David Jenner | 21/04/2022 13:38:44 |
31 forum posts | Ok, hands up, full disclosure, I messed up making the beam linkage on the Elmers 24 engine, drilling that 1/8 by 1/32 strip was my undoing! Does anyone know where I can get some replacements. Looking to get 12" or more (to allow for more learning oppurtunities!) Regards Dave Jenner |
Bizibilder | 21/04/2022 14:20:39 |
![]() 173 forum posts 8 photos | K & S Metals - from modelmakers hobby shops do 1/4" by 1/32" by 12" long which could be cut down. Otherwise you will need to buy suitable sheet and cut a strip from it. Edited By Bizibilder on 21/04/2022 14:21:12 |
bernard towers | 21/04/2022 14:49:04 |
1221 forum posts 161 photos | Why can't you silver solder the holes up and start again?? |
David-Clark 1 | 21/04/2022 15:38:14 |
![]() 271 forum posts 5 photos | K&S metals. Do you haven a mill? If so, clamp a bit of aluminium strip in the vice, clamp the brass on this piece of strip with another aluminium strip on top using a toolmakers clamp. Drill the holes and carefully drill the holes. Then mill round the edges to size. Remove aluminium, job done. I have done 0.1 mm shims like this. |
