5 pin stop start switch
Haydn Callow | 16/09/2022 13:59:02 |
![]() 64 forum posts 37 photos | Hi, I’ve bought a 5 pin stop/start switch ….I think I should have got a 4 pin one. I’ve wired the 5 pin in the cable between the wall plug and the drum switch…easy enough but when I press the green start button the lathe springs to life but when I release the green button the lathe stops. I think the green button should stay down until I press the red stop button. The small 5th pin is not in use. Can I somehow use the 5 pin switch ? Or do I need a 4 pin ? |
Dave Halford | 16/09/2022 14:15:38 |
2536 forum posts 24 photos | A lot of the cheap start/stop switches are like doorbell push switches and designed to operate a relay, you need a latching type. The number of pins is irrelevant. |
Robert Atkinson 2 | 16/09/2022 14:47:47 |
![]() 1891 forum posts 37 photos | can you provide a link to the switch you bought please? Otherwise we are just guessing which helps no one. That said you probably just need to add a link on the back of the switch. Robert G8RPi. Edited By Robert Atkinson 2 on 16/09/2022 14:48:49 |
Haydn Callow | 16/09/2022 15:41:17 |
![]() 64 forum posts 37 photos | Hi, yes sussed it and all good now….had 13 and 23 input. 14 and 24 out…..then a 5th pin A……just connected A to 24 and all good Thanks |
Anthony Knights | 17/09/2022 10:32:45 |
681 forum posts 260 photos | "A" is obviously the feed to the solenoid, which operates and holds the contacts closed, now you have connected it to the outgoing supply. |
