Steve355 | 30/07/2022 11:50:47 |
321 forum posts 235 photos | Hi all I picked up an Eagle surface grinder from eBay. It was pretty mucky, so en route to the shed I took it to bits, cleaned it up, rubbed it down and gave it a coat of paint. Now I can see what I have it doesn’t look in bad nick, and I can make sure it’s properly lubricated as it goes back together. Then the DTI will tell me what I really have. A couple of questions… When I loosened the gibs, a number of small wires fell out, I’m not sure exactly from where, but they look like they were used to adjust the ways, or two reduce movement. Picture below, can anybody explain what these before and how I can reinstall them? Second, the bellows were completely shot. They are not really installable. I found some reasonably priced bellows on eBay, but they are simply flat and the original bellows had 90° bends to wrap around the ways. Does anybody know whether these kind of bellows can be modified to work better with the machine? https://www.ebay.co.uk/itm/195174551731?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bap--a-2t-y&sssrc=2349624&ssuid=yn_RRMPtS_W&var=&widget_ver=artemis&media=COPY Cheers Steve
Trevor Drabble | 30/07/2022 14:18:58 |
![]() 339 forum posts 7 photos | Steve , For your bellows , I would suggest you try Arc Eurotrade or Machgard in Rotherham . |
Tony Ray | 30/07/2022 15:02:38 |
238 forum posts 47 photos | Hi Steve, I too have recently acquired an Eagle but I have not yet stripped it down. I am sure however that those wires are not original to the machine, and are therefore a bodge to compensate for wear, I would suggest that properly shimming the gibs is the way forward or making new ones. Shims could be cemented to the backsides ( i.e. the side that does not contact the sliding surface. With that amount of “shimming” I would be prepared for the ways to be worn unevenly. I’m not saying this is a disaster only any ~70 or so year old machine one has to be prepared for these things. How far you go as regards rebuilding will depend on what you want to achieve and how much time you can put into it. I would address the shimming and as you say see how it performs. Tony |
Kiwi Bloke | 31/07/2022 00:00:59 |
912 forum posts 3 photos | I have a Superior surface grinder, which is very similar, and doesn't contain such 'wires'. I'm sure Tony Ray is correct. 20 years ago, when I was in UK, there were a few bellows suppliers, with a wide range of off-the-shelf sizes and shapes. Some were prepared to make 'specials'. I expect the price would be alarming... |
not done it yet | 31/07/2022 07:38:29 |
7517 forum posts 20 photos | I dismantled mine to move it. Those pieces of wire should not be there. Your machine may need a fair bit of attention, to get it working satisfactorily! |
Steve355 | 31/07/2022 08:58:14 |
321 forum posts 235 photos | Hi all Tony - interesting you are doing a similar project at a similar time! I got it running for the first time yesterday and overall was pleased with the finish result, considering I hadn’t yet dressed the wheel or even really done any adjustment other than tightening it all up. There were some very light marks on the finish that looked to me might be caused by the ratchet mechanism for the table - something worn must be causing that. I put a clock on the table and it showed 0.0005-0.001 deviation across most of its length left to right, but headed off a cliff (!) of a few thou at the right hand end. Clearly that needs to be looked into. Interestingly I discovered that This Old Tony’s surface grinder refurb video on YouTube is him restoring a Capco grinder. I didn’t even know they had them over there. He identifies all the areas of problem and scrapes the bed to fix it. I’ve played with scraping and have a few scrapers but never done it in anger. Let’s see how it all shapes up first. I’m sure I’ll probably be posting about it for weeks. Steve
Steve355 | 31/07/2022 09:59:31 |
321 forum posts 235 photos | So, after a bit more playing with it this morning, a couple of things are apparent. The clock needle vibrates slightly as is moved left to right, as I suspected, seems like the rack and pinion are meshing too much, or the gibs on the work table are not stable enough. It all looks nice and stable as I move the table left to right, +/- 0.00025 until it gets to about 3/4 movement then it falls off the cliff of about 0.003. BUT when I move the table back leftwards it does not return to zero. This to me seems like the Z axis is not stable and I need to concentrate on that. When the table is at one end the weight of the table is moving the Z axis. Im pretty sure I can see it moving slightly. So back to basics, get the Z axis stable and tracking correctly, followed by Y, followed by X. Anyone got any better ideas? Skip not ordered yet. Edited By Steve355 on 31/07/2022 10:02:06 |
