Here is a list of all the postings Haydn Callow has made in our forums. Click on a thread name to jump to the thread.
Thread: Identifying a vintage lathe |
28/09/2022 21:48:58 |
Thanks, I think I understand it now, I’m on the case ! |
28/09/2022 16:35:03 |
Well, fitted drive belt and the lathe is working pretty much as it should……with the gears as above the saddle wizzes along very fast so I changed the gears as in the photo in this post and it is much better but still much to fast….where do I go from here ? Do I try and source a couple of 20 tooth gears… another problem is when the lead screw is engaged the part the ‘clutch lever’ engages that carries the bottom gear slowly moves out until the lead screw disengages. I have looked for a grub screw or something to lock it in position but nothing seems obvious. Edited By SillyOldDuffer on 28/09/2022 18:24:16 |
28/09/2022 11:30:39 |
The gears are not actually turning on those M10 bolts, I made up some steel sleeves for them…should I make replacements up out of a different metal later ? These are mild steel I think.
28/09/2022 11:27:08 |
28/09/2022 11:26:29 |
Well, now got the basket case together and it’s looking o.k. I have cobbled up some spindles for the gears to spin on, no idea what I’m doing regarding ratios ect… the photos show the present result….all I want is the lead screw to transport the saddle at a sensible speed to work with, can’t actually run the lathe yet as I’m waiting for a drive belt which I should have tomorrow. I have a couple of gears left over so I can alter things if required. again thanks for all the help from everyone….. |
Thread: Is this any good |
27/09/2022 18:11:14 |
Would there be any point in cleaning up the pressure pad half so it is smooth ? thoughts please. in the meantime I’ve cleaned everything up and lowered the pressure pad a bit and it does seem o.k. |
27/09/2022 17:17:08 |
Lee Roger’s….I think you are spot on once again….thanks. Should I get the pressure pad half back to smooth ? |
27/09/2022 17:14:20 |
Hi, thanks for all the reply’s…I have now discovered that the shiny top half should in fact not have any thread, what you see is where the lead screw over time has worn into it….it’s supposed to be a pressure pad….the lower half is the only part that has a ‘half’ thread. In view of this should I smooth out the top pressure pad and adjust it down a bit.. the lead screw looks to be pretty good. thanks
27/09/2022 13:09:00 |
So my next question :- can it be repaired ( beyond my ability ) or could I get a replacement ? |
27/09/2022 12:25:25 |
new to all this, bought a Drummond M type in a basket……I now have it built and I know it has been attacked with a hacksaw in the past…..however it is mostly there and it will do what I want. I have stripped most parts and cleaned and oiled reassembled. I have just stripped the saddle and in doing discovered what a half nut is. my question is having never having seen one before :- what do folks think of it ? Worn out, o.k, or good. if worn out what can I do about it ?
27/09/2022 08:25:59 |
Thanks….got it ! |
26/09/2022 20:51:39 |
Nick, that is exactly what I need. Many thanks for taking the trouble. also no 20 teeth beers..but at lease I know what I’m aiming for. I suppose if I get different gears to transmit power from the spindle to the lead screw it will only affect the speed of the lead screw…..I doubt I will ever be doing any threading on this machine and as long as I can get the lead screw turning at a sensible speed to move the saddle I will be happy…. thanks again |
25/09/2022 09:34:35 |
Hi again, looking at your very detailed photo of your gears/banjo…..my banjo looks a different shape to yours so what you have mau not be possible. |
25/09/2022 08:09:41 |
Lovely, thanks….can I be a real pain and ask the size of each gear..? |
24/09/2022 21:04:14 |
Sorry , photos in wrong order….. |
24/09/2022 21:02:30 |
23/09/2022 20:33:19 |
I’ve sorted the gears out, I have :- 2x30 1x35 1x38 1x45 1x50 1x60 they all have a peg sticking out and a hole so they fit together. non have a cutout for a woodruff key. The end of the lead screw has a woodruff slot so I’m assuming that’s missing. Also missing are the spindles the gears turn on…..anyone out there got a pattern or a drawing / Photo of one? Also the size of the lead screw gear. thanks |
23/09/2022 18:53:47 |
That’s exactly what I did this morning, changed the 4 threads that the head stock bolts into….now metric and all good |
23/09/2022 16:27:01 |
I do have the back gear. As said, everything has been modified so it all goes together on the custom made base unit. |
23/09/2022 16:24:13 |
Nigel, thank you for such a informative reply….I have a Myford ML7 and that is complete….I understand now where and what a back gear is….I doubt I will ever need it…..I bought this lathe as a basket case and I’m hoping to get it sorted over the winter…if I decide to sell it I suppose what has been pointed out will reduce the value….however it came with 3 good chucks, a new half hp motor and other bits….I paid £200 so doubt I’ll lose on it and I may keep it.
