Chris Murphy | 02/10/2022 14:05:37 |
76 forum posts 63 photos |
well I’ve removed the spindle and managed to take out the back gear cluster. wasnt too bad of a job to do, now just have to buy a new one. at least they do still sell them at myford, but blimey, £91 for a new cog. well I like the machine to run as good as it can, I was tempted to leave it, especially at that price, as I don’t use the back gear that often, but like I said if anything’s wrong with it, I do like to get it fixed. thanks for the help chris m… Edited By Chris Murphy on 02/10/2022 14:08:45 |
Bizibilder | 02/10/2022 15:02:32 |
![]() 173 forum posts 8 photos | Looks like a relativly easy job for you. P.S. You have a PM Edited By Bizibilder on 02/10/2022 15:03:47 |
DiogenesII | 02/10/2022 15:16:07 |
859 forum posts 268 photos | Used one here for £85 https://www.ebay.co.uk/itm/334487651080 ..I've bought from this seller ('Heritage-lathes' ) before, no problems. Home&workshop have a new one on Ebay for £150.. You did remember to save the shims from the bearing caps so that you can stick them back in the same place they came out of when you re-assemble?
Edited By DiogenesII on 02/10/2022 15:16:27 |
Chris Murphy | 02/10/2022 16:05:58 |
76 forum posts 63 photos | Hi, yeah , i placed each shim exactly where they came from so they can go back just as they came off. hopefully everything will go back together properly 😉 chris m…. |
old mart | 02/10/2022 18:00:28 |
4655 forum posts 304 photos | I wonder if anyone has bought two gears of the correct specs and joined them together to make a cluster? |
old mart | 02/10/2022 19:41:16 |
4655 forum posts 304 photos | When you get the lathe repaired, you may be able to get hold of one of the 3D printed gear locking devices to fit on the large gear nearest the front of the spindle. Using one of these spreads the force of unscrewing the chuck over many teeth. No more broken teeth. The lathe model and number of teeth on that gear would be required before ordering one. |
not done it yet | 02/10/2022 19:44:36 |
7517 forum posts 20 photos | I’m sure someone would offer you a fiver for that ‘scrap’ gear cluster.😊 |
