Where to buy
Michael Brett 1 | 10/03/2022 16:56:38 |
59 forum posts 6 photos | I need to replace the head stock drive belt on my Super 7 with a Fenner link belt. I have found a company called lathe spares online who have one for about 23 pounds but they do not take pay-pal and I am reluctant to give out my credit card details. Anybody used this company or could give me an alternative. Cheers Mike |
noel shelley | 10/03/2022 17:28:49 |
2308 forum posts 33 photos | A ) Don't use link belt B) you need an A29.5 belt any good transmission/ bearing supplier will have one, just called my supplier LESS than £4 +vat. Noel. |
DiogenesII | 10/03/2022 19:01:22 |
859 forum posts 268 photos | I've used Lathe-spares more than once, never had any problems, I think they supply a 'proper' belt for about a fiver which as Noel says is a better bet than linkbelt.. No connection with them except as a satisfied customer for odds & sods, their pricing structure is a bit more grounded in reality than some other Myford spares places.
John Haine | 10/03/2022 19:11:20 |
5563 forum posts 322 photos | RS stock them. The red Fenner link belts are excellent if you have the right size, mount them the right way round, and apply enough tension. Don't buy the cheap plastic version from RDG, they slip. |
John Haine | 10/03/2022 19:11:21 |
John Haine | 10/03/2022 19:42:09 |
**LINK** - take PayPal |
Michael Brett 1 | 10/03/2022 20:02:00 |
59 forum posts 6 photos | I already have a cheap plastic belt from RDG that is why I need to replace it. I would rather fit a link belt than attempt to take the machine apart and risk upsetting the settings. I looked at RS but I have no idea how the belts dimensions are taken , and as I could see no mention of what belt would fit a Myford how can I order one. Thanks for replies anyway , but I am none the wiser. Mike |
John Haine | 10/03/2022 21:52:06 |
5563 forum posts 322 photos | You need to measure the width at the top of the pulleys and Google for the standard dimensions.. As for length, IIRC I bought a metre for my Super 7, but the big bore S7 has a narrower belt than the ML7 so that wouldn't help you. This will probably tell you what you need to know - It's amazing what you can find in one Google query - people should perhaps try it. |
noel shelley | 10/03/2022 22:08:11 |
2308 forum posts 33 photos | If you must use a link belt then order 1m it will be more than enough ! Though dismantling the head stock is not hard and resetting the bearings is easy - you will learn a useful skill that will make sure your headstock is properly set - it may not be so now. Noel. |
peak4 | 10/03/2022 22:18:31 |
![]() 2207 forum posts 210 photos | Yes, I've tried both black and white plastic ones from RDG, and had little success with either. Bill Edited By peak4 on 10/03/2022 22:23:14 |
duncan webster | 10/03/2022 23:31:36 |
5307 forum posts 83 photos | Have bought belts, Orings, seals and bearings from Simply Bearings. Very helpful. They stock Fenner Nutlink belts nutlink, but I've never used link belts. I do know that the generator on Tornado is driven off one of the tender axles by a link belt, otherwise they'd have to take an axle out to change the belt, which would be more than a bit inconvenient. |
peak4 | 11/03/2022 01:26:04 |
![]() 2207 forum posts 210 photos | Posted by duncan webster on 10/03/2022 23:31:36:
Have bought belts, Orings, seals and bearings from Simply Bearings. Very helpful. They stock Fenner Nutlink belts nutlink, but I've never used link belts. I do know that the generator on Tornado is driven off one of the tender axles by a link belt, otherwise they'd have to take an axle out to change the belt, which would be more than a bit inconvenient. Nutlink belts, like T-Nut ones are deeper than the Fenner Powertwist, or the ones I linked to in my previous post. |
peak4 | 11/03/2022 15:28:29 |
![]() 2207 forum posts 210 photos | Just coming back on this one for the sake of completeness. |
Michael Brett 1 | 11/03/2022 15:45:41 |
59 forum posts 6 photos | All sorted now, many thanks guys. Mike |
