Pump centre
John Haine22/11/2021 10:49:10
5563 forum posts
322 photos
I would find a "pump centre" or "Sprung centre" very useful for locating centre drilled dots for referencing for milling. By this I mean a sleeve max 10mm diameter with a true sliding centre point protruding from it which is sprung outwards with something to retain it in the sleeve. In use one chucks the sleeve in a collet and brings the chuck down until the point clicks into the hole one wants to locate.  At the moment I fit a rod with a centred point in the ER collet so it can slide with a little friction but this is a bit hit and miss.
Does anyone know of such a device made commercially please?
Edited By John Haine on 22/11/2021 10:50:25
DMB22/11/2021 11:14:55
1585 forum posts
Hi John,
I believe that Arceuro sell them.
For another John!
Michael Gilligan22/11/2021 11:20:58
23121 forum posts
1360 photos
[Sorry] Not answering your purchasing question, John
Here is a useful discussion from the NAWCC : **LINK**
https://mb.nawcc.org/threads/making-a-pump-center-for-8mm-face-plate.92078/
Mike Crossfield22/11/2021 11:22:56
286 forum posts
36 photos
In his book "A Model Engineers Workshop Manual" G H Thomas discusses similar devices (page 27) and describes a neat design. I made one 20 odd years ago and use it from time to time. Like all GHT designs, it works beautifully. Could be made in an hour. GHT mentions that a commercial device used to be made by Starrett.
JasonB22/11/2021 11:35:39
Most co-axial centre finders come with a point as well as the usual arms though it does mean raising the head a bit more than a simple device it doe shave the advantage of giving a reading as to how far you nee dto move the table to get the part true
Howard Lewis22/11/2021 11:37:28
7227 forum posts
21 photos
If you don't want to make, you could use one of the gadgets meant for supporting a Tap in a machine.
I have a set of six, 3 male, 3 female centres. I think the trade name is Tap Tru.
Arc sell male ones as Spring Tapping Guide
The Micro one (060-250-03100 ) has a 4.75 mm dia pin, while the larger one (060-250-03200 ) has 9.5 mm dia pin.
John Haine22/11/2021 13:49:34
5563 forum posts
322 photos
Thanks for the responses. The ArcEuro one would be perfect but alas has a 12.7mm shank but my max ER collet is 10mm. I do have a 12mm BT30 collet but that's still too small. Oh well, out with the drilles and reamers and make one I think.
ega22/11/2021 22:57:49
2805 forum posts
219 photos
Posted by Mike Crossfield on 22/11/2021 11:22:56:
I made and use GHT's "wobbler" device which I think works in a different way from the one mentioned by the OP; in use it is supported by the tailstock centre.
I would like to find the Starrett version in their catalogue - does anyone know the correct name, please?
Michael Gilligan22/11/2021 23:49:06
23121 forum posts
1360 photos
Posted by ega on 22/11/2021 22:57:49:
I fear there may have been some confusion …
Starrett’s current offerings are here: **LINK**
https://www.starrett.com/category/111603#currentPage=1&displayMode=grid&itemsPerPage=12&sortBy=wp/asc
… none of which could realistically be described as a ‘pump centre’
[or even a ‘pump center’]
Note: __ The version used on the Watchmaker’s lathe is typically manually controlled rather than spring-loaded, but this gives a good idea of the principle:
https://www.snclocks.com/TechnicalInformation/Tid-Bits/Tid-Bit-8-Drilling-tiny-holes/i-xHJcJ97
Edited By Michael Gilligan on 23/11/2021 00:03:17
ega23/11/2021 09:52:09
2805 forum posts
219 photos
MichaelG:
Thank you! I suppose it is possible that GHT himself was confused.
I think his idea of a pump centre was a strongly sprung device which would compensate the expansion of work between centres.
Howard Lewis23/11/2021 11:17:50
7227 forum posts
21 photos
If a commercial available pump centre has too large a shank, it may be possble to reduce the diameter slightly, to 10 mm to fit into your collet.
If the body is case hardened, it may well need a carbide tip to cut it. Removing 1 mm a side will probably remove the case, but since it will only be gripped, wear of the OD is unlikely.
The red hot wire coming off can be quite thrilling to watch!
Nigel McBurney 123/11/2021 11:19:20
1101 forum posts
My punch was made by Eclipse and known as a spring centre punch,I inherited mine from my father ,he used it but I never found it much use ,I prefer the fine prick punch followed up by a centre punch,
Nick Wheeler23/11/2021 11:54:51
1227 forum posts
101 photos
Posted by Nigel McBurney 1 on 23/11/2021 11:19:20:
That's not the same thing as the pump centre in the first post though
