Die Hardenedbedway | 20/03/2022 07:27:06 |
![]() 44 forum posts 40 photos | Hi Folks I need to bond or stick 2mm aluminium platework together. What should I be using ? In the past Ive used JB weld but Ive found it messy, difficult to use, too thick and takes a long time to set. Its not appropriate for the job I need it for. Looking for something with low viscosity and sets reasonably quickly. I feel 'super glue' is a cop out ( and brittle ) If there a loctite product suitable ?
Thank you
C Edited By Die Hardenedbedway on 20/03/2022 07:28:04 |
Thor 🇳🇴 | 20/03/2022 07:35:53 |
![]() 1766 forum posts 46 photos | I have always used epoxy both for Aluminium and mild steel. Yes, it can be a bit messy, use disposable gloves. Loctite do have epoxy, see here. Thor |
Die Hardenedbedway | 20/03/2022 07:41:05 |
![]() 44 forum posts 40 photos | Cure speed of 1 minutes sounds good |
SillyOldDuffer | 20/03/2022 11:59:32 |
10668 forum posts 2415 photos | Posted by Die Hardenedbedway on 20/03/2022 07:27:06: ... I feel 'super glue' is a cop out ( and brittle ) ... Pity, because super-glue would be my answer. Like all glues it's not strong against peeling or shocks, nor is it gap filling. I've not noticed it's particularly brittle between close fitting smooth surfaces. Could be wrong! Dave |
Nick Clarke 3 | 20/03/2022 12:05:45 |
![]() 1607 forum posts 69 photos | Posted by SillyOldDuffer on 20/03/2022 11:59:32:
Posted by Die Hardenedbedway on 20/03/2022 07:27:06: ... I feel 'super glue' is a cop out ( and brittle ) ... Pity, because super-glue would be my answer. Like all glues it's not strong against peeling or shocks, nor is it gap filling. I've not noticed it's particularly brittle between close fitting smooth surfaces. Could be wrong! Dave You can get high viscosity superglue that is a bit better (but not perfect) at gap filling. |
blowlamp | 20/03/2022 13:28:13 |
![]() 1885 forum posts 111 photos | It depends on the application, but some of these modern-day mastics/adhesives are super strong. Martin. |
Ian Parkin | 20/03/2022 13:34:17 |
![]() 1174 forum posts 303 photos | Loctite 330 is my go to glue for jobs like this..its in a tube like toothpaste quite thick and hard to squeeze out...put on one side of the job spray the activator onto the other side bring together and clamp if you need to. |
Jeff Dayman | 20/03/2022 14:37:19 |
2356 forum posts 47 photos | 3M has a good IRSA product, and will stand behind it. Just FYI. https://www.youtube.com/watch?v=hXk5Y9zg1dY |
Die Hardenedbedway | 21/03/2022 05:38:47 |
![]() 44 forum posts 40 photos | Thank you folks |
JasonB | 21/03/2022 07:50:49 |
![]() 25215 forum posts 3105 photos 1 articles | Loctite "Black Max" cyno (superglue) contains rubber particles and will be more flexible than the regular stuff. Being low viscosity it will spread easily in a flat joint. Without going to look in the workshop I think the number is 489. Or slightly warmed Araldite spreads easy enough though as with most 2 part things a faster cure usually mean less strength |
JohnF | 21/03/2022 10:54:48 |
![]() 1243 forum posts 202 photos | I would think an epoxy would be the best, maybe researching what the aircraft and car makers use ! Jaguar Landrover use it on aluminium bodied vehicles and much of what was riveted on aircraft is now bonded I believe. Just my thoughts, John |
