Turning 8 in brake drum
Andrew Phillips 4 | 30/09/2022 20:02:32 |
30 forum posts 3 photos | Hi All, I am modifying a BSA 8 inch front brake drum to fit a 'special' and it is too big to swing on my Super 7. I used a local engineering workshop but despite giving them photos and drawings they took weeks to do an incomplete job. Can anyone recommend a small engineering workshop in the Wokingham/Berks area to finish the job? Andrew Edited By Andrew Phillips 4 on 30/09/2022 20:03:12 |
Michael Cox 1 | 30/09/2022 20:21:34 |
555 forum posts 27 photos | Try Tak Engineering on Slough Trading Estate. |
not done it yet | 01/10/2022 05:59:33 |
7517 forum posts 20 photos | Would it not be better, and cheaper, to join your local model engineering society? Presumably the wheel centre is not attached to the rim?🙂 |
Michael Gilligan | 01/10/2022 07:08:34 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 01/10/2022 05:59:33:
Would it not be better, and cheaper, to join your local model engineering society? Presumably the wheel centre is not attached to the rim?🙂 .
MichaelG. |
Brian Wood | 01/10/2022 15:07:55 |
2742 forum posts 39 photos | Andrew, Check your inbox, you have two PMs Regards Brian |
UncouthJ | 01/10/2022 15:12:01 |
143 forum posts 39 photos | Classic & Modern behind GT Holland's shops in Bracknell? |
