Michael Callaghan | 13/12/2021 10:38:59 |
173 forum posts 7 photos | Hi chaps. I am part way through building a locomotive build stand. This is based on a Genie lift. Part of the job is a turn beam which can be used to work underneath the loco by turning it upside down on the beam. And here lays the problem. As you all know a locomotive weighs a lot and the load on the pivot bolt would be high. To help out here I was thinking of bearing. This would help when turning the locomotive over on the beam. The problem I have is two fold. For the beam I am using 4x2 inch aluminium square 4mm thick. And a 12mm shoulder bolt. I could add 2 bearing housings to each side of the beam, or fit a tube running inside the beam carrying the bearings. What would be your best. Idea, and what would be the correct bearings to use. I have material to make bearing housings, but nothing for the tube if I go that way, and with the cost of metal these days and problems with delivery, would housings be the way to go. Thanks |
Jon Lawes | 13/12/2021 11:06:26 |
![]() 1078 forum posts | My locomotive spit isn't difficult to turn despite being on two plain bearings. In the interests of controllability it could be that a bit of friction is desirable. I'm sure you have considered this but remember the CofG of the locomotive is much higher than the buffer beam once the boiler is on; its much nicer to have it pivoting around the CofG than trying to fight gravity! I don't doubt you have already considered this of course. |
Nigel Graham 2 | 13/12/2021 11:15:19 |
3293 forum posts 112 photos | First, you are not making a centrifuge! You will turning the loco through some angle, slowly, by hand, and only fairly occasionally. So you don't need an elaborate bearing, just one that will take the load, and a plain brass, bronze or cast-iron bush carrying a mild-steel shaft (I assume the M12 bolt) would be more than enough. In fact if an ordinary bolt will not be to ever-so-high accuracy even on the plain shank, and for this purpose it would not really matter if the bearing is a plain hole drilled through mild-steel the bearing-length of the shank. Drill it carefully to produce a reasonably smooth wall, and provide an oil-hole or grease-nipple in its top centre. If you look at commercial engine-hoists, lifting-trolley etc. most don't have anything more than steel pins in steel bushes, though higher-quality ones may have reamed holes and hardened, ground pins. (You can buy shouldered socket-screws with hardened and ground shanks, precisely for such purposes, and they are not very expensive. I am using two M6 versions for my steam-lorry engine's gudgeon pins... don't worry purists, it's an enclosed engine!) ' Looking at typical loco lifts occasionally featured in the magazine, the fulcrum is usually set at approximately the loco's axis of mass, to balance the load to a large extent. Some use a worm and wheel for rotation, though that's not essential provided you can control the over-turning and lock the assembly in place, easily. One way for anything like that is a large-diameter hand-wheel, clipped or loose-pinned to the shaft for safety in use, but readily removeable for access to the work itself. ' Looking at your beam description, will that wide alumimium-angle, even with the deeper web pointing correctly downwards, leave sufficient access to the up-turned loco? Or is the beam a frame wider inside than the loco itself?
Dave Halford | 13/12/2021 11:16:14 |
2536 forum posts 24 photos | I had a car rottisery mounted on four 1" plain plummer blocks, don't use ball races and make the buffer beam connector arm adjustable and a drilled circular disc to take a tent peg size locking pin. |
Michael Callaghan | 13/12/2021 11:29:48 |
173 forum posts 7 photos | Thanks chaps, interesting reply’s. Looks like I was trying to over engineer the thing. |
martin haysom | 13/12/2021 12:10:05 |
![]() 165 forum posts | i built a 5.8 l v8 on an engine stand. the stands pivot is just a steel tube in a steel tube one end only. easy to turn i dowt your engine is heaver. make it adjustable so it ready for next time |
Ady1 | 13/12/2021 12:57:42 |
![]() 6137 forum posts 893 photos | A cog with a worm operated by a handle would create a moveable non locking spit |
alan ord 2 | 13/12/2021 14:54:59 |
![]() 145 forum posts 41 photos | Michael, if you go into my photos you will see the version I made. Very simple and I made it in a few weeks. The design was published in an old ME mag. If you need the mag issue number etc. or a photo copy let me know. Alan |
alan ord 2 | 13/12/2021 14:55:01 |
Speedy Builder5 | 13/12/2021 16:41:01 |
2878 forum posts 248 photos | I made a spit for a Citroen 2CV van body - used for welding and spraying. I just used a scaffold pole and clamps and a couple of "A" frames. My loco frame was a couple of 3/8" ply triangles with a couple of bolts locating in the buffers and a third 6mm bolt for the axis. The only problem with that was access to the smokebox. Bob |
