Haydn Callow | 02/09/2022 15:37:53 |
![]() 64 forum posts 37 photos | Me again with another beginners question :- I have just got myself a Gryphon 0.25 hp motor. I want to keep it as a spare for my ML7 lathe. it has come after having had new bearings fitted and runs very quiet and smooth. it also came with a 3 core cable and plug and runs in one direction only. I would like to rewire it so I can select Fwd/Rev using a drum switch. I have a drum switch with 2 rows of 4 contacts. the motor has 4 terminals. Z1. Z2. A1. A2 A1 seems to be connected to Z1 via a copper link A2 seems to be connected to Z2 via a copper link how ‘very simply please’ do I connect the Mains, Drum switch and motor together to achieve what I want and how many cores does the cable need from motor to switch, and if possible how thick do the cores need to be ? I.e. .75mm,1mm, 1.5mm long question but I am learning and you have sorted my previous 2 ??s very quickly thanks |
John Haine | 02/09/2022 15:46:56 |
5563 forum posts 322 photos | That's possibly a bit small for a ML7, however... Does it have an obvious capacitor? If it does then it should be reversible in the way you want. As for using it as a spare, induction motors almost never give up unless either the bearings wear out or the start/run capacitor(s) give up, usually the latter. So your main motor is very likely to be easily repairable if it does go. |
Haydn Callow | 02/09/2022 15:57:05 |
![]() 64 forum posts 37 photos | Thanks, yes it does have a capacitor…. The motor is I understand original to a ML7. The motor on my lathe was new a month ago and gave up….it would only go in reverse…..see my previous topic…the manufacturer is replacing it for me. |
John Haine | 02/09/2022 16:02:42 |
5563 forum posts 322 photos | Well without knowing exactly how the cap is connected I'm not sure how you reverse it, but I would guess that one winding must be Z1-Z2 and the other A1-A2, and one of these has the cap in series. At the moment it's connected Z1-A1 and Z2-A2, I would guess that if you connect Z1-A2 and Z2-A1 it would run in reverse as you have reversed one winding's sense relative to the other. As for the number of cores, there are only 4 terminals (plus earth presumably) so it can't be more than 4! As for size the same size as on your main motor. Wiring these funny switches I have no knowledge of I'm afraid. |
peak4 | 02/09/2022 16:11:43 |
![]() 2207 forum posts 210 photos | Here you go, not only will this site show you how to refurbish a Dewhurst switch, it will also show how to wire one. Edited By peak4 on 02/09/2022 16:14:10 |
Haydn Callow | 02/09/2022 16:13:39 |
![]() 64 forum posts 37 photos | The capacitor is connected to Z1 & Z2. Red wires the windings to A1 & A2 Black wires |
Haydn Callow | 02/09/2022 16:21:35 |
![]() 64 forum posts 37 photos | Peak4….great, thanks….. Edited By Haydn Callow on 02/09/2022 16:22:10 |
noel shelley | 02/09/2022 16:55:32 |
2308 forum posts 33 photos | A .25Hp motor will only do small work on an ML7 ! Should be 0.5Hp Start windings should be blue and Yellow, run windings should be red and black. It sounds like a dewhurst drum switch. A1 and A2 run and Z1 and Z2 start ' 1,2,3,4, on left 5.6.7.8. on right of switch.. Live to No1 Neutral to No3 earth to the earth stud or bear metal point VITAL ! A1 to No5, A2 to No 7, Z1 to No6 and Z2 to No2. IF the direction is wrong on the switch swap No6 and No2.. ONLY use this switch to change direction of rotation, stop and start with a seperate switch. NEVER change direction whils the motor is still turning ! . Good luck Noel. Edited By noel shelley on 02/09/2022 17:33:23 |
Haydn Callow | 02/09/2022 17:37:02 |
![]() 64 forum posts 37 photos | Thanks for that….it’s not a Dewhurst but very similar…..made in China , green oblong….plenty to see on eBay….dammed if I can work out how to post a picture on here. I’m on a iPad |
noel shelley | 02/09/2022 17:38:58 |
2308 forum posts 33 photos | To answer your question 5 core 1.5 mmsq Noel.. |
not done it yet | 02/09/2022 18:22:34 |
7517 forum posts 20 photos | Posted by noel shelley on 02/09/2022 17:38:58:
To answer your question 5 core 1.5 mmsq Noel.. I would think 1mm ^2 or even less,is likely sufficient. It’s not much bigger than a good sized soldering iron!🙂 |
SillyOldDuffer | 02/09/2022 22:12:29 |
10668 forum posts 2415 photos | I'd think twice before fitting a motor that small - it will limit how fast you can work, and the motor will often be pushed to the max. Half to one horse-power is more usual, and a boy racer might go bigger still...
Haydn Callow | 16/09/2022 13:50:48 |
![]() 64 forum posts 37 photos | All good and working well, thanks everyone |
Bazyle | 16/09/2022 15:49:56 |
![]() 6956 forum posts 229 photos | Hope you are not using the drum switch as the main on/off. That will burn the contacts - you need to get a 'no volt release' unit. Probably got that in the Myford wiring but in case you decided to use this motor on some other little project. |
