Dougie Swan | 20/02/2023 20:30:48 |
269 forum posts 73 photos | Hi Can anyone suggest the best size of grit for lapping in ic engine valves I'm thinking of getting some of the finer diamond grades Any advice Thanks Dougie
JasonB | 20/02/2023 20:37:59 |
![]() 25215 forum posts 3105 photos 1 articles | I usually do mine with 600grit silicon carbide powder mixed with oil to form a paste. 100grams off e-bay will last a lifetime |
bernard towers | 20/02/2023 20:38:43 |
1221 forum posts 161 photos | Carborundum is the paste to use as it does not bed into the valves or seats, I think I would be worried that diamond would do the opposite as its virtually indestructable. |
old mart | 20/02/2023 21:08:08 |
4655 forum posts 304 photos | I went into Halfords ten years ago and asked for a tin of valve grinding paste, to my astonishment, they had never heard of it. I went to a small car bits shop and the guy said that there was a choice of two different makes in stock. I would choose the finer grade in the double ended tin. I would avoid diamond abrasive for valves. Edited By old mart on 20/02/2023 21:09:39 |
noel shelley | 20/02/2023 21:22:00 |
2308 forum posts 33 photos | I would use the double ended tin, it will last for years, Holts and chemico both do it, I'd go for chemico, If you have a branch of MPD near they will have it. Noel. |
JasonB | 21/02/2023 06:55:36 |
![]() 25215 forum posts 3105 photos 1 articles | I expect Dougie want's it for model engine valves and even the fine half of a tin of automotive grinding paste is way to coarse for model use. |
Hopper | 21/02/2023 08:51:04 |
![]() 7881 forum posts 397 photos | Metal polishes such as Brasso and Solvol Autosol aluminium polish are a good fine abrasive for smaller jobs. Brasso is a bit too fine sometimes but the Autosol works well. As does Mothers Aluminium Polish. Never tried it on small model IC valves though. |
Dougie Swan | 21/02/2023 11:21:15 |
269 forum posts 73 photos | Thanks for all the replies I have used the fine end of car valve grinding paste and as Jason says it's a bit rough I will try to get my hands on some finer carbide Thanks Dougie
Rick Hann | 21/02/2023 16:46:42 |
21 forum posts | Timesaver Sampler Pack. 8 different grades. 4 each for ferrous metals and 4 each non-ferrous metals. Non embeding! I have used it for more than 25 years. Rick |
Dougie Swan | 21/02/2023 17:59:27 |
269 forum posts 73 photos | Thanks Where is the sampler pack available from Dougie |
Ramon Wilson | 21/02/2023 18:36:42 |
![]() 1655 forum posts 617 photos | Dougie - I have plenty of Silicon Carbide (Carborundum) powder in 280 (too coarse for piston/liner lapping actually) 320, 600 and 1000 grits. Send me a PM if you want some. 'TimeSaver' is great but far too expensive when only small quantities are required. Diamond is a definite no no if the surfaces are not hardened. It will embed itself into the material and no amount of solvent cleaning will release it all. You need a good ultra sonic cleaner to do the job properly. Silicon Carbide is ideal - does a good job and is easily removed with a solvent such as cellulose thinner. I haven't done any valves but I have done the odd piston and liner. I am disposing of some of my workshop - Silicon powder is no longer required nor some genuine Kasenite case hardening powder - if anyone else wants some then PM me.
Best Tug Edited By Ramon Wilson on 21/02/2023 18:38:32 |
JasonB | 21/02/2023 18:38:20 |
![]() 25215 forum posts 3105 photos 1 articles | Heritage steam do the sets, but at about £100 a pop that's a lot of valves you could grind in compared to £3-4 for 100grams of 600grit off e-bay You could buy just a jar of very fine but it is still coarser than 600g |
Rick Hann | 23/02/2023 17:22:30 |
21 forum posts | Posted by Dougie Swan on 21/02/2023 17:59:27:
Thanks Where is the sampler pack available from Dougie I bought mine years ago from McMaster-Carr. There was a discussion a while back and if I remember correctly, it was hard to find in Europe and expensive. Probably not worth it for one or two jobs. I have built numerous engines over the years and I would not be without it. Still have 50% of it left. A Google search should turn something up if you are still interested. Rick |
