Here is a list of all the postings Matthew Furseman has made in our forums. Click on a thread name to jump to the thread.
Thread: Smart and Brown Model A Fine feed adjustement |
16/10/2022 18:35:01 |
I finally returned to this after quite some time as I was doing some cleaning on other parts of the lathe and stripping my mill spindle (thanks Old Mart for your help in that thread!). The inside was filthy, without about 1cm of gunked up oil with shards of bronze and steel mixed through it. I think the pump on mine is working as I get a smear of filthy black oil over the ways when moving the apron back and forth. The brass dog on the gear selector was stuck solid, presumably glued by the dried out oil. I removed it, soaked in WD40 overnight and then took it to a vice with grips and freed it. I've cleaned everything a lot and it's now looking pretty good, ready to go back together! I haven't run the lathe under power yet so not sure if the clutch works, I didn't get a micrometer stop with the lathe anyway. I've got a bunch of other problems to solve which I'm working through as I do this 'functional restoration' of the thing, not sure if I should start a new thread or keep asking away in this one.
Thread: Stuck Morse Taper in Warco Major 3024YZ |
16/09/2022 19:23:35 |
And it's out!
Once the spindle was removed from the quill I was able to put in a vice with some EPDM for soft jaws, grab a pair of safety specs, then get a drift in and knock it from above with the 3lb hammer. I did have to 'batter the snot out of it' but with the bearings no longer taking any of the shock I figured this wouldn't be an issue. After about 20 heavy blows the taper popped off into a an old garden glove I had bunged over it to try and limit any damage it might cause when released. I reckon I could have done this in situ if I had made up the top of the taper with a 3/8 socket screw as suggested, although I'm not sure I would have been brave enough to pound it like that when the spindle was still installed. There is some scoring to the spindle window from the drift. After all that beating it took before disassembly I think I have damaged the bearings. One of the outer races has marks from the rollers, the other seems to have worn unevenly, so I am considering if they should be replaced while the spindle is out.
13/09/2022 09:46:14 |
Photos for anyone interested: My attempts with the vice and wedges.
And the pulled quill with spindle and offending tooling |
11/09/2022 17:26:50 |
Posted by Howard Lewis on 26/08/2022 11:41:06:
Since you mention a M10 capscrew, presumably that is the nthreadv on your mdrawbar, and in the chuck that bis stuck. Being MT3, on an older machine, I would have thought that 3/8 BSW would be more likely. Nowadays, MT3 arbors tend to come with M12 threads. If you can manage to screw a capscrew into the chuck, in place of the drawbar, as others have suggested, you might be able to use the standard 3MT taper drift, through the slots in the quill to force the chuck ou. You may even have to apply force using your wedges and the clamp nut, and then follow up with giving a hearty whack with a mallet to the drift against the capscrew. The combination of a shock load added to a maximum static load MIGHT just break it free. (A suddenly applied load delivers twice the force of a gradually applied one. Howard Hi Howard, Thanks for your insight, I believe you are right, measuring the thread on the drawbar gives 9.48mm. I've probably got a 3/8 BSW hanging around with my 'old' lathe somewhere. I've been away from home for a while so did not have a chance to try any suggestions. I finished milling the wedges, doing a slot with much to high of a speed, 1000rpm and 3/4" cutter, which gave plenty of nasty chatter. I drove them in with my 'big' vice until I couldn't turn the handle anymore with all my body weight. I then gave the end of the spindle a few hearty wacks with a 3lb hammer. No change at all, the taper is still thoroughly stuck. The quill mechanism felt rough so I thought I'd strip the spindle and see if that gave me any ideas along the way. I've got the quill out without too much hassle, although not sure what to do yet. I'm in Didcot, Oxfordshire, if anyone is keen to give me a hand in person! |
26/08/2022 07:31:34 |
Posted by Tony Pratt 1 on 25/08/2022 22:22:52:
