Hi
New member Sheffield
Drew Mason 106/12/2021 10:07:35
16 forum posts
24 photos
Hi eveyone
Very pleased to join the forum and in need of a little help (i will post when i've found the correct area). I am new to the wonders of lathery and have been enjoying myself immensely. I subscribe to Modedl Engineers Workshop which is just a fabulous read.
Just wanted to introduce myself before begging for help now my Sieg SC3-400 has died!..
So hi to all
Best regards,
Drew
Brian H06/12/2021 16:43:10
2312 forum posts
112 photos
Hello Drew and welcome. I'm afraid that I cannot help with your Sieg but I'm sure that someone on here will be able to help.
I'm about 20 miles South of you near Mansfield.
peak406/12/2021 17:04:53
2207 forum posts
210 photos
Hello and Welcome; looks like I got out just in time. devil
(recently retired from Sheffield-Crookes, and moved to Buxton).
Shout up if you need any specific Sheffield contacts or info.
Bill
noel shelley06/12/2021 17:08:10
2308 forum posts
33 photos
Welcome Drew, I cant help you with the sieg but there will be maNY HERE WHO CAN ! Good luck Noel.
Ian Parkin06/12/2021 17:25:59
1174 forum posts
303 photos
Welcome Drew from me in NE s7
Howard Lewis06/12/2021 17:38:28
7227 forum posts
21 photos
Welcome to the Forum
There will be at quite a few others on here who can help you.
What were you doing when it failed?
Not trying to take 2 mm cuts with a high feed rate, I hope! It is a small 400 watt brushless DC hobby lathe, not a three phase 10 hp 21" industrial monster.
Starting from a totally simple base
1 ) Is the fuse in the plug intact? (Assumes that power is available at the socket )
IF NO, replace
2 ) Is the fuse on the machine intact? If NO, replace. If you have produced a fault on the board, it may blow again., and then you are in deeper trouble.
3 ) Does the motor run? If Yes then the problem is mechanical in the drive line, (belt or gears )
If NO, THEN you start investigating the board and the motor., and need specialist advice.
There is a Model Engineering Society in Sheffield. Look it up on Google, and join. You will find it useful when you have your lathe up and running again. You will learn a lot, just by talking to and listening to the other members.
Drew Mason 107/12/2021 19:25:19
16 forum posts
24 photos
Hi all and thanks for your kind messages.
Howard u6 chip now has a hole in it and cap and diode next to it charred..
Thanks for the advice
Best regards
Drew
Harry Wilkes07/12/2021 21:24:12
1613 forum posts
72 photos
Welcome to the forum
H
Howard Lewis08/12/2021 06:44:44
7227 forum posts
21 photos
That sounds rather terminal!
Sounds like you need to talk to Ketan about a replacement board!
Take a look on the Arc Euro website for prices and availability.
clogs08/12/2021 09:04:21
630 forum posts
12 photos
I know nothing of these tiny lathes but would it not be better to upgrade to at least 240v motor or even a 3phase with a VFD...?
no idea if that s the correct term.....
small motors and electronics........grrrrrr....
arn't they always in trouble this DC stuff.........?
