Chris Hill 1 | 20/05/2023 18:43:02 |
5 forum posts | Hello. New member here. Ive been browsing for a while picking up some good information. Ive got a denham juniour mk 2 lathe that i recently acquired. I would like some help with the headstock bearings. The chuck has play in it. Does anybody know where i can bet a manual for it or what type of bearings are insidd. Thanks |
Thor 🇳🇴 | 21/05/2023 07:21:35 |
![]() 1766 forum posts 46 photos | Hi Chris, Welcome to the forum. You should be able to buy a manual from lathes.co.uk. Denham lathes has been discussed before, see here. May be this can be of help? Thor |
DiogenesII | 21/05/2023 07:57:10 |
859 forum posts 268 photos | Thor types faster than me... According to Tony Griffith's Lathe and Machine Tool Archive Lathes.co.uk - Denham both ball or roller bearings can be found in the MKIIs.. Adjustment is usually simple in principle, but can differ in correct procedure from lathe to lathe - hopefully someone more intimately familiar with these machines will confirm the detaills. I see that Tony can supply manuals, you could also try a 'wanted' ad here or search the 'net. Edited By DiogenesII on 21/05/2023 07:57:50 |
Chris Hill 1 | 21/05/2023 09:37:38 |
5 forum posts | Hello. Thanks for the replies. I will have a look at lathes .co.uk and will have a look through the forum. I think it is going to be a learni g curve. Thanks for the help |
Rockingdodge | 21/05/2023 10:10:40 |
![]() 396 forum posts 111 photos | Chris, check your ibox for a message re manual Regards Roger |
noel shelley | 21/05/2023 10:22:59 |
2308 forum posts 33 photos | Hi Chris, Search the net first ! The lathes.co site is a huge resorce of information but having bought a Centec manual at a considerable cost I found most of what I had got was old averts Etc, great if I was a historian, but nothing else that was NOT available free else where on the net. What I got was nicely printed on good paper but from the point of being a user manual a bit thin ! Noel. |
Chris Hill 1 | 21/05/2023 19:53:47 |
5 forum posts | Hello. Thanks again for all the replies and help. |
Chris Hill 1 | 27/05/2023 07:51:54 |
5 forum posts | Hello. All. Ive started to down the lathe headstock thanks to being able to get a manual. I think ive traced the problem to the 2 angular contact bearings in the head. Only problem is they are very expensive to replace. |
