and similar products …
Michael Gilligan | 05/01/2022 16:42:05 |
![]() 23121 forum posts 1360 photos | In an ongoing discussion : **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=176391&p=1 John Smith 47 on 05/01/2022 08:48:34: wrote: ... that probably took about 20 seconds to be laser cut out of a sheet of metal! . which prompted me to raise a general question for the forum: … for anyone who actually uses laser cutting: What size is the beam-spot ? . The relevance of that question may have been missed; so I am repeating it here, to avoid cluttering-up the discussion on John’s thread. Contrary to John’s opinion; my own ‘working assumption’ is that the gauges would need to be photo-etched. … I have never personally seen a laser cutter with a beam-spot sufficiently small to cut a female radius of 0.5mm. Grateful for informed comment from those in the know ! MichaelG. |
David Noble | 05/01/2022 16:58:08 |
![]() 402 forum posts 37 photos | I don't know about laser cutting but I do have some experience with sheet metal. They could be made on a cnc punch machine which I have seen produce some very complex shapes. David |
Michael Gilligan | 05/01/2022 17:00:40 |
![]() 23121 forum posts 1360 photos | Footnote: If anyone wants drawings of the 167 series gauges; start here : **LINK** https://www.starrett.com/searchresults?searchQuery=167 The Inch versions have 2D drawings freely downloadable as PDFs The Metric versions have 3D drawings, but these require registration/sign-in to download MichaelG. . The ‘cloners’ probably did |
Dave S | 05/01/2022 17:17:22 |
433 forum posts 95 photos | From memory something like 0.1 mm is pretty normal. They use fibres as the light delivery system. This might be interesting reading, although it is welding not cutting the tech is iirc the same I personally doubt that small radius gages are laser cut.
Michael Gilligan | 05/01/2022 17:26:01 |
![]() 23121 forum posts 1360 photos | Thanks, both That’s an impressive document, Dave MichaelG. |
Andrew Johnston | 05/01/2022 17:54:29 |
![]() 7061 forum posts 719 photos | I have a recollection that Moore and Wright used to state that their radius gauges were machined, and hence were better than the opposition who punched them. Andrew |
Michael Gilligan | 05/01/2022 18:24:56 |
![]() 23121 forum posts 1360 photos | The plot thickens … I have just been comparing two of the 2D Starrett drawings: 167-010+.pdf and 167-1_8+.pdf There are substantial differences in the level of information contained. I suppose I better download the set, to see in any contain manufacturing instructions ! MichaelG. |
Bill Pudney | 05/01/2022 19:21:36 |
622 forum posts 24 photos | Size of the laser beam..........Some twenty years ago I had some balsa wing ribs for a model aeroplane cut, approx 70 off from 1/16" thick wood and approx 140 off from 1/32" wood per aircraft set. At the extreme leading edge there to was to be a 0.8mm diameter carbon rod, which required, naturally, a 0.4mm radius cut out for about 270 degrees. Imagine my surprise when after a very short time a parcel arrived with two sets of ribs. My major concern was the tiny cutout at the leading edge, into which the carbon rod fitted beautifully with a very satisfying "click". I appreciate that my task involved cutting balsa wood and not tool steel or whatever, so the power of the laser could be lower and therefore presumably the beam smaller. Hopefully it gives some idea of the versatility of the process. cheers Bill |
Dave S | 05/01/2022 19:41:44 |
433 forum posts 95 photos | Wood is generally cut with a CO2 laser, métal with an ND-YAG - massive difference in power but only slight difference in wavelength IIRC - both are IR ish - so basically super hot points of light. Dave |
peak4 | 05/01/2022 22:35:39 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 05/01/2022 18:24:56:
The plot thickens … I have just been comparing two of the 2D Starrett drawings: 167-010+.pdf and 167-1_8+.pdf There are substantial differences in the level of information contained. I suppose I better download the set, to see in any contain manufacturing instructions ! MichaelG. I've just looked at one of the 2D diagrams, I think it was the 1/64" |
Michael Gilligan | 05/01/2022 22:51:16 |
![]() 23121 forum posts 1360 photos | Well-spotted, Bill … I confess to being a little disturbed by the ‘fractional tolerance’ note at the bottom of that sheet MichaelG. . P.S. I’ve just skimmed through my downloads, and found some dated ‘51 Edited By Michael Gilligan on 05/01/2022 22:58:31 |
Michael Gilligan | 05/01/2022 23:18:36 |
![]() 23121 forum posts 1360 photos | Update: This video [starting about 8 minutes in] has some reasonable images of the Starrett items. … it looks like they are more traditionally manufactured than I thought. MichaelG. |
peak4 | 05/01/2022 23:22:17 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 05/01/2022 23:18:36:
Update: This video [starting about 8 minutes in] has some reasonable images of the Starrett items. … it looks like they are more traditionally manufactured than I thought. MichaelG. I think your link's dropped off. |
Michael Gilligan | 06/01/2022 00:07:51 |
![]() 23121 forum posts 1360 photos | Oops … Sorry about that, Bill **LINK** : https://youtu.be/IR5sG1AcUVw MichaelG. |
John Smith 47 | 06/01/2022 12:51:15 |
393 forum posts 12 photos | MY COMMENT
Michael Gilligan | 06/01/2022 15:52:41 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 06/01/2022 12:51:15:
MY COMMENT . John, You are of course welcome to contribute to ‘my’ thread … but please note that I started this one with the specific intention of detaching the particular aspect that interests me from your other discussions. … I did this as a courtesy to you; and I only referenced your remark by way of a preface to my question. Please be assured that I neither intended, nor implied, any criticism of your ‘guess’: I mentioned it simply an introduction to my own ‘working assumption’ … at this stage, they are both just options on a much longer list of possibilities. I am in search of knowledge, not points. MichaelG. |
John Smith 47 | 06/01/2022 15:57:16 |
393 forum posts 12 photos | OK thank you for the clarification, Michael. Good to hear. |
