My first lathe, a gift from a friend
Andrew Chesney | 21/01/2022 17:22:18 |
7 forum posts 21 photos | Dear Folks,
P.S. I was going to attach photos, but I'm new to this platform and can't work it out. |
Gray62 | 21/01/2022 19:36:43 |
1058 forum posts 16 photos | |
Andrew Chesney | 21/01/2022 19:39:14 |
7 forum posts 21 photos | @Gray62 thank you - See my other photos too
noel shelley | 21/01/2022 19:50:58 |
2308 forum posts 33 photos | Hi Andrew, I know nothing about a raglan but as a capstan is it 3Ph ? I know a bit about lathes in general. If you need help or advice about wiring it up I;m not far from you. When moving it bear in mind it will be very heavy and may not be very stable. Good Luck Noel Just seen the pics, YES it will be VERY heavy and top heavy. It's got a lever operated collet chuck and the capstan looks as though it is like the myford an attachment. When collecting see if there are any collets for it, there may be many bits that are for the capstan. N Edited By noel shelley on 21/01/2022 19:52:37 Edited By noel shelley on 21/01/2022 19:56:29 |
Andrew Chesney | 21/01/2022 19:53:41 |
7 forum posts 21 photos | Dear Noel, I had four men from my local congregation to help move it for me, I think the weight is circa 320kg! Kindest regards
Howard Lewis | 21/01/2022 20:53:32 |
7227 forum posts 21 photos | What wonderful friends to have! It looks as if you might need to find some fittings for the Capstan, such as holders for say, Centre, Roller boxes (Leading and Trailing ), Die Box or Die Holder, Tap Holder, . If all else fails, you could fabricate / machine some of these Each one is basically a flange with a body with a central bore to hold the particular tool. If so, probably the first job will be to make some form of adaptor that allows a conventional 3 or 4 jaw chuck to be mounted; unless you can find someone to do the work for you. (Have you tried contacting The Saracens Head railway group? Howard |
Andrew Chesney | 22/01/2022 09:13:08 |
7 forum posts 21 photos | @Howard - thank you. I've not heard of Saracens Head railway group. I guess it must be another location (not Lincs)? I too was thinking how nest I can get a three-jaw chuck mounted - I have little clue currently. Just a little daunted by this project. Kindest regards ANDREW
Howard Lewis | 23/01/2022 10:59:00 |
7227 forum posts 21 photos | Andrew, Saracens Head IS a south Lincolnshire group, but they don't seem to have a website. Maybe the Southern or Northern Federations might have contact details, if you ask I am sure that if you start asking around Lincolnshire Model Engineering clubs, someone will have a contact.. Maybe someone on here will be able to put you in contact? They exhibited at the now defunct Spalding Hobbies and Model Engineering Show., and occasionally have met someone who I recognise as a member, although do not know his name. Mounting a 3 or 4 jaw chuck will require an adaptor which fits the Mandrel bore to carry the chuck. Once you know what the bore is, a suitable adaptor can be made up (MT stub mandrels are available (Arc EURO don't sell above 3 MT, but RDG offer a 4 MT. ) Being a Raglan, the mandrel bore may be 4 MT, as "read across" from the centre lathes.. Any info on the Lathes UK site? Once a backplate is mounted on such an arbor, all machining should ensure that the register is square to the lathe axis, and concentric. Capstan tooling will be automatically centred of the holder is dowelled to the Capstan head in some way and then bored / reamed from the mandrel.. HTH Howard |
Andrew Chesney | 23/01/2022 12:11:15 |
7 forum posts 21 photos | @Howard - Thank you for the wealth of information. Kindest regards |
Andrew Chesney | 24/01/2022 15:35:03 |
7 forum posts 21 photos | Dear Folks, I have take some photos of the motor (single phase) and the two boxes at the rear of the lathe. Oh my the control box (whatever that is used for), has relays, etc. I wonder if I need to use this, or if this is for a three-phase input? I just wonder what the general view is: (1) use existing controls or (2) bypass and re-wire? I am concerned if this control, panel NEEDS to be used for the electro-magnetic clutch, any ideas?
Regards ANDREW
I have take some photos of the motor (single phase) and the two boxes at the rear of the lathe. Oh my the control box (whatever that is used for), has relays, etc. I wonder if I need to use this, or if this is for a threephase input? |
Brian H | 24/01/2022 15:51:01 |
![]() 2312 forum posts 112 photos | Congratulations on your new acquisition, here is a site with info on your lathe: http://www.lathes.co.uk/raglan/**LINK** Brian |
Andrew Johnston | 24/01/2022 16:25:06 |
![]() 7061 forum posts 719 photos | The item with square fins, below the transformer, is a selenium rectifier, mostly likely to provide DC for the electromagnetic clutch.So you will need the panel to use the clutch. Andrew |
Oily Rag | 27/01/2022 20:59:48 |
![]() 550 forum posts 190 photos | Andrew, I've just noticed your posting about this Raglan Capstan machine. This looks to be a very rare powered capstan model. It has two electro magnetic clutches inside the headstock and this allows instant speed changes to be accomplished for capstan work. I have some pictures of the insides of the headstock and a diagram of the headstock arrangement. These are like no other Raglan machine and was intended purely for capstan type work. I believe the spindle may also be the 'LOO' type with a taper register, not the threaded type nose as used by 'normal' Raglans, The way these capstans work was to set them up for mass production of small items (bolts, nuts, studs, short turned specials) To cut a thread for instance requires a Coventry style Die Head with corresponding dies of the correct thread, the cross slide operates as a fixed chamfer and cut off slide. There is only a power shaft at the front of the bed to power the capstan. A very desirable machine - but only if you want to produce 500 1/4" UNF studs! Martin |
noel shelley | 27/01/2022 22:14:32 |
2308 forum posts 33 photos | I have seen this machine, very clever ! 3/4hp motor with variable speed pulleys feeding 2 electro clutches, giving stepless speeds of 85 to 1750. 24v dc for the clutches. The mandrel has a lever operated collet chuck. The cross slide has 4 stops, 4 way tool post and rear tool post for parting off. The saddle has 4 stops. The capstan is six station and driven off an auxilliary shaft via change wheels. Built for Small production work, a fascinating machine. Noel. |
Andrew Chesney | 29/01/2022 19:20:50 |
7 forum posts 21 photos | Martin, Andrew and Noel, A big THANK YOU for your input. Noel visited visited this week (what a very nice bloke), he gave me some confidence in getting this lathe up and running. I'm busy for a couple of weeks on other matters, but will then get the paraffin, rags and WD40 out to fully clean this up. It will need re-wiring, as it has been somewhat molested. It would be ideal to restore the paintwork too - I enjoy the "journey" of restoration. Regards ANDREW
