Manofkent | 01/01/2022 09:42:11 |
145 forum posts 29 photos | Starting the new year by recomissioning my Harrison toolkmakers lathe which has patiently sat in the workshop for the last 15 months. It has what I think is a Bison 3 jaw chuck. It is 6" dia. The chuck jaws have bolt on jaws, which are badly worn. Ideally I would like to get new jaws, but new soft/hard jaws would also be an option. The bison jaws (not the bolt ons) are stamped "3500". Does this mean any jaws stamped 3500 will fit - ie does this refer to the scroll teeth and other dimensions? Some suppliers seem to sell 3500/3200 jaws. Are these the same? Sorry for the daft questions, but I do hope someone can just reassure me.
Many thanks and Happy New Year
Old School | 01/01/2022 09:46:04 |
426 forum posts 40 photos | Try this company very helpful with lathe chucks etc. http://www.rotagriponline.com |
Pete Rimmer | 01/01/2022 10:14:34 |
1486 forum posts 105 photos | Are you sure it's a 6" chuck not a 160mm? The set on ebay listed as "Hard Jaws American Style to suit Bison 160mm Chuck" should be direct fitment for your chuck. Try sending the seller a message I have dealt with him and he was good at responding. He might even take an offer since they have been listed quite some time. |
Martin Connelly | 01/01/2022 10:56:18 |
![]() 2549 forum posts 235 photos | These people also sell various chuck jaws. Since they have dimensioned drawings for some of them this may help identify what you have. Martin C |
Tony Pratt 1 | 01/01/2022 11:04:56 |
2319 forum posts 13 photos | Thame Workholding actually make these type of jaws so they would definitely have an answer. Tony |
Dave Halford | 01/01/2022 11:51:03 |
2536 forum posts 24 photos | Posted by Manofkent on 01/01/2022 09:42:11:
John, If those jaws are hard ones then using the least worn of the 4 possible clamping faces and using a known pre turned round bar test how much run out the chuck has. If they are soft jaws, which I hope they are, true them up and using a known pre turned round bar test how much run out the chuck has. The chuck scroll may be bad as well. |
Martin Connelly | 01/01/2022 12:31:09 |
![]() 2549 forum posts 235 photos | How does truing up soft jaws tell you what the run out is? The point of truing up soft jaws is that it eliminates problems of run out. Martin C |
Chris Mate | 01/01/2022 14:02:12 |
325 forum posts 52 photos | My little experience with new 3-Jaw chuck was I checked it with various round bars and found it differ in runout towards the centre holding options the most. |
old mart | 01/01/2022 14:30:54 |
4655 forum posts 304 photos | I bought a set of slot and tenon Toolmex jaws some years ago very cheaply which did not fit the chuck I had thought they would. If you post the dimensions of your worn ones and they match, I will send them to you FOC. |
Dave Halford | 01/01/2022 16:04:14 |
2536 forum posts 24 photos | Posted by Martin Connelly on 01/01/2022 12:31:09:
How does truing up soft jaws tell you what the run out is? The point of truing up soft jaws is that it eliminates problems of run out. Martin C Only at the truing point, as the jaws move further out to where there might be less wear will they not go out of true? |
Martin Connelly | 01/01/2022 17:36:23 |
![]() 2549 forum posts 235 photos | Once you have machined soft jaws at one point moving them to any other position tells you only one thing, they were not machined at that point and there is some runout that may be due to the jaws or may be due to the scroll or may be due to the chuck. In other words it tells you nothing of use. Martin C |
Dave Halford | 01/01/2022 17:52:27 |
2536 forum posts 24 photos | Posted by Martin Connelly on 01/01/2022 17:36:23:
Once you have machined soft jaws at one point moving them to any other position tells you only one thing, they were not machined at that point and there is some runout that may be due to the jaws or may be due to the scroll or may be due to the chuck. In other words it tells you nothing of use. Martin C With respect, it would tell me not to spend money on it if it went say 10thou out. |
Chris Crew | 02/01/2022 09:58:16 |
![]() 418 forum posts 15 photos | Maybe not an answer to the OP but just my experience and information imparted during my abandoned apprenticeship training, circa 1968, is that no 3-jaw chuck will ever provide repeatable concentricity once the work-piece has been removed. Therefore, as many diameters as possible are turned at one setting and if the work-piece has to be removed for another operation and then returned to the lathe, either you resort to the 4-jaw or grip-true and clock it with a TDI, you use a collet chuck or you turn it between centres if at all possible from the start and continue the work after replacing it between the centres. Self-centring chucks are obviously useful and some are quite accurate at various diameters but they will never reset precisely once the work-piece has been removed which always has to be borne in mind. |
Tony Pratt 1 | 02/01/2022 10:45:37 |
2319 forum posts 13 photos | It is indeed 'good practice' to machine as much as possible in one setting. Tony |
Martin Connelly | 02/01/2022 11:01:12 |
![]() 2549 forum posts 235 photos | This page refers to Indexa 3500 jaws. Zoro chuck jaws In May 2020 I offered a set of these jaws free to anyone who needed them (as opposed to just wanting them) Outside jaws for Indexa chuck If they will fit your chuck you can have them for the price of the post and packaging. The dimensions are shown apart from the pitch of the scroll which is 7mm. They are for the 125mm chuck but, from the given dimensions, if the scroll pitch is the same they should fit. Martin C Edited By Martin Connelly on 02/01/2022 11:25:09 |
