because the MT3 test bar shows a deflection pretty close to what I measured with the 'tube'. […] . Perhaps worth noting Dr Schlesinger's approach to test bars [mandrels] … it’s clearly described on p5 of the book. MichaelG. . Edited By Michael Gilligan on 11/06/2023 20:19:29 |
Hopper | 12/06/2023 03:41:18 |
![]() 7881 forum posts 397 photos | Posted by Chris Mate on 11/06/2023 19:43:36:
When I got my 330 Lathe new, it came with a metal stand not Cast Iron, and was given advice to lift it like 200mm. Edited By Chris Mate on 11/06/2023 19:44:41 As the video posted above shows, the minilathe bed is about as flexible as a wet noodle if not bolted down to a solid base. But 12mm flat plate can be quite flexible, by precision engineering standards, especially if perched on top of the type of sheet metal cabinet supplied with many lathes. A stout box construction of square tube or angle iron is more solid than flat plate. The trick to bolting down a lathe to a solid base, which seems to be universally forgotten, is shown in the Myford manual pages above. You don't surface grind the bench or base to be flat, You measure any gaps when the lathe is sitting loose on the base and insert shims so you don't distort the lathe when tightening the bolts. I think if Myford recommends using shimming the bed feet to achieve parallel turning, you can rely on their hundred years or so in the lathe manufacturing business I have to say I am astonished at how flexible the minilathe bed is in this video, as measured with a DTI.
Michael Gilligan | 12/06/2023 06:18:48 |
![]() 23121 forum posts 1360 photos | To massively reduce the inevitable flexibility … Niels Abildgaard has the practical solution: his tablet of stone !! [ that steel box section is a very good runner-up though ] MichaelG. Edited By Michael Gilligan on 12/06/2023 06:29:14 |
