EMCO Maximat Super 11 - Headstock & Gearbox Oil
Bountyboy18/01/2022 20:55:54
62 forum posts
8 photos
Hi,
I’m struggling to find a supplier in the UK who sells small amounts of Castrol Hyspin AWS 46 (EMCO recommended oil), I only need 1litre but most sellers only offer 20 litres or more.
I tried finding an equivalent, Mobil DTE 25 ultra which is a hydraulic oil and quite thin, my fear is it won’t protect the gears.
Any advice would be most welcome,
Thanks
David Colwill18/01/2022 21:23:49
782 forum posts
40 photos
I keep other Castrol oils in my eBay shop ( I have AWS 68 ) but not this. I will ring my suppliers and see if I can get some as it may be worth stocking.
Regards.
David.
Mark Davison 118/01/2022 21:28:59
134 forum posts
38 photos
Try Smith and Allan in Darlington. If they don't have it they will likely have a suitable alternative.
Edited By Mark Davison 1 on 18/01/2022 21:30:01
Dave S18/01/2022 21:38:39
433 forum posts
95 photos
Hyspin 46 is just a quality 46 weight hydraulic oil.
Google for 46 weight hydraulic oil and many options appear.
If your concerned check it meets DIN 51524 Part 2 which is what Hyspin is specified as.
Something like this: 5l on amazon should be fine .
Bountyboy18/01/2022 22:39:00
62 forum posts
8 photos
Thanks for all your help. David if you start to stock Castrol Hyspin AWS 46 I’ll definitely be interested, please leave a link or PM me.
Cheers
noel shelley18/01/2022 23:25:35
2308 forum posts
33 photos
Castrol hyspin aws is a range of hydraulic oils ! 46 is a medium hydraulic oil, it will be thin so it can easily run back into a bearing. AWS 32 is a SAE 10. AWS 46 MAYBE an SAE 30. For viscosity think of it as an old car engine oil, NOT an EP90 gear oil. A good motor factor may be able to help you. Witham oils or Morris oils will do it, or try an agricultural supplier ! Goog luck, Noel
PS 32 and 46 are ISO numbers
Neil Lickfold19/01/2022 02:38:17
1025 forum posts
204 photos
ATF(Automatic transmission Fluid) oil work very well for lathe gear boxes. The advantage of the AFT oils , is that they have buffers for acid and for alkalines as well. Can cope with lots of differing materials as well. It's also sold in 1l packs as well.
David Colwill19/01/2022 13:23:06
782 forum posts
40 photos
I have ordered some which should be here in 3 to 5 days.
I will PM you when it arrives.
Regards.
David.
Bountyboy20/01/2022 11:49:39
62 forum posts
8 photos
Thanks David Colwill
