Robert Suijlen | 28/02/2023 18:54:28 |
13 forum posts 10 photos |
Hello every one, is somebody overhere formiliar with Clarkson cutters and Dedlock chuck's? Am looking for a holder or chuck for this cutter, Int 40. Tried to find out what thread this cutter has, I measure 22,80 diameter and 12 TPI. 1"x12 UNF doesn't fit. Does Clarkson have their own threadsize?? Would be fine if some one could help with this. Best regards Robert |
Bdog507 | 01/03/2023 08:20:53 |
38 forum posts | Good morning.
I'm sure Clarkson used Whitworth/BSF thread forms on their Dedlock chucks, but they weren't a standard TPI. You may find a suitable Dedlock chuck, but they're not common nowadays. My milling machine has a 5/8 UNC power drawbar, & tooling for it is much less common than say an M16 drawbar.
Cheers.
Stewart. Edited By Bdog507 on 01/03/2023 08:21:20 |
Michael Gilligan | 01/03/2023 08:30:08 |
![]() 23121 forum posts 1360 photos | Hint; **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1 MichaelG. |
Martin Connelly | 01/03/2023 08:43:33 |
![]() 2549 forum posts 235 photos | 7/8" is 22.225mm so I would guess 7/8" 12 TPI but would use a thread gauge to check if it is a 60° or 55° angle thread. You may be able to get a good macro picture with a digital camera or phone camera that you can measure with a protractor. There was a recent thread regarding the smaller threaded tooling for Autolock chucks and they use 20 tpi Whitworth (55° ) threads. Recent discussion on endmill threads Martin C Edited for unwanted smiley Edited By Martin Connelly on 01/03/2023 08:44:58 |
Robert Suijlen | 01/03/2023 08:58:20 |
13 forum posts 10 photos | Posted by Bdog507 on 01/03/2023 08:20:53:
Good morning.
Cheers.
Stewart. Edited By Bdog507 on 01/03/2023 08:21:20 Saw several advertisements from dedlock's with; 1" Whit x 12TPI. It does make sense, not easy to make yourself.Thanks for the response, best regards Robert |
Robert Suijlen | 01/03/2023 09:10:52 |
13 forum posts 10 photos | Posted by Martin Connelly on 01/03/2023 08:43:33:
7/8" is 22.225mm so I would guess 7/8" 12 TPI but would use a thread gauge to check if it is a 60° or 55° angle thread. You may be able to get a good macro picture with a digital camera or phone camera that you can measure with a protractor. There was a recent thread regarding the smaller threaded tooling for Autolock chucks and they use 20 tpi Whitworth (55° ) threads. Recent discussion on endmill threads Martin C Edited for unwanted smiley Edited By Martin Connelly on 01/03/2023 08:44:58 Ok, I think it's indeed 1" Whit x 12TPI as Stewart wrote earlier. Even saw an advertisement in the US with M24mmx1.75 thread! I cannot find a bolt with these measurements. So is the seller right about this?? Thanks for responding, best regards Robert |
JohnF | 01/03/2023 09:18:50 |
![]() 1243 forum posts 202 photos | Robert, I came upon this site by accident but it looks like it may be worth keeping an eye on their stock https://www.bimtalk.co.uk/cnc-metalworking-manufacturing/?s=Clarkson+deadlock+arbor Clarkson tooling is normal Whitworth form threads but they used whatever TPI they deemed appropriate. John |
Bdog507 | 01/03/2023 09:24:29 |
38 forum posts | Posted by Robert Suijlen on 01/03/2023 08:58:20:
Good morning.
Saw several advertisements from dedlock's with; 1" Whit x 12TPI. It does make sense, not easy to make yourself.Thanks for the response, best regards Robert. I got a couple of Dedlock cutters with my mill, but no chucks. I gave them away & bought an as new Seco indexable facemill. My machine has a 40int spindle so it swings a 100mm facemill with ease, & having round inserts means one can simply rotate them slightly when they become worn. There's a lot of obsolete tooling around. So it pays to do one's homework before purchasing something. I bought a new Bison facemilll arbour with a 3/4 inch shank. It was very cheap....It took 2 years before a suitable indexable facemill came up for sale, as nobody makes them with a 3/4 bore anymore. Unless one shops in the US, then customs & shipping clobber one.
Cheers.
