Sieg SX2.7L tramming advice?
Gordon B28/04/2023 19:31:40
11 forum posts
11 photos
I've recently acquired a Sieg SX2.7L clone, which I believe was built in 2019. The first job I ended up needing it for was fly cutting, with a large diameter (approx 13cm / 5". I noticed that the cutter was taking more material on the trailing edge; which I understand would indicate the machine is slightly out of tram.
I first checked the spindle runout with a DTI touching an MT3 ER collet mounted in the spindle (see image below). This showed 0.004mm of runout, so I'm assuming this is not of concern.
Next I clocked the spindle across the length of table. Two indicators approx 150mm (6" apart, set to 0 when facing away from me.
Turning the spindle 180 degrees shows around 0.015mm of deviation. As the left side of the table is low, right side high; I assume this means the column is tilted slightly to the right.
I then took the same measurement across the width of table. That appears to show that the front of the table is high and the rear is low (by approx 0.06mm to 0.08mm). I assume this means the column is also tilted forward.
However, I next swept a rod in the spindle along a DTI by raising the mill head up the column. As the head rose, the DTI reading dropped (rod moving away from the DTI) by 0.1mm over a distance of about 43mm of vertical travel.
If I understand correctly, if just the column were out of square this reading would not change (see below for a very out of square column, with the head moving up, but the rod-to-DTI distance remaining constant).
However, it would change if the head were nodded forward on the column; e.g. for a very out of square head, with the rod-to-DTI distance increasing as the head moves up the column.
I repeated this test with the DTI to the side of the rod, and it showed essentially no change when the head was raised up the column; so I assume this means the head is not tilted left/right, and the 0.015mm deviation across the length of the table must be down to the column alignment.
Assuming I'm taking the above measurements correctly (do tell me if I'm not), it looks as though the main/first issue is the nod on the head. How do I (can I?) correct the head nod on this machine?
BTW for all tests so far the spindle has been fully raised; I'll check it once the head/column looks OK.
JasonB28/04/2023 20:49:57
Look at the head taper gib for a start if you feel it is the head nodding on the column, make sure both screws are in contact with the gib strip ends
Out of interest have to clocked the end of that rod to see if it is running true that far out of the collet chuck?
Edited By JasonB on 28/04/2023 20:51:56
Gordon B28/04/2023 21:32:09
11 forum posts
11 photos
Good point - I haven't checked if that gib needs snugging up. I'll look at it in the morning; many thanks.
That rod isn't actually running particularly true, but it was clearer for the photos. I ended up taking measurements on the rod for the tool that holds the two clocks; which is much closer to true. I did also repeat the measurements after rotating the spindle by 180 degrees; which I assume would have reversed the error if it were actually down to the rod being bent?
Gordon B29/04/2023 15:38:16
11 forum posts
11 photos
Jason - I think tightening the gib has helped. I removed the gib screw for the vertical axis and confirmed that the head does make contact with the gib wedge. I then tightened it until I can just feel a little drag when raising and lowering the head on the column.
With a DTI mounted on the table and a rod in the spindle I raised and lowered the head again. Rotating the spindle 180 degrees and repeating measurement was pretty consistent; so I assume the rod is straight. That gave me a reading of just under 0.08mm over 100mm of column travel. My earlier measurement of 0.1mm over 43mm would equate to 0.23mm over 100mm; so it's certainly improved.
If I read the inspection record for the mill correctly, it claims 0.10mm over 100mm; so I'm within the claimed spec. Whether that's "good enough" for a home mill I've no idea.
Putting the DTI on the spindle then sweeping it around the table indicates the front to back height discrepancy is under 0.01mm over a sweep diameter of 130mm. Given that the inspection record claims 0.03mm over 100mm I can't complain.
From that same test I appear to now have about 0.03mm discrepancy (over the same 130mm diameter) from the left to the right. Again that's within the claimed spec (0.03mm over 100mm), but I might risk torqueing the column bolts to see if I can reduce it a bit, then I'll check the spindle squareness.
Overall though, I guess that's starting to look acceptable for a budget home mill. I don't really know what is "good" for this class of machine. Is there a general rule of thumb for how well trammed a machine needs to be to achieve a good fly cut finish (for a certain diameter of fly cutter sweep)?
JasonB29/04/2023 16:09:25
You were probably swinging a cutter that is quite a bit larger than a 2.7 is meant for which will have magnified any errors. With these machines it is always a juggling act to get the three things exact - tram of spindle around table - head movement and quill movement. Add in the fact it will probably change a bit depending on what axis are locked and the loading on the machine means you are unlikely to get all three spot on.
Main thing for good flycutting is how the spindle is when you swing the dti around the table, get it good and you end up with a hologram effect but some prefer a slight lean to one side that just gives arc shaped cutter marks
You say gib screw, there is a second one that should bear against the opposite end, if it does not you can find the gib moves up and down as the head is raised and lowered making it tighter as it is raised and looser when lowered so make sure that is snugged up too
Gordon B29/04/2023 22:06:48
11 forum posts
11 photos
Definitely was a big fly cutting diameter; around 130mm total.
I was going to say that I couldn't see a second gib screw, but checking the manual the parts diagram indicates there is one present - but I think it's hidden under a plate on the bottom of the head, so I'll take a look tomorrow.
