Michael Callaghan | 13/07/2022 17:45:26 |
173 forum posts 7 photos | Hi, the control board on my Wabeco d3000 lathe has gone bad. Wabeco no longer carry parts for the lathe so I am at a bit of a loss what to do. The motor is rated at 1.4kw but that’s the only information they give. I take it that it’s dc motor but can’t be sure. There is no label on the motor itself. So my question is would the motor be dc ? Is there a control unit I can buy to bypass the old board. Or is there a motor upgrade that would suit. Thanks. Michael |
not done it yet | 13/07/2022 17:47:30 |
7517 forum posts 20 photos | I expect so. Change it for a 3 phase motor with VFD. A far better system. |
John Haine | 13/07/2022 17:59:37 |
5563 forum posts 322 photos | Does it have brushes? If so it's a dv commutator motor. Several companies supply industrial drives suitable, Google KBE. But the motor might be a bit elderly and the brushes needing replacing anyway in which case a 3 phase motor and VFD upgrade would be a good approach. |
Michael Callaghan | 13/07/2022 18:21:28 |
173 forum posts 7 photos | Thanks chaps |
SillyOldDuffer | 13/07/2022 19:01:37 |
10668 forum posts 2415 photos | Here's the circuit diagram from the manual: Assuming the problem isn't confirmed by magic smoke from a cooked control board! The manual says the brushes should be sanded down every 100 hours and the commutator cleaned. Plus advice to check in the event of a stoppage that the plugs and sockets haven't vibrated loose. If that's been done, I'd check the usual other mini-lathe weak-spots before rushing to change the motor or board:
The manual says the motor is single-phase, and the circuit shows 8 connections:
The claim to be a single-phase motor might make sense if this was a simple triac triggered speed control circuit, but I don't understand what the brushes are for. They suggest a DC motor, or is there a type of AC motor with brushes? Dave
Robert Atkinson 2 | 13/07/2022 19:26:40 |
![]() 1891 forum posts 37 photos | A motor with brushes, a commutator (segmented rotor contacts) and a wound stator (not permanent magnet) will run on AC or DC. For this reason they are often called a "universal" motor. Robert G8RPI. Edited By Robert Atkinson 2 on 13/07/2022 19:27:20 |
SillyOldDuffer | 13/07/2022 19:33:53 |
10668 forum posts 2415 photos | Posted by Robert Atkinson 2 on 13/07/2022 19:26:40:
A motor with brushes, a commutator (segmented rotor contacts) and a wound stator (not permanent magnet) will run on AC or DC. For this reason they are often called a "universal" motor... Doh, is it that simple? In my defence, the spec says it's a 1.4kW motor, which I assumed is too big to be a Universal. Don't know why though, except I've only come across Universals on sewing machines and small power tools up to about 250W max. Dave
JasonB | 13/07/2022 19:34:24 |
![]() 25215 forum posts 3105 photos 1 articles | The two "W" connections are more likely to be the windings and the "K" connections brushes as Kohlenstoff is German for Carbon |
Ian P | 13/07/2022 22:43:04 |
![]() 2747 forum posts 123 photos | Posted by SillyOldDuffer on 13/07/2022 19:33:53:
Universal motors appear on angle grinders, vacuum cleaners, SDS drills and jack hammer things, I'm sure I have seen some rated well over 1kW. Ian P |
John Haine | 14/07/2022 07:22:20 |
5563 forum posts 322 photos | Almost certainly a wound field DC motor, commonly used for larger sizes rather than permanent magnet field. Many controllers have an output to drive the field winding. A series wound motor is very unlikely in a lathe because it's speed torque curve is very unfavourable. |
Michael Callaghan | 14/07/2022 12:04:53 |
173 forum posts 7 photos | Thanks again. |
