Myford VMC mill
service info on myford VMC mill.
RRMBK24/08/2022 23:26:28
159 forum posts
18 photos
Hello all .
Please can anyone provide the specification for the two belts used on a myford VMC mill from around 1980.
Also can you tell me how to lubricate the quill bearings.
I don't have a manual for the mill, and attempts to find one on the web have just led me down interminable rabbit holes ending in a request for payment.
Many thanks.
DC31k25/08/2022 07:00:58
1186 forum posts
11 photos
Posted by RRMBK on 24/08/2022 23:26:28:
You do now:
https://ostiatools.co.uk/machinery-manuals/
Part 25 A34.
It is useful in this case to search for both 'vmc' and vm-c'. To you, they are the same; to the al gore rhythm, they are different.
Russ B25/08/2022 07:47:41
635 forum posts
34 photos
Also, note the makers name on the front, it's not Myford.
Here's a slightly less wonky version!
https://www.dropbox.com/s/1xl3o958x2qupqo/_Kao%20Fong%206x24%20Manual%20KF-VM-C.pdf?dl=0
Tony Pratt 125/08/2022 08:27:01
2319 forum posts
13 photos
I have a Myford VME mill so slightly larger table and I can't see any way of lubricating the spindle bearings, I also replaced the overly stiff original belts with a linked type with great success.
Tony
RRMBK25/08/2022 08:56:13
159 forum posts
18 photos
Thank you very much for the quick responses. Greatly appreciated. The manual and exploded parts drawing is just what I needed.
Bearings are clearly sealed units, so after 40 years probably best to replace ! and the belts are readily available locally.
Once again many thanks.
Russ B25/08/2022 11:49:35
635 forum posts
34 photos
I think I looked in to the spindle bearings many years ago - I seem to recall having no luck with the thrust ball bearing at the bottom - I began thinking about an upgrade to a taper roller on the nose but after removing the pulley and bearings, cleaning and adjusting it's all been solid and sound ever since.
I was thinking along the lines of a "Gamet100035/100072C Super Precision Flanged Tapered Roller" The flange provides about 2mm clearance behind the bearing, and reduces the nose to table by 9mm or so. I'd have fit a standard rotary shaft seal in a carrier secured to the quill to seal it. I can't remember if I did a drawing - I have two young kids now and focus my spare time on tinkering with other things and if I get some me time, I'm zapping about on my 2 stroke faster than I should be, or tinkering with it.......
I'm sure a normal taper roller would suffice for a 10th of the cost (or less!)
Russ B25/08/2022 12:05:53
635 forum posts
34 photos
This was I think.... a drop in replacement, do your own homework though!
Timken 19138X/19283
but still, a seal and carrier would be needed - no trouble for anyone on here I'm sure! I would just 3D print on, from design to part in just an hour or 2, and if it broke, I'd think about machining one... and then remember I can much more easily just press print and another will appear.....
Nigel Graham 225/08/2022 12:15:26
3293 forum posts
112 photos
Thank you for raising this, RRMBK.
I have the same machine, and it suffers from excessively stiff quill vertical travel and as well as that it's quite possible the bearings or at least their lubrication are a little old and worn out by now. It also has a problem that often makes inserting the R8 tooling difficult - it feels like a loose key or pin not reliably engaging the keyways.
Thank you DC31K and Russ -
Have bookmarked these and down-loaded the Ostia manual. I think they are actually the same document. I don't think they differ from the information I have already but I will study them carefully to see if they give any more information... such as actually how to dismantle the thing to service it!
I did at least find my existing manual useful for making a drawbar to replace the original lost in a house-move. While at it the sectional drawing showed how I could make it self-ejecting.
Russ B25/08/2022 14:18:45
635 forum posts
34 photos
I should probably reword that, "upgrade" - the original separate roller and thrust bearings no doubt provide much better support for heavy side loads, but I expect the taper rollers by design to provide less radial play and therefore better support for smaller higher speed cutters - which I more up my street, hence, "upgrade"
John Haine25/08/2022 14:22:42
5563 forum posts
322 photos
I have a VMB which has a similar belt arrangement except that the intermediate pulley, instead of floating, was fixed on a sliding plate that had to be loosened, adjusted, then tightened when you changed belt ratios on the front, a stupid design! When I upgraded to a 3ph motor + VFD I used the intermediate pulley on the motor as it had the same dimensions as the spindle pulley and eliminated the intermediate pulley stage. Haven't missed it!
Russ B25/08/2022 14:42:56
635 forum posts
34 photos
If anyone is interested, not the best quality scan but some sales information.
https://www.dropbox.com/s/4s35k4v8iho6lfl/Full%20page%20photo.pdf?dl=0
Bob Unitt 127/08/2022 16:16:38
323 forum posts
35 photos
Posted by John Haine on 25/08/2022 14:22:42:
Curious - I have a VMB bought direct from Myford in 1998, and it has a floating intermediate pulley.
Douglas Johnston27/08/2022 16:30:26
814 forum posts
36 photos
I have the poly-V pulley version of the VMB with variable speed invertor and it is almost impossible to get access to the bolts of the sliding plate to change the belt positions. As a result I never change the belt position and rely on the VFD for speed change. As you said it is a very poor design.
Doug
John Haine27/08/2022 16:35:28
5563 forum posts
322 photos
Posted by Bob Unitt 1 on 27/08/2022 16:16:38:
Bought mine in 2003 so they must have changed the design.