Stewart. Edited By Bdog507 on 01/03/2023 09:29:42 |
peak4 | 01/03/2023 12:18:10 |
![]() 2207 forum posts 210 photos | A quick internet peruse could it be a double start 12 tpi in 1" size Bill |
Robert Suijlen | 01/03/2023 12:57:06 |
13 forum posts 10 photos | Posted by peak4 on 01/03/2023 12:18:10:
A quick internet peruse could it be a double start 12 tpi in 1" size Bill Hello Bill, saw the first two above allready, allthough the "double start" or "2 start" as the ad says I do not understand what it means! The second is a pity that it is an INT 50 otherwise I woud contact the seller. The third is interesting sure I gonne give it a try! BTW it isn't only the thread but also the 38mm flange wich goes into the cutter is an issue. Try to load up some pictures this evening for a better look. best regards Robert |
Robert Suijlen | 01/03/2023 13:01:48 |
13 forum posts 10 photos | Posted by JohnF on 01/03/2023 09:18:50:
Robert, I came upon this site by accident but it looks like it may be worth keeping an eye on their stock https://www.bimtalk.co.uk/cnc-metalworking-manufacturing/?s=Clarkson+deadlock+arbor Clarkson tooling is normal Whitworth form threads but they used whatever TPI they deemed appropriate. John Thanks John, I've seeing them all passing by in my dedlock surch! |
JasonB | 01/03/2023 13:06:52 |
![]() 25215 forum posts 3105 photos 1 articles | As the cutter body has a female thread it is likely to be the minor diameter being measured, so 22.8 would be about right for 1" x 12tpi if it's just been measured with a digi calliper Edited By JasonB on 01/03/2023 13:07:43 |
peak4 | 01/03/2023 13:12:54 |
![]() 2207 forum posts 210 photos | If you're sure the cutter is a genuine Clarkson, how about this on eBay? Edited By peak4 on 01/03/2023 13:14:27 Edited By peak4 on 01/03/2023 13:20:59 |
Robert Suijlen | 01/03/2023 14:04:40 |
13 forum posts 10 photos | |
Robert Suijlen | 01/03/2023 14:09:51 |
13 forum posts 10 photos | I guess everybody can see my album and intention I had in mind! |
Robert Suijlen | 01/03/2023 14:17:17 |
13 forum posts 10 photos | Posted by Robert Suijlen on 01/03/2023 14:09:51:
I guess everybody can see my album and intention I had in mind! Without the dedlock chuck of course.
DC31k | 01/03/2023 15:29:32 |
1186 forum posts 11 photos | Posted by Robert Suijlen on 01/03/2023 12:57:06:
If you are measuring the pitch as 12 tpi, a double start thread that measures thus is, roughly-speaking, two 6 tpi threads parallel to each other. You can do a quick check to confirm or deny it: Poke a scriber point into the vee of the thread and rotate the cutter 360 degrees. See how far the scriber point advances. If it is 1/12", the thread is single start. If it advances 1/6", the thread is double start. Post number 8 here suggest multi-start also: https://www.homemadetools.net/forum/large-slot-drill-sidelock-chuck-lathe-66573 |
peak4 | 01/03/2023 17:02:12 |
![]() 2207 forum posts 210 photos | Robert, where in the world are you, presumably not UK if you loaded the album in the evening in your time zone.
Edited By peak4 on 01/03/2023 17:32:39 |
Robert Suijlen | 01/03/2023 17:28:10 |
13 forum posts 10 photos | Posted by DC31k on 01/03/2023 15:29:32:
If you are measuring the pitch as 12 tpi, a double start thread that measures thus is, roughly-speaking, two 6 tpi threads parallel to each other. You can do a quick check to confirm or deny it: Poke a scriber point into the vee of the thread and rotate the cutter 360 degrees. See how far the scriber point advances. If it is 1/12", the thread is single start. If it advances 1/6", the thread is double start. Post number 8 here suggest multi-start also: https://www.homemadetools.net/forum/large-slot-drill-sidelock-chuck-lathe-66573 Well, never too old to learn something I guess, the double start can be seen optically at the bottem of the cutter. Also the measuring as you discribed, 4mm advance at one rotation. 1/6" = 4,23mm. |
Andrew Johnston | 01/03/2023 17:33:56 |
![]() 7061 forum posts 719 photos | The spigot on my Clarkson Dedlock holder is definitely 1" OD, 12tpi Whitworth thread form, and is 2-start. Plenty of Dedlock holders on Ebay, which is a sure sign they are obsolete. I have enough Dedlock cutters to make it worthwhile having a holder. Like this one: Andrew |
