Retired Engineer
Keith Basnett | 30/12/2022 14:01:07 |
8 forum posts | Hi everyone my main interest is making model steam engines (just starting) my wife has just bought me a small lathe so at the moment my workshop is just the lathe and bench drill. I'm think of purchasing the Vevor milling attachment to utilise the bench drill. My back ground has been in large machine shops so these dainty machines will take some getting used to. Are there any members using the Vevor milling table and do you recommend them. Any info will be gratefully received |
Harry Wilkes | 30/12/2022 15:44:00 |
![]() 1613 forum posts 72 photos | No Vevor but welcome to the forum H |
old mart | 30/12/2022 15:55:13 |
4655 forum posts 304 photos | Welcome, Keith, you will be amongst a huge number of steam experts. As for Vevor, you should put the name in the search box and read all the comments before committing yourself. I have just bought a Vevor 160mm lathe chuck for a very low price on ebay and initial examination suggests it is excellent value for money. You could start a thread asking advice on milling attachments for your model lathe, that will get the answers you want. If you have the room and funds, a mill would be a much better way to go. |
noel shelley | 30/12/2022 16:20:17 |
2308 forum posts 33 photos | Welcome to the party Keith. there will be many who can help you on here. Good Luck. Noel. |
Bazyle | 30/12/2022 17:31:33 |
![]() 6956 forum posts 229 photos | The bench drill is likely to have a lot of rattle in the quill unless an old British made one in good condition and the table perhaps a bit flimsy unless you are only working on say up to gauge 3. |
Keith Basnett | 30/12/2022 18:46:34 |
8 forum posts | Hi, I'm not sure of the make of bench drill but it is substantial and i've checked the quill for side movement with a dti and seems perfect I was thinking of mounting the milling base directly onto the drill base rather than onto the adjustable mid table. I think the only metal i will milling would be brass or aluminium with just light cuts |
duncan webster | 30/12/2022 18:53:30 |
5307 forum posts 83 photos | Unless you have a drawbar (unusual on a drilling machine) I think the chuck is likely to continually work loose if you try milling rather than coordinate driling |
Keith Basnett | 30/12/2022 19:27:57 |
8 forum posts | I must admit that is something I hadn't thought about, so thanks for that Duncan |
Howard Lewis | 30/12/2022 22:38:10 |
7227 forum posts 21 photos | Welcome! Find a local model engineering society and join.. There you will, meet like minded folk who can help with face to face advice, and demonstrations, Also, what you see will inspire you, but don't think that you should start building an A4 as a first job. Read up in books on lathe operation. (Sparey, Bray, Bradley, Clark, Fenner, Wyatt have all written books that will help. (Setting up, tool grinding etc You'll need a bench grinder if you have not already got one.) Learn by making simple accessories, ( Centre Height Gauge, Tap wrench, Die Holder(s ) . Even better if you make Sliding Die and Tap holders, may save you some grief later on ). A Mandrel Handle can also be a help for cutting a thread up to a shoulder.  Currently, I am helping a newbie with his first lathe, to make accessories. He is gaining experience, and confidence, which he will put to use when he feels able to take on more complicated projects. DON'T use a drilling machine for milling, even with a cross table. By all means use it to drill holes to co ordinates, but not for milling... The drill chuck and the spindle are meant for axial loads, not the intermittent lateral loads imposed by milling. In any case a drilling spindle is unlikely ,to be as accurately located as ma milling spindle. If possible, only use a lathe to mill, for light work.Maybe I was heavy handed, but a Rodney milling attachment shook my Myford ML7. So I bought a Mill! Milling, unlike turning, is an interrupted cut so involves a lot of impacts, and hobby machine are not heavily built like industrial ones. And as you know, industry uses heavily built Mills for such work. HTH Howard
David George 1 | 31/12/2022 07:10:16 |
![]() 2110 forum posts 565 photos | Hi Keith welcome to the forum. I am a retired toolmaker and having got a lathe tried milling on the lathe and found it very restrictive and so bought a small mill from Chester and wouldn't go back. If you have the room that is the way to go. Just look carefuly at the mill you buy as the one I bought has a Z axis handwheel at the back of the column and I did a mod to fit a bevel gear to make it more accessible. David |
Michael Checkley | 31/12/2022 09:15:55 |
