Calum Galleitch | 22/03/2022 20:51:54 |
![]() 195 forum posts 65 photos | I don't want or need to go full DRO on my lathe, but I do want to be able to drill holes with a cross-drilling fixture in the cross-slide into a workpiece held in the lathe. These things seem ideal for the job and should be more than accurate enough: Warco, whose picture above I have, ahem, borrowed, are sold out of the 1000mm length ones and I can't find one anywhere else at close to the price. eBay doesn't seem to have such a thing under £130, and Aliexpress has something a good bit cheaper but with extraordinary shipping costs. Can anyone suggest cheaper options? (I know I probably don't need a 1000mm slide on a ~1m bed, but it will look tidier and give me more options for mounting, and, well, easier to make a long thing shorter than a short thing long) |
bernard towers | 22/03/2022 20:59:51 |
1221 forum posts 161 photos | How about MDRO |
DC31k | 22/03/2022 21:00:59 |
1186 forum posts 11 photos | https://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display/Digital-Readout-Bars-with-Dedicated-Remote-Display |
Paul Lousick | 22/03/2022 21:03:14 |
2276 forum posts 801 photos | Lots of previous posts about readouts. They work OK BUT do not last. I had to replace the ones on my mill 3 times after they failed. Now have a decent set of scales made by Easson.
Huub | 22/03/2022 23:51:35 |
220 forum posts 20 photos | I use these scales (from igaging) on my mill for several years now and they are OK. However, these scales are not swarf or water proof. So I made a "protective" cover to protect against swarf (I don't use coolant on the mill)
Gary Wooding | 23/03/2022 07:23:57 |
1074 forum posts 290 photos | Posted by Huub on 22/03/2022 23:51:35:
I use these scales (from igaging) on my mill for several years now and they are OK. However, these scales are not swarf or water proof. So I made a "protective" cover to protect against swarf (I don't use coolant on the mill) ? |
Stuart Smith 5 | 23/03/2022 10:33:37 |
349 forum posts 61 photos | Arcurotrade sell these. I have 3 of them on my Warco mill. (As per the link from DC31k earlier). I found the display a bit small so built an adapter to use the TouchDRO app on a cheap Android tablet for the display. Stuart
DC31k | 23/03/2022 11:07:41 |
1186 forum posts 11 photos | Posted by Stuart Smith 5 on 23/03/2022 10:33:37:
I found the display a bit small... Any thoughts whether something like this could serve as an alternative to your solution? https://www.amazon.co.uk/Magnifier-Fresnel-Magnifying-Reading-Transparent/dp/B095WY4K5D |
HOWARDT | 23/03/2022 12:18:44 |
1081 forum posts 39 photos | Need good protection to minimise swarf ingress, depending on lathe it may be very close to cutting point. I had one on my mill, lasted about twelve months then readout was all over the place even though well covered. |
