modeng2000 | 12/05/2022 11:58:57 |
340 forum posts 1 photos | My barograph mechanism has a fair amount of 'stiction' in the pen movement and so I wonder if replacing the simple sleve bearings for point bearings as used for escapement wheels would be worth doing. |
Brian Wood | 12/05/2022 12:08:24 |
2742 forum posts 39 photos | You may well be right Brian |
modeng2000 | 12/05/2022 12:31:03 |
340 forum posts 1 photos | Brian, it would be fairly easy to make the change and to revert if no improvement. So I think if it might help I should try. Just wasn't sure it would help. John |
Brian Wood | 12/05/2022 13:51:48 |
2742 forum posts 39 photos | John, I don't think you have anything to lose by trying your ideas out. It might be instructive to look at other instruments of this type to see how they have dealt with suspension matters; the forces acting on the device that is trying to trace the changes in barometric pressure will not be high and plain sleeve bearings will demand some of that as you suspect. You might be pleasantly surprised at the result Brian |
John Haine | 12/05/2022 13:51:58 |
5563 forum posts 322 photos | I think you mean "balance wheels" (sorry, inner pedant at work!). It might help just to dismantle, clean and oil the bearings. |
modeng2000 | 12/05/2022 14:18:13 |
340 forum posts 1 photos | Joohn, Yes of course I mean balance wheels, sorry. I have tried to upload a photo but alas failed miserably. The linkage is very basic, just pins through holes. So I think where a 2.5mm dia brass rod passes through two clearence holes in a pair of uprght posts is possibly where some of the sticking is taking place. (I did manage to place a picture on the Home Model Engine Machinist site) John |
gerry madden | 12/05/2022 14:32:41 |
331 forum posts 156 photos | One of the interesting characteristics of PTFE is that its static friction is the same as its dynamic. This helps avoid 'stiction' issues. Not sure if you would be able to work this in to your application... it might make things too big and therefore might increase friction to above what you already have, so perhaps the balance wheel pivot is better. Gerry |
Dave Halford | 12/05/2022 14:46:46 |
2536 forum posts 24 photos | The chart recorders at BT used a simple balanced pen similar in construction to a Lenco record player arm suspension. A vee shaped cutout balanced on knife edge. No pen arm sleeve bearings at all. |
David Jupp | 12/05/2022 14:47:21 |
978 forum posts 26 photos | I seem to recall from University materials classes that for PTFE friction increases when direction of movement changes, so it isn't as good as you'd expect in oscillating systems. If movement is always in same direction friction remains low - almost as if there is a 'nap' on the surface that has to brushed into place by initial movement. |
Swarf, Mostly! | 12/05/2022 17:02:50 |
753 forum posts 80 photos | Long, long ago, someone told me that instruments for motor car dashboards used crude pivots for the sake of ruggedness and longevity but relied on the vibration when the engine was running to vercome the friction. If you can bear it, strap a buzzer to your barograph! Best regards, Swarf, Mostly! PS: OK, OK, I know that opening sentence is too long, sorry. |
gerry madden | 12/05/2022 17:32:23 |
331 forum posts 156 photos | David, I didn't know that about oscillating movements. Interesting. I had planned to use in a clock escapement, perhaps I wont now There is another material with similar CoF, called Vespel. Do you have any experience of this ? Apologies if this is a thread hijack. Gerry |
modeng2000 | 12/05/2022 17:33:18 |
340 forum posts 1 photos | "If you can bear it, strap a buzzer to your barograph! " This is something I had considered but it would have to be clockwork!!
David Jupp | 12/05/2022 17:48:42 |
978 forum posts 26 photos | Gerry - I've heard of Vespel, but have zero experience of it. I also seem to recall that PTFE gives lower friction if there is at least some moisture (humidity) around - strange given that it was allegedly developed for the space programme... |
Andy Stopford | 12/05/2022 19:35:48 |
241 forum posts 35 photos | Posted by David Jupp on 12/05/2022 17:48:42:
I also seem to recall that PTFE gives lower friction if there is at least some moisture (humidity) around - strange given that it was allegedly developed for the space programme... The space programme thing is a myth - PTFE was discovered (more or less by accident) in the thirties. Its first notable use was in the Manhattan Project to protect the plumbing of the Oak Ridge Gaseous Diffusion Plant from the corrosive effects of Uranium Hexafluoride. Interesting about the poorer performance for oscillating systems. I wonder if its the same for other slippery plastics like nylon and acetal. |
bernard towers | 12/05/2022 21:06:49 |
1221 forum posts 161 photos | And the countries last Barograph and Barometer maker is closing for good next month after something like 175years!!! |
Robert Atkinson 2 | 12/05/2022 21:57:58 |
![]() 1891 forum posts 37 photos | Swarf's comment on a buzzer is spot on. Many aircraft altimeters (basically aneroid barometers) have internal buzzers to overcome stiction. Altimeters have very good bearings but stiction is still an issue. Robert G8RPI. |
modeng2000 | 13/05/2022 07:15:15 |
340 forum posts 1 photos | So I suppose Bernard, these will now be made abroad like a lot of other things these days. Which company is about to stop trading? Robert, so this is why folk tap the barometer as they pass by watching it settle to the current reading. A barometer really indicates the pressure when requested by giiving it a tap however the barograph normally sits on its own most of the time so stiction becomes a problem. I have started the modification so hopefully I'll find an improvement. An electronic device is the answer but finding one with a printed chart output is another matter and it would need an electric supply not just a spring. Thanks for the suggestions to my question. John |
Michael Gilligan | 13/05/2022 07:31:49 |
![]() 23121 forum posts 1360 photos | Posted by modeng2000 on 13/05/2022 07:15:15:
So I suppose Bernard, these will now be made abroad like a lot of other things these days. Which company is about to stop trading? . … which reminds me to ask you, John: What barograph are you using ? MichaelG. . P.S. __ a recent eMail from Jeffrey Formby Antiques mentioned this book, which might be of interest: http://www.barosbooks.co.uk/b.html
Edited By Michael Gilligan on 13/05/2022 07:50:15 |
modeng2000 | 13/05/2022 09:10:51 |
340 forum posts 1 photos | Michael, it is a dome barograph by Russel Scientific. Quite compact and I believe this has compromised the design by being enclosed in a 4"dia by 6" tall glass dome. The Philip Collins book looks really interesting, thanks for the link. John |
modeng2000 | 13/05/2022 10:16:47 |
340 forum posts 1 photos | There is another possible reason for the pen sticking, as this is a small barograph the chart length is shorter than for a normal barograph therefor the distance the pen moves across the chart is also shorter so giving less chance to unstick as compared to a full size barograph.. John |
