Cylinder drain cocks
John Rutzen15/06/2022 15:23:39
411 forum posts
22 photos
Well here's a problem. I thought I would make a batch of cylinder drain cocks, they are quite expensive to buy and I had all the materials to hand. There are drawings of them by LBSC, Martin Evans and Don Young and probably more. I have come unstuck though trying to make the brass washers with 5/64 square holes in them. I made and ground a punch on my Quorn and tried to square up the holes in 10ba brass washers but the things just stretch and even split. So has anyone successfully made cylinder drain cocks?
Incidentally I notice that in most of these descriptive articles there's no end of descriptions about how to machine a wheel, an axle or simple things but they never seem to mention the tricky bits like these drain cocks or bending the curved flare on the top of a tender side.
roy entwistle15/06/2022 15:49:24
1716 forum posts
Small square files for filing holes in watch hands can be obtained from the likes of Cousins or Walshes
They are certainly smaller than 5/64 and about 2 1/2 inches long
Roy
Dave Wootton15/06/2022 15:51:37
505 forum posts
99 photos
Just an idea, and I must stress never tried it, but if the washers split could you use a short length of brass rod with an o/d larger than the finished washer drill and punch the square hole then turn down to the required o/d and part off as many washers as required. Sounds like the washers are too fragile for the biff required, might be better to make a simple broach, which could be filed by hand.
Just seen Roy's post above, didn't realise you could buy needle files that small, they would probably be the thing.
Edited By Dave Wootton on 15/06/2022 15:53:33
John Olsen15/06/2022 15:51:51
1294 forum posts
108 photos
I was going to say that I would probably try to file them, but Roy has beaten me to it.
Luker15/06/2022 16:40:37
230 forum posts
172 photos
Trick is to have a lead-in and the slightest of undercut behind the cutting edge (basically just to remove the cutter radius)...
Luker15/06/2022 16:41:29
230 forum posts
172 photos
A different washer for stops...
Luker15/06/2022 16:45:14
230 forum posts
172 photos
Posted by John Rutzen on 15/06/2022 15:23:39:
I think you'll enjoy my construction series(s) laugh
roy entwistle15/06/2022 16:55:23
1716 forum posts
Just a further thought. If you consider how washers are made ie. by punching, they will work harden. try annealing
particularly in brass
Roy
noel shelley15/06/2022 18:45:02
2308 forum posts
33 photos
Spark erosion will do jobs like this with ease ! Noel
Howard Lewis15/06/2022 22:28:04
7227 forum posts
21 photos
The washers will stretch because they are nit restrained, The washer needs to be compressed, hard, between two surfaces before the punching operation.
duncan webster15/06/2022 23:36:46
5307 forum posts
83 photos
Or in a recess in a bit of bar? That would stop them expanding.
Nick Clarke 316/06/2022 09:45:30
1607 forum posts
69 photos
Alternately why not go automatic and do away with the need for washers and the (usually) difficult and easy to damage linkage to operate them?
John Rutzen17/06/2022 09:25:20
411 forum posts
22 photos
Thanks for the replies everyone, for some reason i didn't get notified. I've done them by turning them from 3/16 brass rod. This was strong enough to take the stress. It also meant I could make them about 1.2 mm thick. I have tried automatic ones but I like another lever to fiddle with! I'm making a Jeannie Deans compound so I will have plenty of levers. Thanks for the pictures Luker, I do like your articles having done some castings myself including iron wheel castings and I make my own boilers.
John Rutzen17/06/2022 09:28:26
411 forum posts
22 photos
By the way Luker, how do you cut your threads right up to the hex? That's another pet peeve of mine, drawings with threads right up to the hex and no mention of how to achieve it.
julian atkins17/06/2022 09:28:45
1285 forum posts
353 photos
I use 2 x 10BA nuts locked together.
Cheers,
Julian
Luker17/06/2022 11:37:15
230 forum posts
172 photos
Posted by John Rutzen on 17/06/2022 09:28:26:
Hi John, my home made dies have the lead-in on the one side only, then the other side cuts all the way to the head, but this is saved for only the end operation as it blunts quicker. My cheap dies have one side ground to the first full thread (carefully/slowly to avoid damaging the temper). My ME dies were a gift from an old friend so they aren't ground. When using those dies I use a tiny grooving tool (I made by soldering a piece of broken slitting disk to some MS) to cut a groove at the end of the thread. I plunge 90% of root depth and the tool thickness is roughly 1mm. When tightening, the female part completes the thread and seals nicely...
