JasonB | 01/06/2023 18:07:54 |
![]() 25215 forum posts 3105 photos 1 articles | Looks like they would work quite well in a between ctrs boring bar |
Emgee | 01/06/2023 18:36:58 |
2610 forum posts 312 photos | I used the short type in a cross drilled hole in the 5/8" toolholder of a Dore boring and facing head, tool bit secured with a grub screw in the end of the bar, or if the tool is angled to reach the bottom of a blind bore the securing screw was at 90 degrees to the toolbit. Emgee Edited By Emgee on 01/06/2023 18:37:32 |
Clive Foster | 01/06/2023 20:20:29 |
3630 forum posts 128 photos | +1 for Emgee Ages ago i was given a small baccy tin full of similar cutters in both HSS and carbide. Donor said "You will find these handy as you have a small boring head." Presumably meaning they could be used as Emgee says in a shank with suitable cross drilled hole. If I ever find the need I shall make a shank. Clive |
Hollowpoint | 01/06/2023 22:04:33 |
550 forum posts 77 photos | I think you might be right. For that type of boring head or line boring. Thanks. |
Neil Wyatt | 02/06/2023 17:03:37 |
![]() 19226 forum posts 749 photos 86 articles | Sincere apologies! For some unfathomable reason the post got reported. I accidentally pressed the wrong button and deleted the post not the report. I don't know if Hollowpoint could replace the image? Sorry for the inconvenience. Neil |
JasonB | 02/06/2023 17:12:12 |
![]() 25215 forum posts 3105 photos 1 articles | I've put it at the top |
old mart | 02/06/2023 19:02:56 |
4655 forum posts 304 photos | They do look like the old style boring bar bits. And there is a toolholder for turning laying about in the workshop which holds something similar. Edited By old mart on 02/06/2023 19:05:33 |