![]() 121 forum posts 66 photos | Hi Keith, your name sounds familiar??....I used to live on the Wirral and was a member of the WRCFS (model flying club) for a number of years. We have since moved to Tarporley. Being self employed, 2 children and a house move has taken its toll on the model flying but my model engineering still lives on as its easier to escape to the bottom of the garden than the flying field! My father is a member of the Wirral Model Engineering Society if you need any contacts then please let me know but they have a good website and Facebook page and active most weekends on the ground level track. Mike |
Keith Basnett | 31/12/2022 10:46:15 |
8 forum posts | Hi Mike, yes I remember you from WRCFS, I've moved to a more sedate and relaxing pastime now. I hadn't realised there was a model engineering society on the Wirral so I'm definately going to get in touch with them so thanks for the info Keith |
Keith Basnett | 31/12/2022 10:50:32 |
8 forum posts | Thanks for all the info Howard Yes you have convinced me to save up for a mill but don't tell my wife |
SillyOldDuffer | 31/12/2022 10:57:54 |
10668 forum posts 2415 photos | Posted by old mart on 30/12/2022 15:55:13:
... As for Vevor, you should put the name in the search box and read all the comments before committing yourself. I have just bought a Vevor 160mm lathe chuck for a very low price on ebay and initial examination suggests it is excellent value for money. ... So Keith doesn't have to solve a mystery, Vevor is a big box shifter, which can be good or bad:
So bit of a gamble, much riskier if the box shifter is based abroad, but lots of people do OK buying from them. For ordinary purposes, I prefer to buy mid-range items of this type from UK specialist hobby suppliers. It's worked out OK for me. They put more-or-less effort into avoiding the worst, and - more important - will talk to the customer, hopefully without too much hassle. I think buying from reputable suppliers is safer than relying on trade-names, but there's always a risk. For what it's worth I prefer ArcEuro, Warco, and TracyTools, but I've bought from other UK vendors without major problems. If the tool is important, I look to the industrial suppliers. Rarely necessary because I'm a light hobbyist. New industrial gear is likely to be eye-watering expensive, and Model Engineers rarely like spending money! Second-hand industrial tooling is often good, but beware! Second-hand tooling has history. It can be worn out or need spare parts made of Unaffordium and Unobtainium. In short, I don't know of a general source of cheap tooling made to a tight specification. Good news, I haven't come unstuck buying mid-range yet. It helps that I don't expect Far Eastern hobby equipment to be just as good as western industrial gear costing 6 to 20 times as much. If a tool does what I need of it, it's "good enough". If it isn't "good enough", I go up market. My view of tools is entirely pragmatic; they're made to be used, not admired! But this is a hobby, and it's perfectly respectable to enjoy a workshop full of the best possible tools, if that's what you want. Dave |
Tomek | 31/12/2022 11:57:16 |
49 forum posts 25 photos | Hi Keith. I agree on joining ME society. There's a lot on benefits that comes with it and the most important is the chance to meet people that share a same interests and are happy to share their knowledge. If you wish to contact WMES, club doesn't have a website anymore but some info and contact details can be found on Facebook page Wmes facebook. You're welcome to come round to a meeting at WI hall in Thornton Hough, these are on the first and third Thursdays of each month at 7.30pm. Tom |
Keith Basnett | 31/12/2022 14:13:23 |
8 forum posts | Thanks Tom, I will definitely come along to those meetings and its just up the road for me. I'm looking forward to meeting people with the same interests. My problem at the moment is I don't have a milling machine until I save up for one, possibly another member might just do a bit of milling for me. Keith |
Keith Basnett | 31/12/2022 14:32:00 |
8 forum posts | Dave, thanks for your posting and yes your right Vevor are big box shifters / importers from China. My small lathe is one of these chinese imports and of course it doesn't compare to a Myford and you get what you pay for. Saying that I have been pleasantly suprised so far I have come from a machine shop background where time was money, I would be on a Mitchell lathe taking 1/4 inch cuts with blue swarf flying everwhere and now with the tranquility of retirement I can be quite happy taking 10 thou' cuts on my chinese lathe to pass the time of day. I just need to find a scrap metal merchant that has big pieces of brass for sale Keith |
David George 1 | 31/12/2022 15:41:38 |
![]() 2110 forum posts 565 photos | Keith have a look at M machine metals http://www.m-machine-metals.co.uk/ for metal suplies. David |
Keith Basnett | 31/12/2022 16:07:21 |
8 forum posts | Nice one David, that metal supply is just what I need and good value too. Thanks again David |
