where to find commercial spindles and cutting frames, advice needed
Biagio Cerruto | 14/02/2023 01:24:25 |
10 forum posts | I own a Chronos cutting engine lacking of accessories and I would like to expand available tool sets to use. I am interested in purchasing a cutting frame and spindle. have a look at the following link on lathes.co.uk showing a rich toolkit. https://store.lathes.co.uk/sites/store.lathes.co.uk/files/styles/enormous/public/classified/2022/05/_5122671.jpg Is it possible to purchase the cutting frame and spindles on the market? Is there any brand that you would recommend or any web site where to purchase similar kit of accessories? Thank you for your advice Regards Biagio |
roy entwistle | 14/02/2023 09:39:14 |
1716 forum posts | I don't think that you're going to find anything for that machine. There was an article in one of the magazines may years ago re making one. Roy |
derek hall 1 | 14/02/2023 10:58:43 |
322 forum posts | Roy is correct, there was a series of articles on how to construct one of these wheel cutting machines by the designer Elliot Isaac's. I think he then allowed chronos to sell completed versions of the machine. You will find the articles in the defunct "Clockmaker" magazine by TEE publishing many years ago (1990?). Maybe you will able to find copies there were only ever 2 volumes over 2 years... Hope that helps Regards Derek |
John Haine | 14/02/2023 10:59:31 |
5563 forum posts 322 photos | There's a book called Spindles by Harprit Sandhu in the workshop practice series that apparently has a design. You can 3ven get the book from Chronos! |
Biagio Cerruto | 14/02/2023 11:02:43 |
10 forum posts | Thank you for the good information! Biagio
bernard towers | 14/02/2023 11:41:04 |
1221 forum posts 161 photos | I presume you mean a wheel cutting engine and when you say tools you mean gear cutters, if so they are commercially available or you can make them yourself. |
roy entwistle | 14/02/2023 13:37:28 |
1716 forum posts | Bernard OP specifically asks about cutting frame and spindles Roy |
Biagio Cerruto | 14/02/2023 13:38:29 |
10 forum posts | Posted by bernard towers on 14/02/2023 11:41:04:
I presume you mean a wheel cutting engine and when you say tools you mean gear cutters, if so they are commercially available or you can make them yourself. I mean the cutting frames and spindles (that can fit the old design of Chronos wheel cutting engine) more than the involute gear cutter itself. Biagio
Bazyle | 14/02/2023 13:42:00 |
![]() 6956 forum posts 229 photos | I think Biagio has the wheel cutting engine but just not the cutting frame. However that is a very simple item make. Just a U shape cut out of a solid block or by silver soldering some bars. Each arm uses a cap head screw or grub screw with a point ground on the end. If you think you need to buy this item you could also research 'ornamental turning ' supplies as they sometimes use similar cutters. |
Biagio Cerruto | 14/02/2023 14:54:40 |
10 forum posts | Posted by Bazyle on 14/02/2023 13:42:00:
That's correct! my wheel engine is incomplete and I need the cutting frame. Something like the below shape that I tried to draw with the keyboard chars.. . _______ |__ I will have a look at the ornamental turning spindles. Regards Biagio
Edited By Biagio Cerruto on 14/02/2023 14:58:26 Edited By Biagio Cerruto on 14/02/2023 14:58:45 Edited By Biagio Cerruto on 14/02/2023 14:59:04 Edited By Biagio Cerruto on 14/02/2023 14:59:18 Edited By Biagio Cerruto on 14/02/2023 14:59:37 |
roy entwistle | 14/02/2023 15:57:51 |
1716 forum posts | Commercial cutters have a 7mm hole for the spindle Roy Edited By roy entwistle on 14/02/2023 15:58:40 |
John Haine | 14/02/2023 16:03:51 |
5563 forum posts 322 photos | Traditional cutter frames have point and cone bearings probably because they were easier to make, but some kind of rolling bearings would be better these days. I suspect that generally wheel cutting engines have fallen out of favour because small vertical mills will do the same job with the addition of a dividing head, plus a whole lot more. One approach that might work for you would be to use a small headstock such as the Peatol or Sherline ones which can be bought on their own and work fine as milling spindles. https://taigtools.com/product/complete-headstock-with-er-spindle/ |
bernard towers | 14/02/2023 18:16:15 |
1221 forum posts 161 photos | The penny farthing tools one on the net does not show a cutting frame and I cannot se where you would fit it as it has a bc frame fitted already. |
Michael Gilligan | 14/02/2023 18:31:48 |
![]() 23121 forum posts 1360 photos | Sorry, Bernard … I am bewildered by your comment Do we have a different understanding of what constitutes a “cutting frame” ? https://pennyfarthingtools.co.uk/chronos-wheel-cutting-engine-4/2023/01/19/ . MichaelG. |
bernard towers | 14/02/2023 21:47:46 |
1221 forum posts 161 photos | No I don't think so Michael its just that why would you want/need a cutting frame when you have the whole machine. I thought (correct me if I'm wrong (usually) ) but isn't a cutter frame used when a wheel cutting engine is not available and wheels are then cut with a lathe and overhead drive? |
John Haine | 14/02/2023 22:13:08 |
5563 forum posts 322 photos | I assume the OP has an engine but it lacks the cutting frame - you can see from the PF Tools picture that it is just bolted in place. Presumably the OP's was parted from its frame at some point so it needs replacing. |
Michael Gilligan | 15/02/2023 00:20:39 |
![]() 23121 forum posts 1360 photos | Thanks, John … Yes, that’s how I understood the original request. Biagio is trying to locate parts to fit his incomplete Chronos whelcutting engine. MichaelG. |
Michael Gilligan | 21/02/2023 23:57:56 |
![]() 23121 forum posts 1360 photos | Biagio Have a look at this discussion: **LINK** https://mb.nawcc.org/threads/chronos-wheel-cutting-machine-help.37443/ You will find some good photographs, and links to two useful PDF files MichaelG. |
Biagio Cerruto | 22/02/2023 00:35:07 |
10 forum posts | Posted by Michael Gilligan on 21/02/2023 23:57:56:
Biagio Have a look at this discussion: **LINK** https://mb.nawcc.org/threads/chronos-wheel-cutting-machine-help.37443/ You will find some good photographs, and links to two useful PDF files MichaelG. Thank you |