peak4 | 31/07/2022 12:22:25 |
![]() 2207 forum posts 210 photos | Steve, if I can sort one, so can you. At 3 thou yours is a lot better than the little Herbert junior I picked up cheaply, which tailed off by about 12 thou. |
Pete Rimmer | 31/07/2022 13:07:01 |
1486 forum posts 105 photos | Posted by Steve355 on 31/07/2022 08:58:14:
Hi all Tony - interesting you are doing a similar project at a similar time! I got it running for the first time yesterday and overall was pleased with the finish result, considering I hadn’t yet dressed the wheel or even really done any adjustment other than tightening it all up. There were some very light marks on the finish that looked to me might be caused by the ratchet mechanism for the table - something worn must be causing that. I put a clock on the table and it showed 0.0005-0.001 deviation across most of its length left to right, but headed off a cliff (!) of a few thou at the right hand end. Clearly that needs to be looked into. Interestingly I discovered that This Old Tony’s surface grinder refurb video on YouTube is him restoring a Capco grinder. I didn’t even know they had them over there. He identifies all the areas of problem and scrapes the bed to fix it. I’ve played with scraping and have a few scrapers but never done it in anger. Let’s see how it all shapes up first. I’m sure I’ll probably be posting about it for weeks. Steve Don't presume that because the table moves the needle when it's moved to it's extremes of travel it's because there's wear in the table. It might be that the weight of the table being transferred from one side to the other is causing movement in the Y-axis or Z-axis ways.
Steve355 | 31/07/2022 13:24:40 |
321 forum posts 235 photos | Don't presume that because the table moves the needle when it's moved to it's extremes of travel it's because there's wear in the table. It might be that the weight of the table being transferred from one side to the other is causing movement in the Y-axis or Z-axis ways.
Pete - yes that’s exactly what I’d surmised. And that’s why I need to take a step back and start from the beginning, measuring the Z axis to make sure it is working acceptably, there is a lot of evidence of scraping on the Z axis ways, so I’m hoping that at least that part is in reasonable nick. Steve |
Steve355 | 31/07/2022 13:38:32 |
321 forum posts 235 photos | Posted by peak4 on 31/07/2022 12:22:25:
Steve, if I can sort one, so can you. At 3 thou yours is a lot better than the little Herbert junior I picked up cheaply, which tailed off by about 12 thou. Hi Bill, thanks for your post - very inspirational. Your Flickr album too was really interesting, all the setups you devised to measure the different dimensions and angles too. As for my equipment, I basically have a 12x18” cast iron surface plate and a bunch of DTIs, mics etc.I have a Dore Westbury mk 1 and a Burke #4 horizontal, both of which work ok but part of the point of getting a surface grinder was that I would be able to sort them out properly. My question is, having done this, where would you start? I don’t want to do any work that isn’t required, but I do want to do the work that is required, if you see what I mean. I’m thinking I strip back to the Z axis, indicate that and see how it is. If it’s fine, all well and good, if not, then that’s where I need to start. Steve |
peak4 | 31/07/2022 14:42:34 |
![]() 2207 forum posts 210 photos | In my case, the wear was so much on the main table and the top of the knee, that it was the obvious place. Edited By peak4 on 31/07/2022 14:46:38 |
Steve355 | 31/07/2022 21:41:13 |
321 forum posts 235 photos | Thanks Bill, seems like the place to start is the table then. On the surface plate I can’t get a 0.0015 feeler gauge under it anywhere, so I guess I can assume it can be used as a reference surface, I don’t want to resurface that unless I have to, I’ve started to take readings along the bearing surfaces and the worst it gets is about 0.004 with the expected dip in the middle. One problem I have is that I don’t really have a proper stand for the DTI. I’m using a height gauge attached magnetically, but I’m not confident that if I move it to measure the other side, it won’t wobble. I can’t seem to find a suitable stand on RDG/Chronos. I have a few old eclipse scrapers I bought from eBay. I doubt they are carbide, but I expect they were perfectly usable once upon a time, one has a rounded end but I could easily grind it more flat. Do I really need to invest in a carbide scraper? Are they that much better ? |
