Steve Richardson 2 | 20/08/2022 01:21:20 |
43 forum posts 10 photos | just curious if someone knows how the internal valving on this engine operates? or has plans for something similar |
Hopper | 20/08/2022 01:28:25 |
![]() 7881 forum posts 397 photos | Maybe a variation on Corliss valve gear -- basically oscillating rotary valves operated by those levers. There are animations on the net if you google Corliss valve gear. |
BOB BLACKSHAW | 20/08/2022 06:45:33 |
501 forum posts 132 photos | Or you could take it apart and see how it works. Perhaps give it a good clean up or any replacement parts needed. |
Zan | 20/08/2022 08:37:35 |
356 forum posts 25 photos | Could be a uniflow engine with the central pore being the exhaust. The cylinder would need to be twice the length of the stroke, and inlet at both ends only More photos would help |
Steve Richardson 2 | 20/08/2022 09:48:05 |
43 forum posts 10 photos | would like to take it part but all I have seen are the pictures online yes may have a look at Corliss - could be some similarities there |
noel shelley | 20/08/2022 10:19:49 |
2308 forum posts 33 photos | As Hopper, could be corliss valve gear, with a link missing ? Noel. |
roy entwistle | 20/08/2022 11:48:45 |
1716 forum posts | There appears to be only one port at each end. As far as I know a Corliss would have two. Looks like a uniflow |
Hopper | 20/08/2022 14:51:09 |
![]() 7881 forum posts 397 photos | Yes looks like a uniflow set up with the central exhaust port, but with Corliss-style rotary valves rather than the uniflow's more usual poppet valves. Looks like an old model. Is anything known about its history or orgins? |
Steve Richardson 2 | 21/08/2022 10:48:17 |
43 forum posts 10 photos | I would have assumed the port facing the front is an inlet? (not exhaust?) - and I assume a uniflow would still need an inlet and exhaust? unless theres another port underneath we cant see. No further history available, this is for sale on that well known online web site, just described as scratch built. |
roy entwistle | 21/08/2022 14:01:23 |
1716 forum posts | Any engine will have an inlet and an exhaust |
Nigel Graham 2 | 21/08/2022 15:49:51 |
3293 forum posts 112 photos | That branch with the screw-plug suggests to me that it is the inlet, with an oiling-point; the exhaust perhaps on the other side. The blobby soldering is rather at odds with the rest of the design and finish so might have been a later modification or repair, perhaps by an intermediate owner. Otherwise as others say, semi-rotary valves of some form.
SillyOldDuffer | 21/08/2022 16:30:22 |
10668 forum posts 2415 photos | Posted by Nigel Graham 2 on 21/08/2022 15:49:51:
That branch with the screw-plug suggests to me that it is the inlet, with an oiling-point; the exhaust perhaps on the other side. ...Could be. I agree it's the inlet but wonder if the side thingy is a crude throttle, where tightening that set-screw blocks the input. Possibly hand-made and early. Seems to be made of Copper apart from the brass inlet which looks manufactured and out of character. Identifying the threads might help, especially if they turn out to be non-standard. I'd love to know exactly how the valves work. Judging by the finish it was made by an advanced Learner, or possibly it's a proof of concept. Good enough workmanship to run, but far from Exhibition standard. Looks like one of mine! Dave |
