Dalboy | 06/05/2023 11:14:43 |
![]() 1009 forum posts 305 photos | I am thinking ahead as much as I can. Just put an order in for some cutters for the Farm boy as well as one for the rob roy later on. (they did not have the size I wanted) With the farm boy I need to round over some of the edges on the Ali parts of the build, would it be possible to use a wood router bit for this operation I have some HSS ones as well as TCT tipped ones. If this is possible it will save having to order from a different company yet again. It just seems as when ordering bits and pieces I have to order from many different companies instead of ordering from just one. I know Arceuro have a metric cutter which would do the job so if push comes to shove I will order that one but that will be yet another postage cost just for a small item. I do try to reduce postage and bulk things together. Edited By Dalboy on 06/05/2023 11:15:31 |
Chris Evans 6 | 06/05/2023 11:22:55 |
![]() 2156 forum posts | I have successfully used a tct router cutter for corner rounding on Aluminium and Cast Iron. High spindle speed and don't get greedy with the depth of cut. |
Baz | 06/05/2023 11:30:40 |
1033 forum posts 2 photos | Only difference between a router bit and a proper corner rounding cutter is the shank diameter, as Chris says use a high spindle speed and take it gently. Both carbide and HSS ones work equally well. |
Bo'sun | 06/05/2023 11:34:26 |
754 forum posts 2 photos | Give it try. What's to lose? (apart from a router bit of course). I'm guessing the carbide insets in woodworking bits might be a bit thinner, and maybe not as well supported. I'd try it with 1//2" shank bits if you can, for increased rigidity if nothing else. As Chris suggests, take it easy. Good luck and let us know how you get on. |
Dalboy | 06/05/2023 11:34:49 |
![]() 1009 forum posts 305 photos | Thank you Guys. At the moment this is the only job I need it for |
JasonB | 06/05/2023 13:15:35 |
![]() 25215 forum posts 3105 photos 1 articles | I've done it several times. The only thing you have to watch is that if you are working into an internal corner then the generally larger diameter of a router bit won't get into the corner as far. Diameter of cutter also determines speed so a router bit would generally need to run slower than the smaller dia of your typical milling cutter but a sit is aluminium you should be able to give it some beans. |
Dalboy | 06/05/2023 13:56:41 |
![]() 1009 forum posts 305 photos | Posted by JasonB on 06/05/2023 13:15:35:
I've done it several times. The only thing you have to watch is that if you are working into an internal corner then the generally larger diameter of a router bit won't get into the corner as far. Diameter of cutter also determines speed so a router bit would generally need to run slower than the smaller dia of your typical milling cutter but a sit is aluminium you should be able to give it some beans. Part of what needs cutting I will need to stop short anyway and finish those by hand and blend them in |