You're right about locking an axis having an effect; I swept a DTI around the table with and without the vertical axis locked, and it measurably causes the head to twist slightly. However, just moderately locking the axis results in a pretty good reading; around 0.01mm over 130mm across the length of the table, and 0.006mm across the width. I'll take that.
I tried to check the spindle for squareness but I'm not sure that my cheap 123 blocks are that square. Regardless, the worst I saw was under 0.03mm of deviation over the 70mm spindle stroke. Again if I read the inspection report correctly that's within the claimed tolerance so I can't complain.
JasonB30/04/2023 06:53:51
Yes the bellows to plate will need it's two small screws undoing so it can be slid down the column to access the bottom gib adjuster.
not done it yet30/04/2023 11:53:46
7517 forum posts
20 photos
Any out-of-tram will result in a curved surface finish, to some extent. JB’s hologram finish is the ideal.
Pillar-tilt should be cheched when the head is locked to the column, too?
JasonB30/04/2023 13:02:49
I've always wondered why the Myford fans say a concave surface when facing is desirable bit not on a milled surfacedevil
mgnbuk30/04/2023 13:12:21
1394 forum posts
103 photos
Why single out "Myford fans" Jason ? sad
Surely it is normal accepted practice for all lathes (irrespective of maker) to face on the silgtly concave side of dead flat ?
Nigel B.
JasonB30/04/2023 13:33:07
It is the only lathe that I have heard it mentioned about on this forum, hence why I mentioned it
But still the question of why is it OK on a faced part but seen as undesirable on a milled one?
old mart30/04/2023 16:07:39
4655 forum posts
304 photos
As already mentioned, the gibs have some affect and it might be useful to check any differences made when locking the movements. The double testing at 180 degrees should give identical results even if the tramming device is not perfectly straight. With a shorter tramming spindle you could repeat the tests with the head lower.
Edited By old mart on 30/04/2023 16:10:46
DiogenesII30/04/2023 16:45:17
859 forum posts
268 photos
Posted by JasonB on 30/04/2023 13:33:07:
..probably explains why Myford put a swivel on the bottom of their milling slide...
Robert Butler30/04/2023 17:58:03
511 forum posts
6 photos
Jason, I've read somewhere it is to avoid a component which sits on a flat surface from rocking. I also recall that the amount was miniscule and definately with reference to Myford only.
Robert Butler
Martin Connelly30/04/2023 18:19:20
2549 forum posts
235 photos
Had a look through this thread for the first time today. Couldn't see any mention of this. It is not usual to put a round rod in the mill and move it up and down as any out of tram will result in the DTI giving unpredictable readings as it moves around the curved surface. As a result I advise you do what is more usual. Put the DTI in the spindle and move it over a vertical plane surface (angle plate or 123 blocks for example) on the mill table. Rotate the vertical surface 180° and repeat in case the surface is not perfectly vertical. Average out the two readings unless they are the same.
Martin C
JasonB30/04/2023 18:20:35
Yes I understand it is to stop things rocking so why desirable to not have a turned item rock but seems undesirable for milled surfaces not to rock?
Gordon B30/04/2023 21:06:59
11 forum posts
11 photos
Posted by JasonB on 30/04/2023 06:53:51:
Got it - thanks. Fiddly to get to. It's slightly disconcerting that if I remove that bottom screw and then wind the top screw in (so it pushes the wedge gib a long way down) I can still raise and lower the column. I would have expected that at some point it would have locked the column movement?
I've put it back together, albeit with the wedge gib a little lower than it was before. I'm still seeing around 0.08mm deviation with 100mm vertical column travel though. Tomorrow I'll try Martin Connelly's advice of running a DTI against a vertical surface; though I don't know that my 123 blocks are particularly square.
I spent a bit more time today sweeping a DTI over the table and gently tightening and loosening the 4 column head bolts. Mostly I just ended up chasing my tail, and ended up with worse results than what I had yesterday indecision
old mart30/04/2023 21:26:49
4655 forum posts
304 photos
You should set the gibs so that the movement is slightly restricted but not tight throughout the full travel. The blocks can be checked against each other sitting on the mill bed, if they are not square you will see a gap when they are one way round. Keep bringing them together and with a decent steel rule or straight edge you can also check the lengths, by using a torch looking for any light showing. I bought a pair of 246 blocks which caused problems until I chanced to see a gap at the top when the bottoms were sitting together on the surface plate. They were reground for free, but now they are square, but slightly different sizes. As they improved for free, I did not say anything and knowing them now I can compensate.
Gordon B02/05/2023 09:20:45
11 forum posts
11 photos
Posted by old mart on 30/04/2023 21:26:49:
Gibs; yes, that's what I would have thought would happen (I've not had a machine with tapered gibs before). However, even if I remove the bottom gib screw and wind the top screw way down (I assume massively overtightening the gib) the column still moves with no noticeable extra drag. Seems a bit odd.
I'll check the 123 blocks for squareness when I next get into the garage.
JasonB02/05/2023 09:47:04
I have heard of another where the gib was loose, I think I'm right in saying the spare gib strips are longer and can be trimmed to fit by cutting a bit off the bottom if they go in a long way.
