Alexander/Deckel Milling Machine
vintage engineer18/02/2023 21:53:30
293 forum posts
Does anyone know if a riser block was ever available for these machines?
Chris Evans 619/02/2023 09:10:52
2156 forum posts
I have worked a few Alexander and Deckle machines over the years but don't recall any with a riser block. Most of the machines I used where copy milling machines so maybe not a relevant answer.
Phil P19/02/2023 10:04:17
851 forum posts
206 photos
There was a riser block made for use with the die grinding head on the Deckel FP1.
Not 100% certain but I think the Alexander has DP gears and the Deckel has Module gears.
Good luck with finding one of those !!
I came up with a different solution when I need more headroom, and that was to make a dropper plate so the table can be attached lower on the vertical axis slide.
Phil
DC31k19/02/2023 10:34:58
1186 forum posts
11 photos
Posted by vintage engineer on 18/02/2023 21:53:30:
Turning the head sideways is another way to create space on this style of machine.
Phil P19/02/2023 11:36:27
851 forum posts
206 photos
Posted by DC31k on 19/02/2023 10:34:58:
Not sure what you mean by turning the head sideways, could you elaborate please ?
Dave Halford19/02/2023 11:41:56
2536 forum posts
24 photos
Rotate head 90deg and either mount the work to suit or end milling becomes side milling if that's OK. .
Phil P19/02/2023 17:01:40
851 forum posts
206 photos
Yes I see what you mean now.
vintage engineer19/02/2023 19:08:19
293 forum posts
Ah!
Thank you never thought of that!
Posted by Phil P on 19/02/2023 10:04:17:
Phil
