Member postings for Biagio Cerruto
Here is a list of all the postings Biagio Cerruto has made in our forums. Click on a thread name to jump to the thread.
Thread: Watchmaker gear cutting
22/02/2023 00:35:07
Posted by Michael Gilligan on 21/02/2023 23:57:56:
Biagio
Have a look at this discussion: **LINK**
https://mb.nawcc.org/threads/chronos-wheel-cutting-machine-help.37443/
You will find some good photographs, and links to two useful PDF files
Thank you
14/02/2023 14:54:40
Posted by Bazyle on 14/02/2023 13:42:00:
I think Biagio has the wheel cutting engine but just not the cutting frame. However that is a very simple item make. Just a U shape cut out of a solid block or by silver soldering some bars. Each arm uses a cap head screw or grub screw with a point ground on the end.
You need several of the small spindles to hold different bore cutters.. The are about 50mm long and have normal centre holes at each end so are turned between centres. First find the nut of large enough diameter to save having to do internal screwcutting.
If you think you need to buy this item you could also research 'ornamental turning ' supplies as they sometimes use similar cutters.
That's correct! my wheel engine is incomplete and I need the cutting frame.
a C shape with a screw on top and bottom and the spindle running between the screw centers:
Something like the below shape that I tried to draw with the keyboard chars..
.              _______ |__
.              |   ________|
.              |  |      __|__
. _______|  |       ------
.|_______|  |        ||||
.              |  |_____|__
.              | _________|
I will have a look at the ornamental turning spindles.
Biagio
Edited By Biagio Cerruto on 14/02/2023 14:58:26
Edited By Biagio Cerruto on 14/02/2023 14:58:45
Edited By Biagio Cerruto on 14/02/2023 14:59:04
Edited By Biagio Cerruto on 14/02/2023 14:59:18
Edited By Biagio Cerruto on 14/02/2023 14:59:37
14/02/2023 13:38:29
Posted by bernard towers on 14/02/2023 11:41:04:
I presume you mean a wheel cutting engine and when you say tools you mean gear cutters, if so they are commercially available or you can make them yourself.
I mean the cutting frames and spindles (that can fit the old design of Chronos wheel cutting engine) more than the involute gear cutter itself.
Biagio
14/02/2023 11:02:43
Thank you for the good information!
Biagio
Thread: Account limitations for new joined members (newbie)
14/02/2023 10:36:02
It makes sense,
Thank you
14/02/2023 10:35:23
Posted by JasonB on 14/02/2023 06:59:06:
You should be OK to see details now
Thank you
14/02/2023 01:44:44
I have just signed up, and for example I cannot see the contacts in the Sales Ad and I should make few number of posts to overcome the limitation.
I can instead post on the Wanted Ad.
Which are the limitations for the new accounts? how many posts are needed to unlock the full potential? is there any link where I can find the above info?
Best Regards
Biagio
14/02/2023 01:24:25
I own a Chronos cutting engine lacking of accessories and I would like to expand available tool sets to use.
I am interested in purchasing a cutting frame and spindle.
have a look at the following link on lathes.co.uk showing a rich toolkit.
https://store.lathes.co.uk/sites/store.lathes.co.uk/files/styles/enormous/public/classified/2022/05/_5122671.jpg
Is it possible to purchase the cutting frame and spindles on the market?
Is there any brand that you would recommend or any web site where to purchase similar kit of accessories?
Thank you for your advice
Biagio
