duncan webster | 03/03/2023 15:22:24 |
5307 forum posts 83 photos | The cabling which goes from the main body to the door on my car has started to give way due to repeated flexing. It has over 20 cores just to control the window, central locking and mirror. Model railways would achieve this with 2 cores via the Direct Cab Control. Even if you don't want to send control signals down the power line I would guess that 4 cores would be enough. Are car manufacturers still in the stone age? |
Dave Halford | 03/03/2023 15:44:31 |
2536 forum posts 24 photos | That's why they invented CANbus |
noel shelley | 03/03/2023 15:56:23 |
2308 forum posts 33 photos | Whilst dave is right it is often easier to fix a broken wire rather than a computerised system. Noel. |
Dave Halford | 03/03/2023 20:14:49 |
2536 forum posts 24 photos | Posted by noel shelley on 03/03/2023 15:56:23:
Whilst dave is right it is often easier to fix a broken wire rather than a computerised system. Noel. Exactly |
Michael Gilligan | 03/03/2023 22:29:47 |
![]() 23121 forum posts 1360 photos | Posted by duncan webster on 03/03/2023 15:22:24:
[…] Are car manufacturers still in the stone age? . No, [see Dave Halford’s post] Having sorted that, years ago, they’re busy now … designing silly toys, as per my BMW thread MichaelG. |
duncan webster | 03/03/2023 23:50:48 |
5307 forum posts 83 photos | Posted by noel shelley on 03/03/2023 15:56:23:
Whilst dave is right it is often easier to fix a broken wire rather than a computerised system. Noel. I've had computers since the BBC (over 40 years?) and computer driven engine management systems for many years. The only problems I've had with any of them have been mechanical, broken wires, hard disc bearings etc. Further research on interweb shows that door wiring loom failure is a common fault on my model of car, fortunately I've tracked down a pattern part at 1/4 the cost of the manufacturer's. The break is too close to the plug to permit a crimp repair. Now wait for the weather to warm up a bit before I fit it, fiddly jobs outside when your fingers are freezing cold is not my idea of fun |
Michael Gilligan | 04/03/2023 09:20:54 |
![]() 23121 forum posts 1360 photos | In this cold weather … it might be worth staying indoors and having a look at this: https://www.csselectronics.com/pages/can-bus-simple-intro-tutorial Clever … and getting cleverer MichaelG. |
Hopper | 04/03/2023 09:28:29 |
![]() 7881 forum posts 397 photos | If the cabling to your door is giving way, how old is your car? Maybe it is from the Stone Age. In tech world that is about five years, as I just found out when trying to get my phone repaired after the on/off button got sticky. |
noel shelley | 04/03/2023 10:53:29 |
2308 forum posts 33 photos | Having read Michaels link I;m glad I have broken wires ! I understand them and with simple equipment can find and fix faults. Whilst I may be a dinosaur, I hope I'm not a Luddite. Having seen £250,000 macine stand idle for 6 weeks because it was so clever that the experts and technicians could not understand what was wrong, I'll stick with the old tech ! Agriculture and plant have yet to solve simple problems like rat and mice proof wiring, 1 wire and it's crippled ! Once started an old diesel needs no electrics ! Noel. |
Phil P | 04/03/2023 11:48:53 |
851 forum posts 206 photos | I had the same problem with the drivers door loom on my Skoda Yeti, apparently they had originally made them a tad short and they failed near the hinge post. I could not even lock the car when it failed. I was staggered at how much "stuff" was inside the door when I watched the new cable being fitted, the door even had its own ECU along with alarm system, heated mirror, moving mirror, window motor, door locking for drivers and/or other doors, under door lighting etc. I kept the old door loom as it had a good range of different coloured wires which came in very handy when I made a new loom for a 70's motorcycle. Phil |