Are we there yet? Tony Not yet, I've started on the tapered wedges, I think an M10 socket screw would fit, I don't have hex bar but knowing that's an option if it does get stuck would be useful. Progress is slow, this is my first time on the mill and work is mostly consuming me at the moment. |
23/08/2022 17:00:04 |
Posted by Howard Lewis on 23/08/2022 16:06:55:
When you manage to get it out, IF you want, you can buy screw in tangs for 2Mt and 3 MT tooling. But obviously precludes the subsequent use of a drawbar. A drawbar prevents the holder m,dropping out. But it is not necessary to apply much torque to it. Running with the drawbar slightly loose, and cutting with an End Mill,as already suggested may shake the chuck loose. Some times it happens even when the drawbar seems to have been tightened sufficiently!. It may be that it will require some time milling just for the sake of it, so that the chuck and the quill heat up together , so that the interrupted cuts provide enough vibration to shake the chuck free. Howard Thanks, keeping a drawbar seems like the safer prospect, I'm keen to modify the spindle to make it self extracting if I can find a suitable design. I've been milling some wedge plates with the draw bar undone by a couple of turns. Most of the way through that now and no sign of it easing up. |
21/08/2022 18:10:18 |
There's a slot, I could put a drift in there so that the spindle is locked as Colin suggests. The taper is threaded, so no tang, I tried an MT4 drift but it touched the far side of the arbour before contacting the top of the taper. I drive a pair of drifts back to back in, but one of them got mauled up. |
20/08/2022 20:15:21 |
Posted by oldvelo on 19/08/2022 02:14:55:
Look for any signs of heat discoloured metal on the morse taper socket. By the amount of force used already it is possible that the mill has had the cutter stop and the spindle spin on the morse taper long enough to get red hot and when stopped has welded them solid. More likely the pervious owner used big long spanner to winch up the drawbar way too tight. Insert the morse taper of the tool half way into the socket then slap it firmly home. Advice I was taught Use the correct size spanner on the drawbar, Hold the spanner in your fingers put your thumb on the spanner at the centre line of the spindle. The amount of torque applied with the fingers is enough to hold the drawbar firm.
I can't see any heat damage on the outside of the spindle nose, but I'm far from a metallurgic expert. I'll take a pic next time I'm in the workshop and post it. |
20/08/2022 20:13:23 |
Posted by duncan webster on 19/08/2022 16:50:13:
If you are going to hit it again please arrange some packing between the bit with the female taper and the table. Putting impact loads through the spindle bearings is not good Hi Duncan, Thanks, I am worried about the bearings. I would really rather not have my first experience with a mill be to strip the spindle and change the bearings. I've only run it up to 300rpm so far and it's happy there, but can go to 2000rpm which I imagine is quite different and damage to the bearings would be much more apparent. The collet holder diameter is about the same as the spindle nose which makes it hard to get any support in there, once I have these wedges made up I can at least use them to support the spindle while smacking it. |
20/08/2022 20:06:38 |
Posted by Macolm on 19/08/2022 22:14:21:
If a lathe is available, I suggest making an aluminium or brass sleeve to be clamped up with the collet nut as before. It needs to be good and solid, and the nut tightened once again as hard as possible. If it only catches on the spindle by a little, make a steel support spacer and split it with a saw so that it can be fitted to support the sleeve, and both clamped.
Now run the spindle slowly, and heat the sleeve with preferably two blow torches to something like 250C. It needs to be as quick as possible so that only the sleeve gets hot. This should produce expansion of 20 parts per million times 200C – about 4 thou per inch. A medium thump on the drawbar at the same time is worth a try. Thanks, I have a lathe, a very old drummond. It's a bit of a chore to use and it's 3/4" spindle thread limits it's duty a lot. With patience I could make this out of brass or aluminum. I've also got a Smart and Brown Model A, which I imagine would do this in a blink, but it's not running yet.
