My Ford Super 7 Countershaft Balance
Andrew Knowles 219/04/2023 17:01:10
20 forum posts
6 photos
Has anybody had any issues with the balance of the countershaft/clutch assembly
I have no vibration from the motor on its own (3phase Newton Tesla) but when I put the belt to the countershaft on but with the belt to the spindle off there is vibration
The large pulley on the clutch appears to be out of balance. Ie place it in one position and it will move round on its own always stopping in the same spot
The problem was much improved when fitting the 3phase motor but the vibration is still there
Thanks for any help or ideas on how to balance it
Michael Gilligan19/04/2023 17:16:18
23121 forum posts
1360 photos
So-called ‘Static Balance’ is relatively simple to check and adjust
Mount the pulley on a plain shaft and set it on a pair of parallel knife-edges
Edit: __ this illustrates the concept, on a smaller scale
https://clocksavant.com/blogs/news/watch-timing-and-accuracy-static-vs-dynamic-poising-balance-wheel-poising
When it settles: Remove material from the heavy spot [or add weight at the top]
Repeat the process until it settles in a different orientation every time you disturb it.
Dynamic Balance [like the tyre shop does] is, of course, more difficult.
Edited By Michael Gilligan on 19/04/2023 17:21:28
noel shelley19/04/2023 17:33:39
2308 forum posts
33 photos
2 clutches were used on the S7 the early moped front brake and the later cone clutch. I would check that the clutch unit has not gone out of balance before trying to balance the pulley. Noel.
ega19/04/2023 17:46:42
2805 forum posts
219 photos
Is it possible, please, to correct the thread title so that it can more easily be found in future?
bernard towers19/04/2023 17:48:27
1221 forum posts
161 photos
If the vibration is there before engaging the clutch it should mean that its the clutch driven pulley.I have just looked at mine and there are balance drillings on the back which you can see with a mirror and torch.
Zan19/04/2023 19:00:58
356 forum posts
25 photos
When I got my new s7 (1982) I too had bad vibration. It came from the primary drive belt whipping. A call to myford and it seems this was a common problem which they couldn’t test at the factory cos in those days the lathe came with no motor, chuck or much else! It was completely cured when they supplied a brammer line belt which I used until fitting a vdf and 3 phase 25 years ago, when the motor drive pulley diameter was changed to stop excessive motor speed and vdf frequency with high speed turning
bernard towers20/04/2023 15:59:54
1221 forum posts
161 photos
Ive never had any vibration problems with my S7 in single phase mode or 3 phase so it could be belt induced.
Howard Lewis21/04/2023 13:28:26
7227 forum posts
21 photos
Some v belts are fatter atb the join, and this can produce vivratiob because of the join riding furtherv out in the V .
Maybe a change to a better belt might cure the problem?
