Matthew Furseman | 16/08/2022 21:20:04 |
21 forum posts 30 photos | I've recently got a used Warco Major Mill/Drill. I've had it in pieces and have just put it back together. When I picked it up there was an ER32 collet holder in the MT3 spindle, I think it's been in there a while. I tried the obvious step of loosening the drawbar bolt and giving it a tap with a small hammer but it didn't budge. Since then I've tried a bunch of things, still with no luck:
My failed attempt with the spanner, I'm worried that the force, particularly and non-downwards component, could have damaged the mill. I've bought a larger drift which is in the post, although don't expect much from that. Apart from heating the spindle and using a drift / hitting the draw bar, I don't know what else I can do.I don't own a hydraulic jack but even if I did I don't know how I'd apply while the spindle is still in the mill. Does anyone have further suggestions? |
Andrew Johnston | 16/08/2022 21:26:06 |
![]() 7061 forum posts 719 photos | Repetitive taps on opposing sides with a hammer; doesn't need to be hard but you may need a lot of taps. Repetitive, and oscillatory, side loads are a classic way of loosening a taper. Which is why it isn't recommended to mill without a drawbar. Andrew |
Pete Rimmer | 16/08/2022 21:28:02 |
1486 forum posts 105 photos | Loosen the drawbar and start cutting it'll soon come loose then |
Matthew Furseman | 16/08/2022 21:37:13 |
21 forum posts 30 photos | Posted by Pete Rimmer on 16/08/2022 21:28:02:
Loosen the drawbar and start cutting it'll soon come loose then Err, is that safe? |
Matthew Furseman | 16/08/2022 21:38:45 |
21 forum posts 30 photos | Posted by Andrew Johnston on 16/08/2022 21:26:06:
Repetitive taps on opposing sides with a hammer; doesn't need to be hard but you may need a lot of taps. Repetitive, and oscillatory, side loads are a classic way of loosening a taper. Which is why it isn't recommended to mill without a drawbar. Andrew That sounds like something I can tinker away with. Any idea how many / how long I'd need to do this for before I find it will release? Should I try the odd tap on the drawbar as I go? |
Huub | 16/08/2022 22:44:52 |
220 forum posts 20 photos | You could use a pneumatic drill to "hammer" it out using a lot of small taps. Preferred The thread on the collet (M40x1.5) and the collet nut can be used to make a puller against the shoulder of the mill.
peak4 | 16/08/2022 23:06:50 |
![]() 2207 forum posts 210 photos | In order to avoid damaging the bearings if you're hitting the drawbar, I'd arrange come sort of support for the quill onto the main table. Edited By peak4 on 16/08/2022 23:14:33 Edited By peak4 on 16/08/2022 23:16:14 |
Robert Butler | 16/08/2022 23:07:53 |
511 forum posts 6 photos | Posted by Matthew Furseman on 16/08/2022 21:20:04:
Does anyone have further suggestions? With my Chester Lux mill R8 taper, when changing tooling I use my air impact wrench which undoes the draw bar, (not overly tightly secured) and and loosens the taper. Place something to catch the ejected tooling safely - ask me how i know! Robert Butler Edited By Robert Butler on 16/08/2022 23:09:30 |
Mike Poole | 16/08/2022 23:11:30 |
![]() 3676 forum posts 82 photos | It looks at though you could employ some taper wedges like the ones supplied for removing drill chucks. You will probably need to make a pair as drill chuck ones will be too small. Mike i see Bill beat me to the wedge idea while I was composing 😀 Edited By Mike Poole on 17/08/2022 17:34:24 |
Peter Cook 6 | 16/08/2022 23:23:56 |
462 forum posts 113 photos | Short length of tube which bears on the face of the quill, the other end of which bears on the back face of the collet nut. Tighten the nut while holding the spindle to squeeze the tube up onto the quill - pulls the taper down. If the OD of the collet thread is bigger than the OD of the quill, slip the/a spanner in between the tube and the quill to provide a bearing surface. |
Pete Rimmer | 16/08/2022 23:29:31 |
1486 forum posts 105 photos | Posted by Matthew Furseman on 16/08/2022 21:37:13:
Loosen the drawbar and start cutting it'll soon come loose then Err, is that safe? Well I wouldn't condone running it at 2000rpm but sooner or later you're going to have a tool come loosein the taper. I guess it all depends on what you regard as 'safe'. Some people won't use a 9" grinder full stop because they don't regard them as 'safe'. I'm more than comfortable with it. Probably best to explore other avenues TBH, my reply was very much tongue-in-cheek. |
Howard Lewis | 16/08/2022 23:40:04 |
7227 forum posts 21 photos | I don't think that P R was suggesting running without bthe drawbar. merely slackening, to finger tight and taking a few cuts at low speed is likely to shake things loose. If you did not want it to, it WILL happen. Probably, the ER collet chuck was inserted, cold into a warm quill. DON'T do that.! If you choose to go for the method of using either wedges or packing behind the 40 x 1.5 mm collet clamping nut, to try to extract the chuck, having the drawbar slightly loose, and giving it a bash once the load has been applied, MIGHT break the taper loose. If the taper moves even slightly, you have succeeded! Howard |
Hopper | 17/08/2022 00:10:01 |
