Steam whistle-pitch pipes
mick H19/10/2022 14:32:45
795 forum posts
34 photos
Whilst tootling around in the workshop I came across a pitch pipe-brass chromed tubes, just over an inch long and joined together like pan pipes. They make quite delightful sounds which would sound really good on a loco as a whistle. Whilst they work perfectly when gently blown into they refuse to emit any sound when blown into with compressed air. Does anyone with knowledge of these pipes know what needs to be done to convert them into a steam whistle?
duncan webster19/10/2022 16:56:20
5307 forum posts
83 photos
Problem is the different speed of sound in air and steam. I wish you luck, but I'm not holding my breath.
noel shelley19/10/2022 17:00:10
2308 forum posts
33 photos
I'm pretty sure this matter has been discussed in ME at least once, but a few years ago ! Noel.
Nigel Graham 219/10/2022 22:23:52
3293 forum posts
112 photos
The clue might be in the question itself: not only the speed of sound (which depends on the density of the medium, not its pressure as such) but the pressure of the air or steam entering the whistle.
Over-blow a recorder, say, and it emits a harsh squeak at best, and that's just by lung effort.
Roderick Jenkins19/10/2022 22:46:24
2376 forum posts
800 photos
Mick,
Your pitch pipes are probably for tuning violins (4 pipes) or guitar (6). If so, they will likely be reed pipes rather than a flue pipe as used for steam whistles.
Rod
mick H20/10/2022 08:34:32
795 forum posts
34 photos
Hallo Roderick. Yes they are reed pipes I believe. Does that mean that they will not work with steam?
Nigel. Overblowing the pipe does emit a strangulated squeak of sorts just as in your recorder analogy. The strange thing is that I barely have to breath into the pipe to get a fine mellow note but they will not work on compressed air however low the pressure.
Mick
Michael Gilligan20/10/2022 08:42:29
23121 forum posts
1360 photos
Mick
Diagnosis at a distance is difficult [!]
But I suspect that your “however low the pressure” is still way too high
The maximum pressure that your lungs can blow might be around 2psig, so your gentle breath would be a tiny fraction of that.
Experiments with a manometer tube might be helpful
Edit: __ I have just found a wondrous list on Wikipedia:
 https://en.wikipedia.org/wiki/Orders_of_magnitude_(pressure)
[ Wondrous if you like that sort of thing ]
Edited By Michael Gilligan on 20/10/2022 09:01:53
