Acme or not?
Odd thhread
Stephen Follows26/04/2022 18:32:08
119 forum posts
I’m restoring an old vice. The screw looks like an Acme in all respects. Problem is I can’t find it in tables. It’s 7tpi x 0.54 inch diameter.
Tables go from 6 tpi to 8 tpi, no 7.
I need to make a new spindle and have no idea what change gears to use on the lathe. Anyone come across this thread before? It’s Swiss made BTW.
not done it yet26/04/2022 18:59:57
7517 forum posts
20 photos
Are you sure it is not metric? Swiss made, so likely?
JasonB26/04/2022 19:02:53
Diameter falls within TR14 max/min but pitch is between the usual 3 or 4 mm
DC31k26/04/2022 19:06:00
1186 forum posts
11 photos
If it is Swiss, is there a possiblity it could be metric, trapezoidal form? The dimensions are not so far off 14 x 3.5mm pitch.
How are you measuring the pitch? If you measure over 21 threads, do you get exactly 3 inches?
You would have to tell us what lathe it is in order for us to advise on gears.
not done it yet26/04/2022 20:18:09
7517 forum posts
20 photos
Posted by JasonB on 26/04/2022 19:02:53:
Yes, 3.5mm near as dammit isto swearing.🙂
Michael Gilligan26/04/2022 22:10:09
23121 forum posts
1360 photos
Rumour [or at least a discussion on hobby-machinist] has it that the Kurt D60 screw is 7tpi stub ACME
https://www.hobby-machinist.com/threads/harden-kurt-vise-screw-threads.24385/