![]() 7881 forum posts 397 photos | Tapping simultaneously on the sides of the extended quill in the area of the taper with a pair of copper hammers will bring it loose. Work around the diameter until the taper comes loose. Get the two hammers to strike at once so the impact expands the taper from two sides at once. Steam fitters use this trick (with two steel hammers) to loosen up rusted pipework where tapered threads have seized solid. A pipe wrench with six foot of pipe on the handle and two blokes swinging on it will not shift rusted 2" pipe, but a 30 second belting with two hammers around the outside of the fitting and it comes loose by hand. Amazing to witness. |
Ady1 | 17/08/2022 00:50:13 |
![]() 6137 forum posts 893 photos | Posted by Pete Rimmer on 16/08/2022 21:28:02:
Loosen the drawbar and start cutting it'll soon come loose then side milling with a slot drill type cutter, leave a tiny gap and it drops down safe better than battering the snot out of it |
Hopper | 17/08/2022 05:45:47 |
![]() 7881 forum posts 397 photos | Posted by Ady1 on 17/08/2022 00:50:13:
Loosen the drawbar and start cutting it'll soon come loose then side milling with a slot drill type cutter, leave a tiny gap and it drops down safe better than battering the snot out of it True dat. |
Pete Rimmer | 17/08/2022 06:11:09 |
1486 forum posts 105 photos | Posted by Howard Lewis on 16/08/2022 23:40:04:
I don't think that P R was suggesting running without bthe drawbar. merely slackening, to finger tight and taking a few cuts at low speed is likely to shake things loose. Correct I was not suggesting milling without a drawbar, just a loosened one. |
DC31k | 17/08/2022 06:59:26 |
1186 forum posts 11 photos | A couple of observations: With the tapping idea, would it not have to be on the inner, rotating part of the quill (i.e. the part into which the male taper is seated) to have any effect? Extending the quill will only expose the outer, non-rotating part and I do not think any effort on that will do anything. The idea of the vibration is high-ish frequency, small amplitude and not much force. It is very much 'rattle it out' rather than 'beat it out'. Someone above suggested a pneumatic hammer. Another option is an SDS drill set to hammer-only. You can buy SDS to 1/2" BSP male adaptors and you can screw a sleeve onto this that will accept the drawbar or a drift that goes down the spindle. Bung up the hole in the chuck and pour some diesel down from the top a day or so before. Instead of pulling on the collet nut, there is a good chance the chuck has a through hole, so just install the drawbar from below and use it to apply the pulling force against the pipe sleeve. As with pulling any taper, a combination of pull from below and tapping from above will assist. |
Gavlar | 17/08/2022 07:57:07 |
119 forum posts 1 photos | I had the exact same problem with a 3-2MT reducer stuck in the quill of a Chester 626 mill. There is a thread on here somewhere but to summerise, I couldn't knock it out from above as there was no shoulder, it wasn't threaded so I couldn't use the drawbar. I couldn't vibrate or twist it out. Gentle heat had no effect and I used a can of freeze spray which also had no effect. I ended up removing the quill and taking it to a small local engineering company. They tig welded the protruding part of the reducer to facilitate knocking it out from above. Whilst still warm from the welding it came out with a gentle tap. The mill has been in use ever since and has not suffered any ill effects. |
Nicholas Farr | 17/08/2022 08:33:43 |
![]() 3988 forum posts 1799 photos | Hi, I'd go with Peak4's wedges idea myself and yes use two with the same taper, you can always give the drawbar a clout once you have the wedges locked together. Regards Nick. |
SillyOldDuffer | 17/08/2022 09:28:01 |
10668 forum posts 2415 photos | Likely causes one of more of:
Heat, penetrating oil, sharp tapping (avoids pounding) and vibration all tend to loosen tapers. Sharply tapping the drawbar hasn't worked. Penetrating oil left to soak for a few days might help if the cause is gum or corrosion, but it may be difficult to apply to the joint and it removes lube from any bearings it gets into. Vibration is good at loosening stuck joints and I'd try it first. Normally, mills are set up and used to minimise vibration, but in this case I'd do it all wrong. It's somewhat risky so keep clear of the cutter, wear eye protection, and be ready to stop. As this is off the beaten track I hope others will comment on the following suggestions:
Heat is almost guaranteed to work but it may be difficult to apply without dismantling the mill. Although heat is the Queen of dismantling methods I'd try vibration first because it's easier to do. Heating the spindle, not the chuck, expands the spindle and tends to loosen the joint whatever is holding it together. I think many repeated cycles of moderate heat and cooling are safer than one blast of severe heat. By moderate heat I mean a temperature below anything likely to alter the temper of the steel, say 100 to 200°C, below the temperatures that cause oxide colours to appear, and definitely not glowing! If an expert says disagrees, believe him not me. Final advice. This sort of problem causes me to lose my rag and reach for a sledge-hammer. Resist the temptation to take extreme measures - slow but sure is unlikely to break anything Dave PS After posting I see others recommending wedges. Good idea, and you can make them in the mill. Making a wedge with a slack drawbar might be enough!
Edited By SillyOldDuffer on 17/08/2022 09:31:02 |
