How to achieve a clean edge when shortening small screws using a Dremel Cut off Blade Dremel EZ S
Greensands21/06/2022 20:49:34
449 forum posts
72 photos
I am using a Dremel 38mm EZ SpeedClic cut-off wheel to shorten 8BA steel screws to size but the leading edge is throwing up a burr preventing an easy running fit onto the test nut. The problem can be overcome by running the screw into an 8BA die but I have never had to to do this when using a piercing saw as the resulting cut face is always clean and free to accept the test nut. Am I using the wrong type of cut-off blade or is there something else I should be aware of? The srew is being firmly held in a dedicated chuck with zero wobble.
DiogenesII21/06/2022 21:05:10
859 forum posts
268 photos
I assume you are running the spindle, i.e. the screw is rotating..
If you can you swing the Dremel over slightly ( I mean ever so slightly) to give a (barely) convex top to the end of the screw, it ought to clean it up as it goes..?
PS I use these wheels to 'nick' and shape HSS / carbide - if your steel is a bit soft, try slowing the Dremel a bit..
Edited By DiogenesII on 21/06/2022 21:07:43
Greensands21/06/2022 21:25:29
449 forum posts
72 photos
The screw in the chuck remains stationary, the Dremel being run at high speed to provide the necessary torque without stalling the motor.
Andrew Johnston21/06/2022 21:35:05
7061 forum posts
719 photos
Make a plate of the same thickness as the wanted screw length. Drill and tap 8BA holes, insert screws and file to length. The end of the screw is automatically cleaned when the screw is unscrewed.
bernard towers21/06/2022 21:36:54
1221 forum posts
161 photos
As DII says rotate the lathe spindle it should help. Why not use a chamfer tool. I shorten 12 and 14 ba screws and finish off with a chamfer tool and have occasionally used a graver but it takes a bit of practice.
Paul Lousick21/06/2022 23:20:37
2276 forum posts
801 photos
Why not take off the burr and add a small chamfer with a fine tooth or diamond file ?
Hopper22/06/2022 00:39:23
7881 forum posts
397 photos
Put a nut on the screw before cutting then screw it off after.
Edited By Hopper on 22/06/2022 00:39:53
Dave Halford22/06/2022 11:21:11
2536 forum posts
24 photos
Rotating the screw by hand with the chuck key whist feeding the Dremel will do way with the burr
Greensands22/06/2022 15:42:03
449 forum posts
72 photos
Hi Dave - Just tried out rotating the screw by means of a mandrel mounted handle whilst running the Dremel which has given a burr free end face with easy acceptance of the test nut. Problem solved I would have said. Thanks for the tip.
