Probably an aircraft part
Michael Gilligan | 09/01/2023 20:46:11 |
![]() 23121 forum posts 1360 photos | Given the paint-job … I am almost sure that this lump came from an aircraft fitter. It has a half-inch diameter hole, with this natty little insert carrying a captive nut. … I scraped some paint off, in the hope of finding an identifying mark, but there is none. . . Simple questions:
Grateful for a simple answer … but if none is forthcoming, I will probably remove some more paint and try pulling !! MichaelG. |
peak4 | 09/01/2023 21:17:22 |
![]() 2207 forum posts 210 photos | Can't be much help I'm afraid; just been in contact with a friend of mine, in Cornwall, who until recently was an aeronautical tech of some sort, on current RAF aircraft. |
Michael Gilligan | 09/01/2023 21:38:19 |
![]() 23121 forum posts 1360 photos | Just a lump of metal, Bill … no longer identifiable, I am led to believe it’s an off-cut from a bucking block. Thanks for trying. MichaelG. Edited By Michael Gilligan on 09/01/2023 21:43:56 |
DrDave | 09/01/2023 22:12:42 |
264 forum posts 52 photos | It’s a barrel nut. This picture is an aircraft nut & bolt that used to help hold the wings on a PC-12 aeroplane, for example. Edited By DrDave on 09/01/2023 22:17:22 |
Michael Gilligan | 09/01/2023 22:36:35 |
Thanks DrDave … that looks spot-on I just didn’t know the name. Looks like my assumption that it would just slide out is O.K. MichaelG. |
peak4 | 09/01/2023 22:46:24 |
![]() 2207 forum posts 210 photos | That's annoying, I'd searched for barrel nut, but not "aircraft captive barrel nut", all the words, but not in the correct combination. |
DC31k | 10/01/2023 07:42:12 |
1186 forum posts 11 photos | Looking at the pictures, it would be interesting to see if there is anything built into it to stop it being installed upside down (i.e. that prevents the bolt entering from the wrong side). Maybe the last thread is malformed like a T-nut. |
Robert Atkinson 2 | 10/01/2023 08:04:40 |
![]() 1891 forum posts 37 photos | The nut is made in 3 parts. There is the barrel which has a slot in the back. A high tensile "nut" sits in the slot. A flat strip spring clip holds the nut in barrel and locate the whole assembly in the hole. On most of these the exit side of the nut is deformed. This is primarilly a threadlocking feature but also makes it very difficult to put the male thread in from the wrong side. If you want a dheaper non aircraft similar part intended for D shaped holes and T slots, but can be used upside down, look at D nuts for use in machine building extrusion Robert G8RPI. |
Michael Gilligan | 10/01/2023 08:07:58 |
![]() 23121 forum posts 1360 photos | When I remove them [there are two, one towards each end of the long hole] I will post a photo to illustrate the construction. There seem to be many variations on the theme, so we won’t know the detail until then. Following the very useful responses last night, I bumped the insert gently with a drift and it moved quite easily. More anon MichaelG. |
Michael Gilligan | 10/01/2023 08:09:53 |
![]() 23121 forum posts 1360 photos | Thanks for the additional notes, Robert MichaelG. |
Mike Poole | 10/01/2023 08:49:50 |
![]() 3676 forum posts 82 photos | Posted by peak4 on 09/01/2023 22:46:24:
That's annoying, I'd searched for barrel nut, but not "aircraft captive barrel nut", all the words, but not in the correct combination. That sounds like Eric Morecambe explaining to André Previn that he was playing all the right notes but not necessarily in the right order. Mike |
DrDave | 10/01/2023 10:02:36 |
264 forum posts 52 photos | I took a close-up of the working side of the nut to show its features. The dark grey nut can float slightly on the barrel section to allow for mis-alignment of the bolt. A pair of roll pins retain the nut (you can see one in the upper right of the nut). You can see why they cost an arm & a leg. |
martin haysom | 10/01/2023 11:45:27 |
![]() 165 forum posts | Posted by DrDave on 10/01/2023 10:02:36:
I took a close-up of the working side of the nut to show its features. The dark grey nut can float slightly on the barrel section to allow for mis-alignment of the bolt. A pair of roll pins retain the nut (you can see one in the upper right of the nut). You can see why they cost an arm & a leg. everything aircraft cost an arm and a leg after all it has to be made the best it possible to make it. long way down when something goes wrong |
Lee Rogers | 10/01/2023 11:50:52 |
![]() 203 forum posts | A good example of design to do the job. The bolt is taking sheer load , the captive nut is simply stopping it from moving and subject to very little load. NEAT !
Robert Atkinson 2 | 10/01/2023 12:13:23 |
![]() 1891 forum posts 37 photos | Posted by DrDave on 10/01/2023 10:02:36:
I took a close-up of the working side of the nut to show its features. The dark grey nut can float slightly on the barrel section to allow for mis-alignment of the bolt. A pair of roll pins retain the nut (you can see one in the upper right of the nut). You can see why they cost an arm & a leg. Slightly different design and a lot bigger than the ones I'm used to. No room for pins on the smaller ones but installation forces are probaly a lot lower. |
Robert Atkinson 2 | 10/01/2023 12:22:25 |
![]() 1891 forum posts 37 photos | Posted by martin haysom on 10/01/2023 11:45:27:
<SNIP>
everything aircraft cost an arm and a leg after all it has to be made the best it possible to make it. long way down when something goes wrong Unfortunatly not everthing on aircraft is made to be the best possible. The cost of aircraft parts is mainly down to certification costs A.K.A "the paperwork" not the basic production costs. It's getting worse all the time. It is one reason why aerospace is so conservative and does not always use leadingedge technolgy. Oid technology components are used long beyond their product life as a non-aircraft item because of the cost of analysing, testing and certification of a more modern replacement. Robert G8RPI.
DrDave | 10/01/2023 12:49:19 |
264 forum posts 52 photos | Posted by Lee Rogers on 10/01/2023 11:50:52:
If I may correct you, Lee, this is a tension bolt. If the shank is loaded in shear, something has gone wrong with the design! When installed, the bolt is torque tightened to a specified value, normally high enough to prevent the joint gapping under the maximum expected tension loading. The barrel nut has to carry the full tensile load in the bolt. The barrel nuts would be used in places where it is difficult to install an ordinary nut, for example. For reference, on aircraft at least, a shear bolt would be installed in an interference fit hole and the nut screwed on. |
Nicholas Farr | 10/01/2023 13:15:09 |
![]() 3988 forum posts 1799 photos | Hi, I don't know much about aircraft construction or maintenance, but I think DrDave is correct. High tensile bolts are normally used where the shear forces are taken by the two components having enough friction to resist shear forces, and to do this, the bolt is in tension, and such bolts should not have shear forces applied to them. These are also known as High Strength Friction Grip bolts. Regards Nick.
Michael Gilligan | 10/01/2023 15:38:02 |
![]() 23121 forum posts 1360 photos | I am pleased to confirm that:
Thanks everyone … mission accomplished . . |
Graham Meek | 10/01/2023 17:22:43 |
714 forum posts 414 photos | Everything aircraft usually carries a number. Thin plain washers being an exception. It can be the part number, but more usually it is the production or batch number. Each item being recorded in the build log of the particular item. Be that a fuel system, undercarriage, propeller, etc. Regards Gray, |