Tony Ray | 31/07/2022 22:17:45 |
238 forum posts 47 photos | Steve, it’s good that you have some scraping experience. What you also need to gain is a feel for surface grinding and knowing what your machine is capable of delivering in terms of surface finish. A 46 grit wheel will do pretty much any task, unlike finer grit abrasive paper finer wheels will not necessarily give a better finish. Washing soda in water is said to make a good coolant and I was advised not to rush into grinding the magnet as this takes some skill do do well. Dressing the wheel is a must, balancing is said to have minimal effect on the diameters of wheel used on this and similar grinders, my view is if you can balance it why wouldn’t you? Once you have resolved the gib issue I would grind some test pieces, typically 5 pieces of the same material eg 1” dia. are ground on one side then flipped, they are arrange one on each corner of the magnet and one in the middle. There should be no difference in thickness. I would mark the so you know this position on the table and orientation as this may give you a clue as to which axis is most worn. if you have not come across the Machine Rebuilding Scraping and Inspection forum on Practical Machinist it is a great resource. |
peak4 | 31/07/2022 22:36:17 |
![]() 2207 forum posts 210 photos | I'm absolutely no expert in scraping at all, so wait until someone more experienced comes along to check anything I suggest. Edited By peak4 on 31/07/2022 22:39:17 |
Steve355 | 31/07/2022 23:18:14 |
321 forum posts 235 photos | I basically saw some scraping coming on one project or another, so I got a few old scrapers from eBay, and practiced on some mild steel. It worked ok, was interesting to watch the blue spots spreading as the piece flattened. But that’s all I did really, and yes I was regularly honing the edge. You are correct that the larger scraper it for curved surfaces but I can grind it square. I think I may have a flat bar DTI holder somewhere that would allow me to attach it to the height gauge. Perhaps tomorrow I can start!
Steve355 | 03/08/2022 21:19:19 |
321 forum posts 235 photos | This scraping business is not as much fun as I had imagined! It’s very slow going its difficult to get into tight spots I watched a video on YouTube where the chap measured the depth of the scrape at up to 0.0005. If only, I can see why this old Tony started by milling his, I have to take off up to 0,005 in some places. Perhaps it’s time for that long carbide scraper, if I can find one.
Tony Ray | 03/08/2022 21:35:43 |
238 forum posts 47 photos | Yes it’s hard work. You can make the scraper. I bought a Sandvik insert & made the rest. The inserts is very hard wearing but you will need a way of lapping it. There is a knack to it once you have it it does get a bit easier. Someone mentioned C19 carbide I’d be interested to know where they bought the blank. |
Pete Rimmer | 03/08/2022 21:36:33 |
1486 forum posts 105 photos | Yep it's slow and hard work but going too far isn't as easy as you at first think.. Half-thou deep scrapes are not normal more like 2 tenths. So if you think that you'd have trouble milling off only 1 thou of cast iron, that's a good 4-5 rounds of scraping. What tight spots are you trying to get into? Ways inherently have open ends so I guess you must mean a dovetail? If so then just get yourself a big mechanical hacksaw blade and use it manually to cut a healthy relief in the corner. Like most things there are a number of ways of doing this stuff. What I would advise is don't strive for perfection. So what if you dig a few double-depth holes in the work? It'll still function as intended. So what if the best flatness you can achieve is 1 thou? That's 5 times better than the 5 thou you have now. |
peak4 | 03/08/2022 21:58:03 |
![]() 2207 forum posts 210 photos | Posted by Tony Ray on 03/08/2022 21:35:43:
Yes it’s hard work. You can make the scraper. I bought a Sandvik insert & made the rest. The inserts is very hard wearing but you will need a way of lapping it. There is a knack to it once you have it it does get a bit easier. Someone mentioned C19 carbide I’d be interested to know where they bought the blank. Twas me that mentioned C19 as an early adopter, but that's an abbreviation for Covid, not a grade of carbide. |