I've started milling out the plates to make the wedge as suggested by other posters. This is my first time on a mill so taking things slow. I've squared them up, with the drawbar loose, and it hasn't dropped yet! Ready to put the taper on them now, have to work out how to hold them to get a repeatable angle. |
17/08/2022 21:08:48 |
Posted by Swarf, Mostly! on 17/08/2022 13:47:50:
Good afternoon, Matthew, I just want to make a plea that, when you do solve your problem (soon, I hope ), you will tell us and advise just which method eventually brought success. Best regards, Swarf, Mostly! Thank you, I shall, I'm grateful and a bit overwhelmed by the explosion of responses.No luck this evening,, tried drawing it out with the collet nut. I haven't run the machine yet so got about giving that a go before rigging up some wobbly milling setup. Plugged it in, pushed 'forward', and nothing. It turned out that there's a post, which I think is meant to hold a guard, which was interlocked. I didn't get the guard so bypassed it and now it's working but it's a bit late to continue exploring. Fortunately my electrical knowledge exceeds my mechanical. |
17/08/2022 21:04:44 |
Posted by colin hawes on 17/08/2022 12:41:39:
Use the collet holder nut to apply force on tubular packing between nut and spindle nose. Colin
I gave this a go, I found an odd backplate that came with a lathe that happend to have the right ID and screwed it up above the collet nut with a couple of milling clamps as spacers against the spindle. I got it pretty tight but had to hold the belt drive on the top of the spindle to stop it rotating so this limited how much force I could put into it. No joy unfortunately. |
17/08/2022 21:01:40 |
Posted by Robert Atkinson 2 on 17/08/2022 12:57:51:
If you can get some, dip the end of the collet holder in a polystyrene cup full of liquid nitrogen. I used to get it from a local frozen food supplier..... Robert G8RPI. As it happens my workplace does have (a lot) of liquid nitrogen. I'm not sure how happy they'd be lending me a dewar though! |
16/08/2022 21:38:45 |
Posted by Andrew Johnston on 16/08/2022 21:26:06:
Repetitive taps on opposing sides with a hammer; doesn't need to be hard but you may need a lot of taps. Repetitive, and oscillatory, side loads are a classic way of loosening a taper. Which is why it isn't recommended to mill without a drawbar. Andrew That sounds like something I can tinker away with. Any idea how many / how long I'd need to do this for before I find it will release? Should I try the odd tap on the drawbar as I go? |
16/08/2022 21:37:13 |
Posted by Pete Rimmer on 16/08/2022 21:28:02:
Loosen the drawbar and start cutting it'll soon come loose then Err, is that safe? |
16/08/2022 21:20:04 |
I've recently got a used Warco Major Mill/Drill. I've had it in pieces and have just put it back together. When I picked it up there was an ER32 collet holder in the MT3 spindle, I think it's been in there a while. I tried the obvious step of loosening the drawbar bolt and giving it a tap with a small hammer but it didn't budge. Since then I've tried a bunch of things, still with no luck:
My failed attempt with the spanner, I'm worried that the force, particularly and non-downwards component, could have damaged the mill. I've bought a larger drift which is in the post, although don't expect much from that. Apart from heating the spindle and using a drift / hitting the draw bar, I don't know what else I can do.I don't own a hydraulic jack but even if I did I don't know how I'd apply while the spindle is still in the mill. Does anyone have further suggestions? |
14/08/2022 14:27:59 |
Hi, sorry it's been a while; I've still not taken the apron apart but will soon I think. I've got a stack of original manuals and parts drawings and a brochure for the Model A, I'm happy to scan them to a pdf and upload if that's allowed and there's a demand for them. I've also found the sheer pin on the first change gear had snapped when I looked under the cover, so need to make/source one. |
20/07/2022 09:54:33 |
Posted by old mart on 20/07/2022 09:31:09:
You can remove the apron cover with care for assessment. Remove the leadscrew lever, one grubscrew, woodruff key and slacken off the threading dial friction adjuster (that grubscrew shown in the picture, then remove the dial). Remove the fine feed lever (taper pin small end at bottom). Remove the main wheel and woodruff key which moves the saddle. There are 5 SHCS holding the fromt on and when they are removed, carefully use a thin blade to work it off the dowel pins. The 2 dowels are top right and bottom left. If you do need to remove the plate at the bottom, make sure that the front lefthand screw is the short one, as it intersects with the screw holding the front on. Post a picture of the mechanism. Thanks! It may be a few days before I can get around to it, work is busy and I'm babysitting this weekend. Do I need to drain the oil before pulling the plate? |
19/07/2022 22:02:09 |
I wonder if the half nut lever (top right) is working properly. I can see the half nut around the side of the apron, it engages and disengages nicely. You do of course have to catch the thread right. The Smart & Brown model A Mk 1.5 at the museum has had the fine feed sort of working for years until about a couple of months ago, when the lever would not engage ... we took the apron completely off and partially dismantled it. Oh dear, I'd hoped not to have to do that. There's the bolts around the front plate, can you remove the handles and leavers and then take the front plate off the apron without removing the lead and feed screws? The lockout between lead and feed seems to kinda work, I can lift the feed lever and it clonks into place, if I then push the leadscrew leaver it drops the feed lever back down. When the leadscrew's engage I can't toggle the feed lever. I tried slackening the bolts through the top of the saddle and wiggled things about with no change. I removed the black handle, the play I felt was only in the handle, the shaft doesn't seem to turn at all. I assume that the casting behind it comes off but it didn't want to budge from a gentle tap. |
18/07/2022 15:04:56 |
Hi Martin, thanks, I did give that all a try already, gently wiggling all the slides and also the leadscrew and fine feed 'screw' while attempting to turn the knob and also while engaging and disengaging the fine feed lever. I also tried turning the knob as hard as I could by hand but it wouldn't budge. |
